Any opinions of the All Pro CV boots?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Nick_Taco, Jul 15, 2011.
  1. Jul 15, 2011 at 2:58 PM
    Nick_Taco
    Nick_Taco [OP] Well-Known Member
    Nick
    Maryland
    2014 DCSB OR 4x4 Auto
    Just put on my diff drop and i still have the inner CV boots touching :mad:
    I know just from the look that they will be tearing soon just like every other time so now I'm looking for any other solution.
    Anyone try these? I searched but it's just people recommending to look at them and no real experiences.
    https://www.allprooffroad.com/9504frontsuspension/282
    My front set up is Eibachs and Bilstein 5100s set at 0.
  2. Jul 15, 2011 at 3:40 PM
    Nick_Taco
    Nick
    Maryland
    Another question, is it possible to stretch the boots further on the axle to bring the ribs further apart?
  3. Jul 15, 2011 at 3:55 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    Seems like a good idea. Im always worrying about my boots. I haven't heard any reviews about them though. It seems like they should have clamps on both sides but I guess it's not necessary.
  4. Jul 15, 2011 at 4:08 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    33's,armor,crawler,dents, ect
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    You can stretch out your stock boots. Worth a try because new boots are a pain in the dick to install.
  5. Jul 15, 2011 at 4:14 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    How new is your suspension? Maybe let it settle a bit and then do the boot slide mod
  6. Jul 15, 2011 at 5:26 PM
    Nick_Taco
    Nick
    Maryland
    Been on since last October so I think it's settled for the most part.
  7. Jul 15, 2011 at 8:35 PM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    the allpro boots are for outer boots only.
  8. Jul 15, 2011 at 8:59 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    This ^
    Just get some reman axles from autozone/advance auto/nap/whatever with a lifetime warranty. If your boots rip again or you break an axle you just head back to the auto parts store and get another axle for free.
  9. Jul 15, 2011 at 10:32 PM
    Nick_Taco
    Nick
    Maryland
    crap didnt see that :eek:
  10. Jul 15, 2011 at 10:33 PM
    Nick_Taco
    Nick
    Maryland
    thats what ive been having to do for the last few months but its getting to be a huge pain in the ass :mad:
  11. Jul 15, 2011 at 10:35 PM
    kmok
    Kyle
    Columbus, Ohio
    How often are you ripping your boots?
  12. Jul 15, 2011 at 10:39 PM
    kmok
    Kyle
    Columbus, Ohio
    Maybe these will work? :notsure:
  13. Jul 15, 2011 at 10:45 PM
    Nick_Taco
    Nick
    Maryland
    I've seen those on that site before. The site closed down and I can't find those boots anywhere else. :mad:
  14. Jul 15, 2011 at 10:59 PM
    kmok
    Kyle
    Columbus, Ohio
    Do you know how the inner part of your cv axle is shaped? Is it circular or a circular triangle shape?
    Edit:
    This part
  15. Jul 15, 2011 at 11:04 PM
    Nick_Taco
    Nick
    Maryland
    pretty sure its just circular but i'll check for sure tomorrow
  16. Jul 15, 2011 at 11:08 PM
    kmok
    Kyle
    Columbus, Ohio
    If they're circular then these should work, the outers would work regardless.
    Inner
    Outer
  17. Jul 15, 2011 at 11:22 PM
    Nick_Taco
    Nick
    Maryland
    They slip over the current boots?
  18. Jul 15, 2011 at 11:27 PM
    kmok
    Kyle
    Columbus, Ohio
    No, they're high angle replacement cv boots
  19. Jul 15, 2011 at 11:39 PM
    Nick_Taco
    Nick
    Maryland
    I may try these.
    Just noticed you have a similar setup to me, having this problem? What are you doing about it? Right now after I replace both axles I'll have 3 or 4 torn wide open after about a month.
  20. Jul 15, 2011 at 11:57 PM
    kmok
    Kyle
    Columbus, Ohio
    My boots tore probably 4-5 months after I installed my lift and I drove around on them for awhile. To fix the cv axles I bought the boots in the link I posted to swap out the boots but the inner boots didn't work for my cv axle. I now am using autozone reman axles. I've had the new axles on for maybe a month. The passenger side split at the seams so I think it was just a defective boot, but the diff seal was leaking anyways so I would have had to pull that axle out again anyways. Hopefully the boots on these autozone cv axles hold up.
