Any high mileage 4 cylinders?
Discussion in '4 Cylinder' started by Samurai49, May 5, 2013.
  1. Jan 18, 2014 at 12:53 PM
    #161
    crainholio
    crainholio Well-Known Member
    200K miles here on my '03 2.7L and just got done replacing the cylinder head. Burned exhaust valves on cylinders 3 & 4 plus cracks in the combustion chambers. I bought it with 136K miles on the odometer and put over 60K on it before this happened.
    Disappointing, but it got me home, back to to work, and to the garage under its own power so I can't hate it.
    I'll be checking the valve clearances at 60K mile intervals from now on. Never had a DOHC engine before, where valve clearances tighten with wear rather than loosening and giving an audible tick sound as warning.
  2. Feb 9, 2014 at 3:22 PM
    #162
    tquinn
    tquinn Member
    Tim
    NC
    Tacoma SR5 TRD 4WD
    227,000 on my 2001 Tacoma, it is a TRD, SR5 access cab 2.7l 5 speed. Never an issue with this engine or truck for that matter, I bought it new so I know how it has been taken of. Engine has never been into and have just put the first set of belts on it after 13 years if you can believe it, but it has not been abused either. I run Mobile One 10/30 oil and Mobile One filters and Marvel Mystery Oil in the oil at times and in the gas just to help keep the insides clean.
  3. Feb 10, 2014 at 4:44 AM
    #163
    cowboy50
    cowboy50 Well-Known Member
    Dexter,MO
    05 Tundra 4x4
    I like hearing what different people add to their engines to try and make them last longer. Always wondered about the Mystery oil, alot of old timers around here use it. I use Lucas oil additive about every other change. Mine had 170K when I bought it. An old man had it and drove to his hunting spot and the coffee shop. I've had it 3 yrs. now and shows 217K, I use it on the farm but try not to abuse it, It is my daily driver to work about 40 miles round trip.
  4. Feb 10, 2014 at 9:45 AM
    #164
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    I got bored the other day so I decided to give the ol taco a compression test. This truck is knocking on the 300k mark, and looking at it it did not have a friendly life while on the farm it came from. Any who I was pretty surprised to see she had 145-150 psi across all the cylinders. This is at almost 5000' elevation and is the highest comp of anything I've personally checked and I've had some pretty modified vehicles in my day. Surprised me so thought I'd share what I found.
  5. Feb 11, 2014 at 3:36 AM
    #165
    Esau
    Esau Member
    Esau vazquez
    Rainsville AL
    I have a 07 tacoma 367000 mile just oil change and gas thats it
  6. Feb 11, 2014 at 1:49 PM
    #166
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Congratulations ! No brakes, serpentine belt, water pump, battery, alternator - nothing:confused: Curious George
  7. Apr 15, 2014 at 3:09 PM
    #167
    jrbaus
    jrbaus New Member
    montana
    97 4 cyl. 4x4
    My 97 Tacoma has 294000 been a great truck gets driven hard as I live 12 miles from the nearest paved road. Truck is stock and at about 240000 I started having to replace a lot of random parts but the engine and transmission have not needed anything still does not burn or leak any oil.
  8. Apr 22, 2014 at 9:28 AM
    #168
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    My 95.5 2.7 4x4 5-speed is coming up on 176,000 and as far as I know it has only had a new rad and oil changes. Needs a new header and muffler though, stupid cracked manifold.
  9. Apr 8, 2017 at 8:41 PM
    #169
    SUBLIME LBC562
    SUBLIME LBC562 Member
    Andrew
    1998 Toyota Tacoma 2.4l
    Replaced worn parts Ball joints,Rotors,brakes,spark plugs,
    I have a Manual 1998 Tacoma 2.4l that just turned 350,000 miles two days ago,right after my left lower ball joint popped off ,fixed it,two days later my right side happened right outside the part store,not bad for an 18 old truck that hauled a lot of Glulam and paralam beams and lumber on my lumber rack,trash dump runs etc,it took 350,000 miles. And thousands of pounds to wear it off, Changed the clutch for the first time at 330,000 miles,constantly change the engine oil and oil filter about every 2-3 weeks or before more or less than 1,000 miles I do a lot of driving up and down the coast every day,This truck has had good maintenance witch is an overall reason Why it still runs good,starts right up,BTW still needs a little TLC but over all pretty Reliable/Dependable, I have at least another 100,000 miles or more out of it before I can expect somthin else.
    tacoburrito likes this.
