Any one replace their two-speed wipers on 2009 Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by atea, Jan 4, 2009.
  1. Sep 22, 2009 at 2:30 PM
    #61
    Rickochet
    Rickochet Well-Known Member
    Rick
    Kentucky
    '09 Tacoma Access 2.7 4 x 2
    Added VS Wipers, Cruise Control, DRL, Undercover SE Bed Cover
    Maybe next time at your dealer take a look at a '10 with intermittent wipers and see how they work. If they work backwards like the '09 OEM install I would order the '08 stalk. Also maybe check with your dealer parts dude and see if he can dig up the part # for the '10 OEM install switch. It appears some dealers are hesitant to look up parts if you didn't get them OEM. I had the Rostra cruise switch installed after market and my dealer didn't mind looking up the part # for the $4 plastic cover that went around the switch.
  2. Oct 16, 2009 at 3:12 PM
    #62
    mbeaver
    mbeaver Member
    Richmond, VA
    2010 Tacoma 4X4
    I am going to order the older part and give it a shot. I will let you know.
  3. Oct 16, 2009 at 4:06 PM
    #63
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    When I bought my truck my dealer told me it would cost $3800.00 plus they would need my truck for 7+ days to install DRL's. They informed me that the part #'s for the fuse panel are different and that they would have to order the new panel and wiring harness and re-wire the entire truck.
    Thanks to a write I purchased an $80 relay and jumper harness and installed it myself in 30 minutes.
    To be fair, things like adding the wiper switches, cruise and DRL is something the dealers probably rarely come accross. They would only make repairs to those items on vehicles that already have them installed.
    I'm sure in my case they just look up the 2 parts #'s and see they are different, what's different they don't know, so they assume the entire panel had to be changed.
    Shawn
  4. Oct 17, 2009 at 3:24 AM
    #64
    sammy
    sammy Well-Known Member
    Maryland
    '09 4X4 Reg. Cab, Debadged Barcelona Red
    seat belt chime inter. wipers debadged canvas top (Bestop)
    I put the 09 parts number in mine. I don't understand why everybody says it works backwards. Maybe it works opposite than the ones they are used to. It makes sense to me. Rotate it up and the speed goes up. Down and the speed goes down
  5. Oct 17, 2009 at 9:06 AM
    #65
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I installed switch #84652-04141 in my '09 base a while back. Nothing is "backwards" at all. It functions just like the variable intermitten wipers on my wife's '04 Sienna do.
  6. Oct 17, 2009 at 9:36 AM
    #66
    Rickochet
    Rick
    Kentucky
    Same one I used in my '09. There is an earlier post about someone ordering the '09 part which is # 84652-02610 and the intermittant function is backwards from the #84652-04141.
  7. Oct 17, 2009 at 10:30 AM
    #67
    Rickochet
    Rick
    Kentucky
    Using the #84652-04141 in the '09 as you move the knob down the speed goes up so is is the opposite of yours. I really don't think it makes a difference since you leave the interval setting in a favorite setting and activate it by pulling the lever down to the first click. I leave my setting on the longest interval and change as needed.
    Perhaps the '09 part with the shortest interval at the top is backwards from the graphics on the handle. Here is picture of my '09 with the #84652-04141 handle. The interval marker is set at the top and is set at the longest interval.
  8. Oct 17, 2009 at 3:21 PM
    #68
    newfie8
    newfie8 Well-Known Member
    newfoundland
    09 tacoma
    Tinted windows all around. Fog lights. Intermittent wiper switch. Skid plate. Extra D rings. Grillcraft. Color matched grill. Hella 500ff HID behind grillcraft. Rcbs204 Lighting. 5100's up front. 265/75/16 Duratracs.Firestone riderites. Bora Wheel spacers. Tinted tails. De badged. Blacked out rims.
    Just installed part# 84652-04141 in my tacoma and it works fine and worth every cent! Got mine from 1st toyota parts to the door for $160. Had to pay $20 dollar custom fee at the border where i'm from Canada. A far cry from toyota i priced it there and it was a wopping $245 plus tax!! Hope this helps somebody.
  9. Oct 21, 2009 at 4:00 PM
    #69
    mbeaver
    mbeaver Member
    Richmond, VA
    2010 Tacoma 4X4
    I put 84652-04141 in a 2010 Toyota Tacoma Crew Cab 4X4. Works well and the interval knob works correctly.:D
  10. Oct 22, 2009 at 12:43 PM
    #70
    barnyard
    barnyard Member
    Pennsylvania
    2010 Tacoma
    Great, good to hear. Thanks! Did you get it from a dealer or from an on-line source?
  11. Oct 22, 2009 at 6:24 PM
    #71
    mbeaver
    mbeaver Member
    Richmond, VA
    2010 Tacoma 4X4
    I got them from 1sttoyotaparts.com. $106.79
  12. Oct 22, 2009 at 6:25 PM
    #72
    mbeaver
    mbeaver Member
    Richmond, VA
    2010 Tacoma 4X4
    Yep.
  13. Nov 19, 2009 at 1:35 PM
    #73
    irelandr
    irelandr New Member
    St Louis
    2010 Tacoma
    Intermittent Wipers
    I just completed this on my 2010 and it works perfectly, took about 10 minutes and the controls are not backwards. I used 84652-04141 from 1stToyotaParts.
    Thanks for the info on doing this!!
  14. Jul 10, 2010 at 7:32 PM
    #74
    skipper
    skipper Member
    reg cab
    followed the instructions below/the new wiper switch arm was 110.00. I love it. My local dealer said it would not work!! But no problem, it took about ten min. to install. Best 110 I ever spent. thanks
  15. Jul 10, 2010 at 7:40 PM
    #75
    Rickochet
    Rick
    Kentucky
    The dealer will always tell you it won't work and they won't do it. I have done the wipers, DRL and cruise on my '09 and they have worked well for over a year.
  16. Jul 10, 2010 at 8:47 PM
    #76
    Nathan
    Nathan Well-Known Member
    Nathan
    Frederick County, MD
    2010 5 lug single cab
    you can get them used on ebay for $75
    #76
  17. Aug 19, 2011 at 1:49 PM
    #77
    Ironwings
    Ironwings Member
    Pete
    PA
    2011 Double Cab 4x4
    side steps, bug deflector
    I have an 11 Dbl cab with the same 2 speed wiper switch, I would imagine I can order an intermitten from the dealer as I am going to find out.
  18. Aug 19, 2011 at 2:11 PM
    #78
    Nathan
    Nathan
    I got a used one off ebay, looks and works just fine.
    #78
  19. Oct 15, 2011 at 5:40 PM
    #79
    Humpty Dumpty
    Humpty Dumpty Member
    Kingston, Ontario, Canada
    '11 4X2 2.7L 5spd BASE Barcelona red
    Trifecta Tonneau cover, Class IV hitch, Always-on acc. outlet, OEM delay wipers, Keyless entry/remote start
    For my 2011, I ordered the '09-'11 part number from 1sttoyotaparts shipped to Ontario for $125 and it works great. Thanks to all the info on this board! They must have fixed the markings because mine acts as I would expect and is the same as the pic a few posts back for the older part number.
    Now for cruise...
  20. Jul 12, 2012 at 6:10 PM
    #80
    dajabr
    dajabr Flyin' Singin' Writin' Weirdo Freak
    Dan
    Charleston, WV
    Convenience Pkg
    Installed. Happy with the INtermittent BUT, was expecting the High speed wiping to be faster than the high speed on the plain ole two speed unit. Anybody notice faster high speed, and if so what was your part number?
