Any interest in internal roll cage kits for 05+ Tacomas?
Discussion in '4x Innovations' started by traxman25, Sep 20, 2011.
  1. Dec 28, 2011 at 8:33 AM
    #61
    NakedTacoma
    NakedTacoma Well-Known Member
    West Covina
    Mid travel front Long travel rear
    didne read thru 4 pages ...... but would pay for a prebent WIY cage for a reg cab
  2. Dec 28, 2011 at 8:52 AM
    #62
    GRatt
    GRatt Well-Known Member
    Garrett
    Reno
    2017 TRD off road manual
    Cap and tent
    I would for sure want one. To bad i would want racing seats to go with it and i have a Double cab so i would of course have to get a racing bench for the back so i would be looking at about 3G's. maybe in the far off future unless you could just do a mid frame bar thing so you could get racing seats in the front.
  3. Mar 4, 2013 at 6:44 PM
    #63
    trd_eric
    trd_eric Well-Known Member
    Bolt in for a regular cab and no cutting of stock dash or parts would be sweet
  4. Mar 9, 2013 at 10:31 AM
    #64
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    any status on this?
  5. Jul 30, 2013 at 5:49 PM
    #65
    littlebluetaco
    littlebluetaco I like truck
    Frank
    calgary
    05 speedway blue double cab long box
    lots of stuff and more to come
    old thread revival I'd be interested in a bolt in cage for a DC LB requires no cutting if possible
  6. Jul 30, 2013 at 6:49 PM
    #66
    traxman25
    traxman25 [OP] 4x Innovations Vendor
    Adam
    Platteville Wi
    Too Many!
    I just got a bunch of these in from the machine shop. :cool:
    That said, it is physically impossible to install an internal cage in this cab without trimming the interior panels and cargo pockets behind the back seats. There simply isn't enough room to avoid it in that part of the cab.
  7. Jul 30, 2013 at 7:14 PM
    #67
    ComeAndTakeIt
    ComeAndTakeIt Bob Lob Law
    Longview, TX
    13' White DC TRD Off Road
    Build in the Signature
    subs ... :popcorn:
    what about an external cage?
  8. Jul 30, 2013 at 7:47 PM
    #68
    traxman25
    Adam
    Platteville Wi
    Too Many!
    No exo, sorry. That would cost a mint!
  9. Jul 30, 2013 at 7:48 PM
    #69
    no mods
    no mods Well-Known Member
    cincinnati
    Some stickers
  10. Aug 6, 2013 at 7:31 AM
    #70
    Jholden
    Jholden Well-Known Member
    Hey just wondering if you'll be doing this cage any time soon?
  11. Aug 6, 2013 at 7:37 AM
    #71
    no mods
    cincinnati
    Some stickers
  12. Aug 13, 2013 at 10:35 AM
    #72
    traxman25
    Adam
    Platteville Wi
    Too Many!
    Yep, working on it. Look for it to be available this fall.
  13. Aug 15, 2013 at 6:12 AM
    #73
    littlebluetaco
    Frank
    calgary
  14. Oct 14, 2013 at 12:43 PM
    #74
    traxman25
    Adam
    Platteville Wi
    Too Many!
    Double Cage cage kits are now available! Weld in, Weld It Yourself Bolt In, and Fully Welded Bolt In! For more information check them out here!
  15. Oct 14, 2013 at 5:19 PM
    #75
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Sweeeet!!!
    Will it be necessary to drop the cage to weld top side on the WIY kit?
    Would it be possible to get a kit with an A-pillar that goes through the dash?
  16. Oct 14, 2013 at 5:31 PM
    #76
    traxman25
    Adam
    Platteville Wi
    Too Many!
    Yes to fully weld the weld in kit you'll need to drop the cage down through the floor. This would be the case with any weld in only cage kit that actually fit the cab worth the money the tube costs.
    Yes, we can do though the dash kits. However it would be recommended to only be installed in a truck that is not using the factory dash as a through the dash kit has not been, and will not be, designed to fit with all of the internals of the factory dash.
  17. Oct 14, 2013 at 6:36 PM
    #77
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    You should check out the long travel section..there's quite a few with a through dash kit and fully functioning factory dash
    :popcorn:
  18. Oct 14, 2013 at 6:39 PM
    #78
    MonkeyProof
    SoCal- SGV
    Link isn't working..:pout:
  19. Oct 14, 2013 at 6:40 PM
    #79
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I'm concerned with the A pillar legs. With so many bends would they not just buckle in a roll?
  20. Oct 14, 2013 at 6:41 PM
    #80
    traxman25
    Adam
    Platteville Wi
    Too Many!
    They also were custom built cages. A production through the dash cage is not going to happen.
    I just drove my Tacoma from WI to CA and back with the cage in and it presented no problems. I've been DDing it since we got back, rather than the car, if that tells you anything.