  10. Apr 9, 2017 at 4:37 AM
    #170
    tacoburrito
    tacoburrito Well-Known Member
    boston
    2013 regular cab
    5100s. eibach coils. 285/75/16 km2s. leer cap
    lets see the truck!
  11. Apr 20, 2017 at 8:56 AM
    #171
    TenDollarTaco
    TenDollarTaco A Honda guy who got a cheap Taco.
    Columbia
    2005 SR5 2wd 2.7 auto 5-lug
    250k miles
    I just acquired my "new" Taco. It has 248,000. 2.7 auto, 5-lug. It was a work truck for one of the installers for my dad's company. It feels like it misfires a bit when I put it in Drive and begin to accelerate under very light throttle. I will pull codes and compression test it this weekend.
  12. Apr 20, 2017 at 12:54 PM
    #172
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Did you get any service records or other documentation with it? by 248k it should have received a bunch of services and replacement parts as part of normal maintenance.
  13. Apr 21, 2017 at 10:28 PM
    #173
    TenDollarTaco
    Columbia
    250k miles
    Not really...
  14. Apr 25, 2017 at 6:23 AM
    #174
    AJH387
    AJH387 Well-Known Member
    AJ
    Pittsburgh, PA
    '19 TRD OR DCLB
    I love threads like this. In a couple ears, I hope I am still happy with my 4cyl. Too early to tell yet, but I do log a bunch of miles on the little beast.
  15. May 5, 2017 at 6:40 PM
    #175
    MaidenTheTrooper
    MaidenTheTrooper Well-Known Member
    2017 Tacoma SR5 2.7
    So far wheels & tires
    IMG_6079.jpg 99 Prerunner 285k Everything original, even the spark plugsIMG_6079.jpg
  16. May 7, 2017 at 11:04 PM
    #176
    pepperhead71
    pepperhead71 Well-Known Member
    Cajun County Mire,La
    2015 Tacoma Double Cab SR5,2007 Tacoma Double Cab SR5
    2012 pushing152,000 just bought it a month ago and love it
    BassAckwards and KS WRAITH like this.
  17. May 8, 2017 at 6:48 PM
    #177
    bmidd
    bmidd Member
    Brian
    Chattanooga,TN
    2001 Tacoma Pre Runner
    Riiiighhhhtttt
  18. May 8, 2017 at 6:53 PM
    #178
    MaidenTheTrooper
    2017 Tacoma SR5 2.7
    Believe what you want but my Tacoma still running with original spark plugs. Never done the brakes, transmission fluid, nothing... oil changes, air filters & gasoline. Well windshield wiper fluid.
    That's my F-Ing Beast..
  19. May 8, 2017 at 7:28 PM
    #179
    chad L
    chad L Member
    2008 tacoma base
    All original
    IMG_0772.jpg I'm at 287,000 on my 08 5 lug. Drive shaft u joint, front crankshaft seal, right front hub. That's all!
    Hub @220000
    U joint & seal @ 250000
    Everything holds together very well, there is a little shake on the highway, tie rods, etc (upper and lower ball joints are good, just checked them) will probably be replaced by 300,000.
    In the near future I'm expecting (based on experience) water pump, thermostatIMG_0771.jpg , and alternator to need replacement. But all in all you can't buy a better truck.
    Oh btw I just changed by original spark plugs tonight, I took the pic of miles tonight also.
    TheCookieMonster likes this.
  20. May 8, 2017 at 7:32 PM
    #180
    chad L
    chad L Member
    2008 tacoma base
    All original
    There are videos on YouTube of tacomas with 700k, 900k, crazy stuff but it's doable if you don't abuse it too bad
