Any of y'all figure out a way to move your backup camera to your cap's third brake light?
Discussion in 'Tonneau Covers, Caps and Shells' started by tacotmac, Mar 6, 2017.
  1. Mar 6, 2017 at 6:04 PM
    tacotmac
    tacotmac [OP] Well-Known Member
    Athens, GA
    '12 DCLB
    Seems like it would be badass to me. I've run across some third brake lights that have cameras built into them in separate systems but I'd like to integrate it into my stock camera and move it up there. The increased height would do wonders for visibility.
    To be specific, my idea is to mount the camera beside or in the middle of the third brake light on my leer 100xr.
    Any ideas would be appreciated.
    TrillTacoma and Geronimo1111 like this.
  2. Mar 6, 2017 at 6:10 PM
    Bishop84
    Bishop84 Well-Known Member
    I think so far the manufacturers are only doing that if you intend to use the truck for a goose neck.
    I love seeing my bumper and I get really close to my garage door with it. A roof camera wouldn't do me much use in any situation.
  3. Mar 6, 2017 at 6:11 PM
    tacotmac
    Athens, GA
    '12 DCLB
    I meant putting it on my caps third brake light. You'd still be able to see the bumper, just probably the whole thing since you would be higher up and further away.
    t.hornstra and redrider736 like this.
  4. Mar 6, 2017 at 6:12 PM
    Bishop84
    Ooooh I missed that. That would be neat with the higher angle. Especially with a fish eye lense.
  5. Mar 6, 2017 at 6:16 PM
    tacotmac
    Athens, GA
    '12 DCLB
    Yeah! I think it would offer great visibility of the back of the truck. I also plan on having a bike rack on the back of the truck a lot of the time so it will block my view from the stock mounting location.
    What I'm thinking would be perfect is if there was a way to do a quick disconnect on the wiring so I could remove the cap still, and then replace the third brake light with one that had a camera in the middle of it or a way to mount one. That or rig up or 3d print a mount location beside the light.
    Geronimo1111 likes this.
  6. Mar 6, 2017 at 6:17 PM
    tacotmac
    Athens, GA
    '12 DCLB
    was hoping someone had already pulled it off!
  7. Mar 6, 2017 at 6:19 PM
    tacotmac
    Athens, GA
    '12 DCLB
  8. Mar 6, 2017 at 7:30 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Have you pulled the lense off to see what it would take to mod it yourself? I doubt the factory camera has enough wiring but it should be easy enough to either splice some in or buy an aftermarket camera and adapt it. You may be able to find an aftermarket light that already has one in it too, such as this cap light that I found doing a quicky Google search- https://www.rearviewsafety.com/rvs-915-rear-view-camera-jason-cap-third-brake-camera.html
  9. Mar 6, 2017 at 7:36 PM
    tacotmac
    Athens, GA
    '12 DCLB
    leer doesnt have on that will fit, so i'm thinking the easiest and least painful thing to do would be to wire something like this up https://www.amazon.com/TOPTIERPRO-T...=sr_1_74?s=car&ie=UTF8&qid=1488855722&sr=1-74 .
    My real question is would it be possible to wire in both cameras and have them on a switch to change between the two. That way, if i take of the cap or one is better for a situation than the other, I could swap between them
  10. Mar 6, 2017 at 7:52 PM
    tacotmac
    Athens, GA
    '12 DCLB
    which the more i think about it, the more i think that yeah, it wouldnt be too hard. I would just need to make a switch box to run both cameras into, then have the output going to the connection to the head unit
  11. Mar 6, 2017 at 9:15 PM
    Bajatacoma
    SC
    Yeah, there's a guy on here who used a multi-position switch from Radio Shack and had multiple cameras that he could bring up on his head unit. I'll see if I can't find the thread.
  12. Mar 6, 2017 at 9:21 PM
    tacotmac
    Athens, GA
    '12 DCLB
    Pretty sure I saw that earlier. Not the clean install I'm thinking about but the same idea kinda.
  13. May 23, 2018 at 2:07 AM
    Geronimo1111
    Geronimo1111 Well-Known Member
    Ventura, Flagstaff & Phoenix
    '07 Silver Streak Mica 2.7L AC
    Ride-Rites LEER 100 XQ Cap Homemade Bedslider Bilsteins
    OP, I want to do the exact same thing as you with our Leer xq100...
    Did you find a 3rd brake light with a camera that fit? Switch box?
    The Jason one looks like a close fit, but hard to tell from pictures...
  14. May 29, 2018 at 7:18 AM
    tacotmac
    Athens, GA
    '12 DCLB
    Hey! Sorry for the delayed response, haven't been working on this project for a while, but your comment got me thinking about it again. I think what I'm going to try to do is use the Pelfreybilt relocation brackets and mount it underneath the third brake light. Seems cheap, reversible, and like not that much trouble other than lengthening the harness to run it up to the top of the cap. I image the bracket will need to be bent some to point the camera down more and that it will likely be that I won't see the bumper anymore, but my bike rack is in the way anyways so I'm not too worried about it.
    Figure it's worth $30 in parts and an afternoon of beer drinking and soldering wires.
    My third brake light is double side taped down to a flat spot in the fiberglass that seems like a perfect place to screw that bracket down underneath the light. I doubt that the light will put off enough glare if its behind the camera to cause much issue, but thats the only problem I can imagine coming from this project.
    Geronimo1111[QUOTED] likes this.
  15. Dec 30, 2018 at 9:58 AM
    shaunsquid
    shaunsquid Member
    Shaun
    Sacramento, CA
    2017 SR5 V6 4X4
    Any luck on this?
  16. Dec 30, 2018 at 11:28 PM
    Geronimo1111
    I haven't gotten any further on the project. Kind of got sidetracked with other stuff, but I like one of the previous poster's mention of a switch box. I think he may have been talking about something like this from radio shack ($19):
    https://www.radioshack.com/products/radioshack-4-way-audio-video-selector-switch
    I like the idea of multiple cameras to a head unit...back up cam up high, one for the hitch and maybe one out the front...
  17. Dec 31, 2018 at 6:00 PM
    Bajatacoma
    SC
  18. Apr 4, 2021 at 7:13 PM
    Sideswipe
    Sideswipe Member
    Jer
    06 Prerunner SR5 Taco
    Little here and there
    Hey I want to do the same thing and came across this thread. Did any of you pull it off?
  19. Oct 7, 2022 at 9:10 AM
    bonan
    bonan New Member
    October seems like a good month to resurrect this thread from the grave. I am in the same boat as OP and looking for a clean solution. Bike rack blocks the factory camera; thinking a birdseye view from the shell would work well. Anyone solve this?
  20. Oct 7, 2022 at 9:33 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Never done it, and just now seeing this thread, but I would think doing something like the anytime front/rear camera mod, and just using the "front" option for the cap mounted camera would do the trick. Then you could have access to those cameras anytime. As for camera choice, use whatever you like best I suppose.
