Any PC Builders Out There?
Discussion in 'Technology' started by Tacoma_SR5Pro, Nov 19, 2017.
  1. Jan 15, 2025 at 9:19 AM
    #6101
    MGMDesertTaco
    Well, my build list in Neweggs cart is looking dismal. I keep getting out of stock and backorder notifications. :mad: I suppose there's a rush on components to upgrade before the new 50 series cards drop in 2 weeks.
  2. Jan 15, 2025 at 9:21 AM
    #6102
    Kwikvette
    Fresno County
    4 run, 2 don't
    What kind of build?
    DDR5 mobo's and ram have dropped quite a bit over the last year, along with m.2 storage
  3. Jan 15, 2025 at 9:34 AM
    #6103
    MGMDesertTaco
    Ryzen 7 7800x3d was out of stock so changed to Ryzen 7 9800x3d/MSI Mag x870 Tomahawk mobo combo (9800x3d out of stock this morning/can still buy motherboard)
    Corsair 4000d case (probably a little tight for the new 50 series anyway)
    These are still in stock...
    Corsair 1000w-1200w psu
    NZXT Kraken Elite 360 cooler
    G SKill ddr5 pc5 51200 64gb
    Soundblaster ae-5
    Samsung 990 pro 2tb
    5080 :fingerscrossed:
  4. Jan 15, 2025 at 9:36 AM
    #6104
    Kwikvette
    Fresno County
    4 run, 2 don't
    Interesting, haven't seen a soundcard used in years
    What kind of speakers or cans are you going to run?
  5. Jan 15, 2025 at 9:41 AM
    #6105
    MGMDesertTaco
    Not sure yet. I might try the on board audio first. I still have my Logitech z5500s, but I need to do a little more research to see if I can still make those work.
  6. Jan 15, 2025 at 9:47 AM
    #6106
    Kwikvette
    Fresno County
    4 run, 2 don't
    I used to have those speakers
    You're wasting your money buying a soundcard with a Sabre DAC only to completely disregard it by having your Logitech use its own DAC
    You pay money for a good DAC to run analog out of it
    oldgreg likes this.
  7. Jan 15, 2025 at 10:12 AM
    #6107
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    Or into it.. :rockband:
    I'd dump the soundblaster, those things are flakey af. It's not doing you any favors to help re-use the logitechs either.
  8. Jan 15, 2025 at 10:16 AM
    #6108
    Kwikvette
    Fresno County
    4 run, 2 don't
    "Into it" would only mean a digital source for the DAC which is your computer already
    I didn't look up that sound card to see if it had any other digital inputs but I can't imagine him running an SACD or similar to his soundcard
    A DAC only works to convert a digital signal to an analog one and you normally pay a premium for better processing IE limited to no artificial distortion etc
  9. Jan 15, 2025 at 10:39 AM
    #6109
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    I use a focusrite scarlett as a DAC for my monitors , and for input from guitar/microphones.
    I imagine that old logitech needs a digital s connection or optical. Ain't seen one of dem in a while.
  10. Jan 15, 2025 at 10:47 AM
    #6110
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    That motherboard has a SPDIF out.
    PhoS[QUOTED] likes this.
  11. Jan 15, 2025 at 10:47 AM
    #6111
    Kwikvette
    Fresno County
    4 run, 2 don't
    I don't know if we're misunderstanding each other.
    A DAC is unnecessary especially if he has a speaker system with a built-in DAC.
    It is only beneficial to purchase a soundcard with a quality DAC if you're going to utilize its analog output.
    You mentioned using analog in though - there are a plethora of options for an analog in that do not warrant a premium DAC (wrong tool for the job).
    So really, in your situation you are actually using the DAC for its analog out, but also taking advantage of its analog input. Keep in mind your DAC itself has nothing to do with helping the quality of your analog input.
    There are many motherboards even that allow the use of an output to be used as an input as well which he could take advantage of.
    The Z5500S has digital inputs though (two of them) and you can change the source material on the controller itself.
  12. Jan 15, 2025 at 10:51 AM
    #6112
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Do not waste money on a sound card. For 90% of people, on board audio is good enough. It looks like the Z5500s support a TosLink optical connection? If so, check for motherboards that have one, it'll be called SPDIF. It's a digital standard so there's no real chance of interference from the motherboard anyway, so if you use that connection a sound card is a complete waste of money.
    As an aside, sound cards died because modern motherboards use a gap in the motherboard substrate to isolate the on board audio components. Along with better filters and DACs onboard, this eliminated the issues with on board audio for most people. However, some audiophiles need to drive high impedance headphones and want a crazy high sampling rate. For that use, sound cards are still dead, they were replaced by USB external Digital to Audio converters. By going to an external DAC, there's even better separation between the motherboard and analogue audio source and the power for the more expensive DACs can even come from a separate outlet or be filtered by larger components than can fit on a sound card.
  13. Jan 15, 2025 at 10:52 AM
    #6113
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    Ouch, I knew it was old but I didn't realize it was that old. Now I feel kind of stupid even spending anything on it, Even though I hate throwing stuff away
  14. Jan 15, 2025 at 10:53 AM
    #6114
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    They're still common on mid to high end motherboards. Using a sound bar or mid range pair of speakers with their own DAC has kept the TosLink alive.
  15. Jan 15, 2025 at 10:55 AM
    #6115
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    IMHO don't waste your money on a surround speaker system. If you want great sound, go to either a set of higher end gaming headphones with good reviews like the Steelseries Arctis Nova Pro's or jump up to a decent external DAC and a common set of headphones with the Sennheiser logo on them.
    If you need speakers, grab something stereo from Polk, Edifier, etc. It'll sound great and you won't miss the surround in most games. If you do, again, use headphones.
  16. Jan 15, 2025 at 10:56 AM
    #6116
    Kwikvette
    Fresno County
    4 run, 2 don't
    He's talking about an old laptop...
    But yes agree, I've got those cans and love them
    drewskie and Sterdog[QUOTED] like this.
  17. Jan 15, 2025 at 11:02 AM
    #6117
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    I use the SteelSeries Arctis Nova 7P for the PS5, great headphones. Even the cheap Logitechs I use for my PC sound decent. I have 2 pairs of AudioTechnicas, one for bluetooth and one analog. I share my music with noone.
  18. Jan 15, 2025 at 11:10 AM
    #6118
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    Were not.
  19. Jan 15, 2025 at 11:13 AM
    #6119
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    Didnt see mobo linked, that's convenient though.
  20. Jan 15, 2025 at 11:20 AM
    #6120
    Kwikvette
    Fresno County
    4 run, 2 don't
    MANY (even cheap mobo's) seem to include a digital out as standard.
    Really convenient for sure.
    Even my 17 year old PC has a digital out :rofl::anonymous:
