Any of you 4 banger guys run 235 85s?
Discussion in '4 Cylinder' started by single cab, Apr 15, 2014.
  1. Apr 15, 2014 at 3:50 PM
    single cab
    single cab [OP] Well-Known Member
    upstate ny
    2012 Single cab 4x4 mt
    Im gonna need tires by winter and I hear some people run these. Its not much skinnier them the 245 75s that came stock acorrding to the calculator only 4 percent taller and 4 percent skinnier. Thanks
  2. Apr 15, 2014 at 4:10 PM
    vtmactech
    vtmactech Well-Known Member
    KS
    '11 Reg Cab 4cyl 4x4 MGM
    235/85/16 will be the size I get when I wear the factory sized MT-Rs down. I have a set of LCE headers I need to get around to installing and hope that makes up for the increased diameter. I kinda want the tooter intake spacer but seems a bit hokey on the install side. Wish it was a bit more stable/secure.
  3. Apr 15, 2014 at 4:16 PM
    zacharypaul89
    zacharypaul89 Eat right, be fit, die anyway
    Zach
    Georgia
    2003 TRD 4WD 3.4 V6 Supercharged w/ Locker
    Mine are 265/75/16's which are almost the exact same tire, except .2% shorter and 11.3% wider....so basically the same height, but a little wider. It should be fine.
  4. Apr 15, 2014 at 4:23 PM
    single cab
    upstate ny
    ok awesome i would like to avoid a lift till next set of tires
  5. Apr 15, 2014 at 4:24 PM
    zacharypaul89
    Zach
    Georgia
    Not necessary. I had mine on for a year before I put my 3" lift and had zero issues.
  6. Apr 15, 2014 at 6:54 PM
    single cab
    upstate ny
    any comments about useage? Highway driving or turning sharp?
  7. Apr 15, 2014 at 6:56 PM
    zacharypaul89
    Zach
    Georgia
    Nothing much. A little louder than normal, but nothing like super swampers or anything. No turning issues and no significant decrease in mileage
  8. Jun 19, 2014 at 8:07 AM
    mulishataco13
    mulishataco13 Active Member
    Monrovia
    13 Tacoma
    Daystar leveling kit
    I'm running 235/85/16 Duratracs
  9. Jun 20, 2014 at 12:50 PM
    clcartwr
    clcartwr Member
    So how is the ride with the E rated tires?
  10. Jun 20, 2014 at 1:07 PM
    mulishataco13
    Monrovia
    13 Tacoma
    My truck rides just fine, no complaints.
  11. Jun 21, 2014 at 12:41 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I also went with 235's... but in /60/16 to retain the stock wheel diameter on my 5 lug street Taco.
  12. Jun 27, 2014 at 12:33 AM
    covefrog08
    covefrog08 swollen member
    Vancouver Island- Canada
    08 w/west coast pin-striping
    devil horns, weather tech floor mats, Camo seat cover, window visors, premier deck w/ 6 speakers and sub, checker plate tool box, diff breather relocate, Mag light & Fire Extinguisher behind seat
    i run 235/85/16 beg all-terrains on my 4cyl 4x4 and they are great on and off road. but i did just move to an area that gets lots of snow and they are to narrow for fresh stuff i just sink down. suspension is all stock and no rubbing and i have definitely 3 wheeled it lots. :D
