Any high mileage 4 cylinders?
Discussion in '4 Cylinder' started by Samurai49, May 5, 2013.
  1. Nov 17, 2013 at 11:25 PM
    #141
    RdRunr
    RdRunr Well-Known Member
    Dan
    still in the Matrix
    2014 Base, white, reg cab, 2.7L, 5-spd
    DT header, Flowmaster 50 Series Delta Flow muffler
    Markcal and Hartford like this.
  2. Nov 18, 2013 at 8:42 AM
    #142
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Had 230k on my 2004 2.7L when I sold it. Nothing but brakes, tires, oil and filters!
  3. Nov 18, 2013 at 8:01 PM
    #143
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    You lose :D
  4. Nov 18, 2013 at 8:07 PM
    #144
    seedless024
    seedless024 Well-Known Member
    norman
    SL,UT
    01' TRD ext cab white
    wouldnt ever by a 4 banger.
    but my 96 3.4 v6 had 295k and still purred like a dream until some jackass cut me off and wrecked my truck
    now own a 01' 3.4 with 220k
  5. Nov 18, 2013 at 10:59 PM
    #145
    RdRunr
    Dan
    still in the Matrix
    Haha, yeah, well I'm on my way to 400k! :D
  6. Nov 18, 2013 at 11:05 PM
    #146
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ya, we'll see.
    I've told myself that with both of my previous Toyotas and my wife's Toyotas.
    Ended up trading my '94 on an '03 Tundra with 225k on it, traded the Tundra on an '06 Duramax with 125k on it.
    Wife had 60k on her '00 Echo when we sold it to her daughter and I bought her a new '04 Rav4.
    She's got almost 140k on that Rav4 now.
    I put her ass in a '14 last weekend... she liked it. Now we need a dump truck to unload $26k in our driveway :D
  7. Nov 19, 2013 at 5:36 PM
    #147
    coma98
    coma98 Well-Known Member
    zach
    ky
    98' built 2rz turbo
    Lowered 4/5 Stage 4 clutch. Fidanza flywheel. W58 trans, arias pistons, pauter rods, arp mains an head studs, cosmetic gasket, T3/t4 15psi and more coming!
    262k. put in 440cc injectors an a 15psi spring. Seems to be lovin it other than it using a little oil. (Quart between changes) day by day.. goin with a built motor when its done.
  8. Nov 19, 2013 at 11:32 PM
    #148
    RdRunr
    Dan
    still in the Matrix
    Indeed, we shall see.
    But, I do drive 52.8 mi to work. And we seem to keep our vehicles for a while. My wife had an 85 Camry. We replaced it with a 07 Camry. Now at 130k. I drove my first car (66 Plymouth) for 23 years. Replaced it with a little 98 F-150, now at about 296k.
  9. Nov 20, 2013 at 9:49 AM
    #149
    goldstar
    goldstar Member
    Joe
    Pa
    2004 Tacoma
    Update 467,880. Catalytic converter. State inspection passed.
    New tires Cooper CS4 Touring.
  10. Nov 20, 2013 at 2:31 PM
    #150
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Congratulation ! How'd U keep your frame from rusting out in Pa over almost 20 yrs ? Tacoma's are famous for good motors and rust bucket frames especially our area - NJ PA - mucho salt. Thanks. Curious George
  11. Nov 20, 2013 at 2:39 PM
    #151
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    467,880k Wow. Nice.
  12. Nov 22, 2013 at 7:20 AM
    #152
    E34 OBSESSION
    E34 OBSESSION Its all about the angle...
    Niklas
    Western Suburbs of Chicago, IL
    99 Prerunner Xtra Cab SR5 2.7L
    Bilstein 5100's in rear, Bilstein TRD's in front, 2.5" Toytec spacers, 2.5" Toytec shackles, ProComp add-a-leaf kit, Addco rear sway bar, Poly bushings on practically everything, 285/70/17 BFGoodrich KM2's, Level 8 MK6 wheels, Custom catback exhaust, Various exterior stuff... Of course, more to come...
    1999 Xtra-Cab SR5 Prerunner... 3RZ-FE 2.7L 4 Banger with Automatic Transmission.
    174XXX miles pretty much original minus maintenance parts (starter, belts, plugs, oil, filters)
    Aside from the 22RE, my luck and experience with the Toyota RZ four banger has led me to believe it is just as indestructible as the older motors, and trust me... I do not baby my truck :p
  13. Nov 23, 2013 at 6:05 AM
    #153
    goldstar
    goldstar Member
    Joe
    Pa
    2004 Tacoma
    MAYB ALL t carwashes I went thru after I get off those salted roads. Maintenance is being on top of the elements and then removing all that stuff from underneath. I use a carwash that you drive thru for only $9 and THEY have inside HEAT and a Great undercarriage wash.!!! Must work....lol
  14. Nov 23, 2013 at 2:28 PM
    #154
    Rich91710
    Rich
    Los Angeles
    08 Base
    Undercarriage wash is good.
    Heat is bad.
    Heat accelerates the rate of corrosion.
    The worst thing you can do for your vehicle in the winter is to drive it home on a salted road and park it in a heated garage.
  15. Nov 23, 2013 at 2:32 PM
    #155
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    My 97 2.7 5speed is on her way to 170,000. engine wise all i have done was replace a cracked manifold.
  16. Jan 17, 2014 at 6:27 PM
    #156
    coma98
    zach
    ky
    98' built 2rz turbo
    I'm out of the 200k mile club.. I now have a 60k mile motor:D my old motor went 263k on 13 psi untill it ate up a wrist pin bushing:(
  17. Jan 17, 2014 at 9:25 PM
    #157
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    I like the car washes that use pretty hot water to wash with seems like it gets the crud off better. But I dont know anything about salt and rust I live in the south.
  18. Jan 17, 2014 at 9:26 PM
    #158
    Rich91710
    Rich
    Los Angeles
    08 Base
    Oh ya... heated water is good for cleaning, but you don't want a vehicle with damp salt deposits to sit in a warm room.
  19. Jan 17, 2014 at 9:35 PM
    #159
    toyodajeff
    jeff
    06 reg cab sr5
    One of my friends used to work at a chevy dealer with a nice detailing bay, they had hot ass water in it or maybe it used steam but it would get stuff pretty clean without soap.
    To bad self serve car car washes arent that hot.
  20. Jan 18, 2014 at 6:34 AM
    #160
    Hansel
    Hansel Well-Known Member
    Glenn
    Arizona
    base
    yep, cleaning with hot water or a steam cleaner is a great way to do it. The heat from this dissipates rapidly and in no way does the hot water increase corrosion.
    Like others have pointed out, keeping a "salted" vehicle in a warm environment accelerates the corrosion.
