Any interest in internal roll cage kits for 05+ Tacomas?
Discussion in '4x Innovations' started by traxman25, Sep 20, 2011.
  1. Sep 23, 2011 at 9:57 AM
    #41
    TacoTabe
    TacoTabe Well-Known Member
    Kevin
    Northeast PA
    '93 pickup
    Yeah, external cage is out of the question.
    I wouldnt mind the glass breaking, thats easily replaced without having to replace the truck completely.
  2. Sep 23, 2011 at 10:00 AM
    #42
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    THAT'S what I forgot to include in the build! :facepalm: ;)
    Wouldn't that be an issue with any structurally sound cage? I would think any kind of dampening on the tubes would weaken the structure.
  3. Sep 23, 2011 at 10:01 AM
    #43
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    you wont be able to replace the glass if you roll it good, the cab will be smashed around the cage still.
    Bobby18 likes this.
  4. Sep 23, 2011 at 10:09 AM
    #44
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    If I was to install a cage it would be for my protection not to keep my exterior pretty
  5. Sep 23, 2011 at 10:11 AM
    #45
    traxman25
    traxman25 [OP] 4x Innovations Vendor
    Adam
    Platteville Wi
    Too Many!
    You're running desert races it looks like, so for you, you need a solidly mounted cage. I'm not looking to build this kind of cage kit. For the market I'm looking to serve, a frame tie in kit with bushing isolation still adds extra strength while not creating the noise issues you have. There's a VERY small handfull of people who would even want a cage like what you have, not what I'm looking to do. Your cage is great for desert racing and is what you need, but you sacrifice other performance of the truck, such as in cab noise levels.
    Also, not having carpet or a headliner is adding to the noise levels A LOT. I had carpet in my 4 Runner on the first wheeling trip only. Then it go muddy, wet, and needed to be taken out, cleaned and put back in. It got taken out and tossed. With no other changes to the truck it got significantly louder in the cab just by loosing the carpet, more so than any other modification. You could try wrapping the cage in cage padding (which you should do anyway) to help cut down on the noise as well.
    Certainly not easily. I have friends who have done it in the mini trucks and it was never quite right afterwards. That's on a truck that doesn't have quite the engineering behind cab strength that these do.
    RIGHT!
  6. Sep 23, 2011 at 10:18 AM
    #46
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    If i lived out west and i ran my truck on the dunes at high speeds i'd be interested but it's not necessary for this truck, for me anyways. I do have a street legal s2000 that is fully caged, and am a fan of caged vehicles but not for this truck
  7. Sep 23, 2011 at 10:23 AM
    #47
    Defined
    Defined Well-Known Member
    mike
    southern california
    i dont consider my cage race ready yet , it needs more tube. id say what i have is the min anybody would want out of a rollcage. but if your just talking about building 4 legs with a hoop at the top, it isnt very strong for the 2nd gens and what the majority does with them. a cage needs a lot more bracing to stay ridigid in a 30-40mph roll vs a 5-10 mph roll down a slight grade. id say 150 lbs for a cage in a double cab would definitely be missing a few much needed tubes!
    everybody here is going to want something different and i think a simple bolt in cage would be a good idea . especially if your worried about someone calling you complaining that they cut a hole in the wrong place on the floor or dash. bolt on is the only way around that . what you are trying to do is definitely a huge undertaking.
    are the cages going to be laser cut and cnc bent ? or are all the tubes going to be hand fabricated? as far as bolt-in goes , is it going to bolt on to the frame or the bodymounts inside the truck?
  8. Sep 23, 2011 at 10:27 AM
    #48
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    i like all of your in cab designs now, it looks to me like your cages are built best for someone that wants complete protection in a roll over while keeping complete functionality of the rest of the truck! Ive heard a lot of people mention things like this before about adding a cage to a "factory" truck for those safety reasons!
