Any interest in shimms.........
Discussion in 'Suspension' started by chris4x4, Jun 25, 2008.
  1. Jun 25, 2008 at 5:57 PM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    for the '05+ Tacomas? Im thinking of machineing some shims, as I have read that some people have a Truck that does not sit level from side to side. They will be made from Aluminum, and fit on top of the spring pack. :)
  2. Jun 25, 2008 at 6:01 PM
    bauermike
    bauermike Western Alliance
    Tucson, AZ
    08' Prerunner, Radiant Red
    Billet Grill
    Do the Tacomas start to sag in the rear as they get older? I see it every once in a while on the road. I think it looks rediculous.
  3. Jun 25, 2008 at 6:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Any vehicle's springs will sag over time. :)
  4. Jun 25, 2008 at 6:08 PM
    bauermike
    Tucson, AZ
    Billet Grill
    I have seen some bad sagging though. few inches sometimes.
  5. Jun 26, 2008 at 6:17 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Shims? or lift blocks?
    And...mount them ontop the spring pak?
    I'm confused.....:rolleyes:
  6. Jun 26, 2008 at 6:42 AM
    Banchi94
    Banchi94 Well-Known Member
    Ron
    Parker, CO
    2008 Indigo Blue TRD Sport DCSB 4x4
    ToyTec 3" basic lift
    I don't want to speak for chris, but I think he does mean shims. You place these in the rear under the spring pack. At least, that's what the installers did in my truck. Helps keep vibes down, too, I think.
  7. Jun 26, 2008 at 6:51 AM
    Janster
    Jandy
    Lancaster, PA
    Shims & blocks are different.
    Shims are sloped to point the pinion to a certain angle to relive driveline vibrations. - installed under the leaf springs.
    Blocks wouldn't have a slope and would act like a suspension lift mounted 'underneath' the leafs.
  8. Jun 26, 2008 at 7:04 AM
    Banchi94
    Ron
    Parker, CO
    My bad...sorry. Just showing my inexperience for you all to know. :anonymous:
  9. Jun 26, 2008 at 7:21 AM
    Janster
    Jandy
    Lancaster, PA
    No no ...you were right the first time. Shims get installed to help with vibrations and go under the leaf pak.
    Chris mentioned for 'leveling' purposes - and that made me think he was making mini lift blocks.
    Although you could have a combination lift block with a non-90degree edge on it to act as a shim. I was just wondering what he meant....
  10. Jun 26, 2008 at 7:27 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    a lot of guys get a lil overzealous with the hauling and wind up collapsing the leafs:eek:-also you could be looking at a truck that was smakked in an accident and the BODY is what's tweeked....some crap body shops will put a pretty face on a wrecked vehicle but do nothing about releveling unless the driver piks up on it!
