Any options other than replacing engine for $11k?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xb4r7x, Jun 26, 2023.
  1. Jun 29, 2023 at 8:59 AM
    #121
    xb4r7x
    xb4r7x [OP] Well-Known Member
    Bart
    2017 TRD Sport
    Ditch Lights
    I'm definitely having it towed elsewhere for a second opinion. Waiting on a few phone calls still.
    ppat4 and Junkhead like this.
  2. Jun 29, 2023 at 9:00 AM
    #122
    lbhsbz
    lbhsbz Well-Known Member
    These prices are nuts. Last I checked, a new short block was about $3K. Send the heads to a machine shop to get gone through, should be under $1000, then 20ish hours of labor at a good Indy shop.
    you should be able to get out the door for under $7K
    Toyko Joe likes this.
  3. Jun 29, 2023 at 9:03 AM
    #123
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
    Am I the only one thinking LS swap now?
    TheDanimal likes this.
  4. Jun 29, 2023 at 9:09 AM
    #124
    Firn
    Firn Well-Known Member
    White OR
    I think the point is that with an $11,000 bill staring you in the face its probably worth a second opinion, and through that a deeper investigation into what is wrong. To his point, "metal in the oil" is NOT a diagnosis in itself. Yes, sure, actual pieces of metal indicates something major wrong but the tech could have seen a glimmer of sheen and called it "metal". If you didn't see the oil itself I would be very hesitant to use that as the only reason to drop a LOT of money. Even if there is metal it could be something that can be repaired, as opposed to needing an entirely new engine.
    I have to admit, for the at most $500 it would take to get a second opinion I sure would be doing that. And no, you don't need to tear it down. Things like compression checks and those inspection cameras can do a lot without tearing the engine apart.
    Not sure if you said so already, but does it turn over, but just won't start? Or does it not turn over at all? A bad bearing that prevents the engine from starting would need to be completely seized and thus the engine won't spin over. Even if it has a bad bearing, if it spins over it should start and run as it tears the insides up (which doesn't matter in your case). If it turns over but won't start I would expect something else to be wrong.
    joba27n and Toy_Runner like this.
  5. Jun 29, 2023 at 9:37 AM
    #125
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    :censored:,:censored: & :censored:...
    :sorry:
    HisDad likes this.
  6. Jun 29, 2023 at 10:40 AM
    #126
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    It may not be as much of a fluke as you think. I haven’t heard about many bottom end failures, but the mysterious “burnt valve,” “P11EE” issues are not unheard of at low miles in the 3rd gen unfortunately.
    https://www.tacomaworld.com/threads/2gr-fks-engine-problem-failure.774579/
    In fact I didn’t see any mention of engine codes in this thread; I’m assuming you or the tech that diagnosed your truck checked for them?
  7. Jun 29, 2023 at 11:02 AM
    #127
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    I was wondering how much the person who sold the car to Carvana and how much they might have known about this.
    I-Give-Up and thomasburk like this.
  8. Jun 29, 2023 at 11:04 AM
    #128
    xb4r7x
    Bart
    2017 TRD Sport
    Ditch Lights
    I've already stated a few times in this thread I'm taking it for a second opinion, just waiting on phone calls from some other shops. It does start, briefly, and then stalls.
    Toy_Runner and Firn[QUOTED] like this.
  9. Jun 29, 2023 at 11:07 AM
    #129
    xb4r7x
    Bart
    2017 TRD Sport
    Ditch Lights
    It only had 4500 miles on it when I bought it, and had been through multiple owners. Our best guesses based on the info we have, someone bought it, owned it for 2 months, it was repossessed by the bank, sold again at auction... carvana bought it and sold it to me.
    TacoSR523 likes this.
  10. Jun 29, 2023 at 12:36 PM
    #130
    .45 Calibear
    .45 Calibear Well-Known Member
    Mount Diablo
    17 TRD Off Road - REI Crawler
    Broverlandering kinds
    I feel your pain. I have a 2017 with burnt exhaust valve at 79k miles, and was quoted $7k for the work at an independent shop. Good luck with everything man hope you get it all resolved.
    TacoSR523, cryptolime and Junkhead like this.
  11. Jun 29, 2023 at 12:40 PM
    #131
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    Tundra V8! Ian Johnson did it into a 2nd gen on his show "4 Wheeler"
  12. Jun 29, 2023 at 12:42 PM
    #132
    xb4r7x
    Bart
    2017 TRD Sport
    Ditch Lights
    Yeah, nothing they can do.
  13. Jun 29, 2023 at 12:42 PM
    #133
    xb4r7x
    Bart
    2017 TRD Sport
    Ditch Lights
    Ugh. Thanks. Same to you.
  14. Jun 29, 2023 at 12:46 PM
    #134
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    No codes?
  15. Jun 29, 2023 at 1:33 PM
    #135
    nightcrawler
    nightcrawler Well-Known Member
    ‘17pro
  16. Jun 29, 2023 at 3:14 PM
    #136
    HisDad
    Texas at last
    Repossessed vehicles can be risky. People who aren't responsible enough to make payments are often irresponsible in general. They may abuse the vehicle or just not maintain it.
  17. Jun 29, 2023 at 4:16 PM
    #137
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Mere curiosity but what bikes do you work on/enjoy?
  18. Jun 29, 2023 at 4:23 PM
    #138
    ABA180
    East Bridgewater MA
    Second this, though we knew the money was en route we used a credit card for siding on the house to refinance our rate/cash out some equity. Did the job, got the refi, fully paid the card.
    danny15l likes this.
  19. Jun 29, 2023 at 6:40 PM
    #139
    Toyko Joe
    Toyko Joe Here for the pictures
    Do slimy dealers use this opportunity to up their used car inventory? o_O
    Sell another car to you because you can’t swallow a $11,000 repair; for only 36 more payments you could drive a newer car with only a slightly higher payment?:confused:
  20. Jun 29, 2023 at 6:48 PM
    #140
    ABA180
    East Bridgewater MA
    IDK what book time on this job is but by way of comparison..
    My 2010 single cab had the frame replaced in April-July 2021. I believe it books around 80 hours total (2 person job taking about a week). Total cost just of the job was 12-12.5K from my recollection.