    I love the idea cause like you said, even though cages like MPJ2s are badass, its not what an average person, whos trying to keep a "truck" and have a cage, would want! Im a personal fan of the idea of a simple design thats strong and provides the best protection while keeping as much pipe out of the way as possible for everyday function!
    and for the sound, people use stuff like dynomat all the time for increased sound deadening. Pull the carpet, head liner, and panels, lay that shit down, then reassemble everything, works great! I wonder if this could also be used on the cage itself
  9. Sep 23, 2011 at 10:35 AM
    #49
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    For the Access cab, keeping the middle open would be important. I would keep the stock seats... Have an optional addon for guys wanting to run harnesses.
  10. Sep 23, 2011 at 10:39 AM
    #50
    traxman25
    Adam
    Platteville Wi
    Too Many!
    Defined, Do you have any photos of your cage? How many feet of tube did you put in your cage? We really should be talking feet, not weight. I've been building cages for many years. If you don't know by now, we don't do legs and halos! That's the WORST kind of cage you could build, and like you said won't hold up to much of anything. http://4xinnovations.com/techarticle/4and5RIC_install_instructions.pdf Skim the first 3 rolls, they're boring, "read" the last two, watch the last video.
    I do WIY cages now, in fact that's all I do for cages. They don't require cutting a hole in the dash and lining up the floor plates is not difficult, so there's very little worry of drilling a hole in the floor at the wrong spot. Drilling a large hole in the dash is a MUCH different story!
    Laser cut tubes is only useful if you want to spend much more money than you need to. We have perfected the systems we use here (which are not laser or hand cut either) and I have no concerns about mass producing the cages in house. Remember this is not a new product line for us, we're not new to offroading, and I'm not new to production of complex tube assemblies.
    Allmotor, you get it, thanks!
    RiggedT, We'll do the harness bar and dash bar and probably a few others as add ons for those who need them. That's how I do the 4 Runner cages and it works out well.
    For those with out a double cab, I'm sorry but I won't have anything for you for quite a while. I've yet to find anyone in the area who wants anything for their 05+, so I had to buy the double cab I have. It'll be a while before I can buy a regular cab and access cab. :(
  11. Sep 23, 2011 at 10:48 AM
    #51
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Cool man. Id hate to have a bunch of tooobs blocking my reach area for snacks
  12. Sep 23, 2011 at 1:06 PM
    #52
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
  13. Sep 23, 2011 at 1:13 PM
    #53
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    well that just killed it for me:(
  14. Oct 10, 2011 at 11:55 AM
    #54
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Adam,
    What's the verdict on this one?
    - Chase
  15. Oct 10, 2011 at 12:00 PM
    #55
    traxman25
    Adam
    Platteville Wi
    Too Many!
    I'll likely be doing something but there's other projects that are in line first.
  16. Oct 15, 2011 at 5:47 PM
    #56
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I need an exo skeleton that fits around the outside of the cab and straight out over the hood to mount at the outside corners of the front end frame. A 400# platform to haul stuff or stand on. Removable would be neat, too
  17. Oct 15, 2011 at 6:42 PM
    #57
    gtrotter
    gtrotter Well-Known Member
    Interlake, Indiana
    2009 Regular cab 4x4, ARB's, 4.88's, bumpers, 2017 DCSB SR5 stock,2008 Reg. Cab 4x4
    locker,mud tires, lifted, toolbox
    What kind of deal do you think you could work on a regular cab? If I showed up with the truck and cash in hand?
  18. Oct 24, 2011 at 5:58 PM
    #58
    Bfoster133
    Bfoster133 If i asked my dad for money, He'd knock me out
    Blake
    Thousand oaks, California
    2011 PreRunner TRD offroad
    15% Tint, 5100's at 1.75, Rear Diff Breather, CB radio, Black rattle canned rims, 265/75/16 Goodyear MTR, Magnaflow Offroad pro cat back, hi-lift bed mounted, shovel bed mounted
    reviving an old thread here, but the sound issue can be solved by filling the tubes with expanding foam, we use this in the pro bikes at the shop i work at and it keeps the tubes from echoing
  19. Nov 1, 2011 at 6:30 PM
    #59
    no mods
    no mods Well-Known Member
    cincinnati
    Some stickers
    Dbl cab here w cash in hand and gas in the cylinder
  20. Dec 11, 2011 at 8:17 PM
    #60
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    bump?
