Any high mileage 4 cylinders?
Discussion in '4 Cylinder' started by Samurai49, May 5, 2013.
  1. Aug 11, 2013 at 2:21 PM
    #81
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Just as I suspected. My folks are from Charlotte. Enjoy your rust free frame and salt free street.
  2. Aug 11, 2013 at 2:53 PM
    #82
    RobbieP4VT
    RobbieP4VT Well-Known Member
    Robbie
    Virginia
    2004 Single Cab 4x4!
    vehicles this badass don’t need any mods!
    I have 1997 Tacoma xcab 2.4 manual, 2wd. Original motor and trans. 2 alternators and two starters, 278,000 miles....best damn truck I ever bought...still going!!!!!
  3. Aug 11, 2013 at 4:13 PM
    #83
    ronman737
    ronman737 Dangerous
    Ron
    Greenville, SC
    2008 4Runner 4x4 Sport
    My truck was a NH truck before it wound up down here. I had to have the frame replaced after my spare tire fell out while I was on the highway
    From what i understand they are now doing a recall on just that part. Guess i wasnt the only one with that problem.
  4. Aug 11, 2013 at 4:18 PM
    #84
    george3
    New Jersey
    They bought back my 2000. I've heard that spare tire thing is common - U R not special.:rolleyes:
  5. Aug 11, 2013 at 4:23 PM
    #85
    ronman737
    ronman737 Dangerous
    Ron
    Greenville, SC
    It scared the shit out of me. I was going 70 when it happened, so my spare was too but 25 feet high. Luckily it wasnt a busy time of the day.
  6. Aug 11, 2013 at 5:09 PM
    #86
    george3
    New Jersey
    :eek::eek: Glad U R OK
  7. Aug 11, 2013 at 5:21 PM
    #87
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    285K on my old 97 5 spd. put a clutch in it at 206K no work what so ever to the engine not even a water pump.
  8. Aug 11, 2013 at 5:33 PM
    #88
    george3
    New Jersey
    The water pump lasting to 285 is even more impressive then the motor. Sid you do anything special ? Change the antifreeze often to lubricate it ? My 2000 needed one at 130,000. Congratulations !
  9. Aug 27, 2013 at 10:22 PM
    #89
    danstruck
    danstruck Member
    dan
    ocoee, florida
    06 tacoma 5spd 4wd 2.7, ome 3inch lift
    hard bed cover, step tubes
    110,000 on 06 2.7 5spd 4x4 , have done front and rear brakes spark plugs (tho they didnt look that bad) a 3 inch lift a snorkle and on third set of tires and one front wheel bearing (some water got in it). runs smooth on highway or offroad. doesnt even have any cracks in the fan belt yet.
  10. Aug 28, 2013 at 6:36 AM
    #90
    Eldowr
    Eldowr Well-Known Member
    Donavon
    Georgia
    1999 ext 4wd 5 Speed
    Kenwood sound system
    My aunt just totaled her 2002 ext cab. Before that, she used it for escorting mobile homes, it had 450,000 on it. Only work ever done was a throw-out bearing in the clutch/transmission! Not sure if 2.4l or 2.7l
  11. Aug 28, 2013 at 3:09 PM
    #91
    george3
    New Jersey
    I did my fronts around 60 - when did you need rear brakes ? Thanks - Curious George.
  12. Aug 28, 2013 at 3:10 PM
    #92
    george3
    New Jersey
    450,000 - WOW !
  13. Aug 28, 2013 at 3:10 PM
    #93
    JTS2016TACO
    JTS2016TACO Well-Known Member
    Jamie
    Chandler, AZ
    2016 MGM 4x4 TRD Off Road Double Cab Short Bed
    See my build thread in my signature
    One of the people I work with has a 1990 and it has 270K on it and the only think they have ever done is changed the oil and batteries.
  14. Sep 4, 2013 at 5:49 PM
    #94
    yumyumtaco
    yumyumtaco Well-Known Member
    Kevin
    SO-CAL
    96 preRunner, 2.4L
    Total Chaos Suspension RaceRunner Shocks w/ reservoirs Flared carbon fiber front pushed-out rear fenders
    250k and just getting started.... 96 single cab.. man I love these trucks. Manual tranny. Guttless but fun as hell..oh and I haven't had any major problems just belts and alternator. Going to do a complete rebuilkd at 300k tho.
  15. Sep 20, 2013 at 2:31 PM
    #95
    jij0226
    jij0226 Member
    josh
    raleigh nc
    2004 tacoma base
    I have a Stock 2004 Auto 4cyl with 205000.
    Never any problems.
  16. Sep 20, 2013 at 2:39 PM
    #96
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Sold my 91 a few years back-195K Running strong-the body needed more work than I cared to invest--Replaced the clutch, starter contacts, and clutch master and slave(a couple times),timing hardware.
    And battery of course-- most reliable TOUGHEST and CHEAPEST truck I will ever own.
    Picture to the left
  17. Sep 20, 2013 at 4:30 PM
    #97
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    picked up my 97 4x4 2.7 a couple months back and the odometers broken at 248,000, previous owner said its been broke for a year or better and truck should be in the 260-270k region. the thing seems to run like a champ, but it lived its last few years on a farm so i pretty much had to replace every wearable item in the front susp. i.e. bushings, balljoints etc. and one rear shackle. now she's back on the road again i intend to see how long she'll last and dont intend on babying it.
  18. Sep 21, 2013 at 11:29 AM
    #98
    coma98
    coma98 Well-Known Member
    zach
    ky
    98' built 2rz turbo
    Lowered 4/5 Stage 4 clutch. Fidanza flywheel. W58 trans, arias pistons, pauter rods, arp mains an head studs, cosmetic gasket, T3/t4 15psi and more coming!
    260k an turned the boost up to 12psi. Shes lovin it! Bone stock motor never had the valve cover off. Knock on wood.
  19. Sep 21, 2013 at 12:22 PM
    #99
    4banger4x4
    4banger4x4 Probably should'nt have done that.
    Eric
    Whorelando, Fl
    Whaaa? I wanna do a forced induction but I'm scared with 230k on the clock
  20. Sep 21, 2013 at 2:19 PM
    #100
    coma98
    zach
    ky
    98' built 2rz turbo
    That's about when I started, i jus turned it up to 12 psi but it leans out sometimes. Im fixn to get a aem fic so I can tune it. So that will fix the leaning out. Only thing I've done is put pink top injectors in with a 190 walbro pump. It runs stock untill boosted, its great.
