any pics, info or links to clearance?
Discussion in 'Wheels & Tires' started by chad68, Jan 8, 2008.
  1. Jan 8, 2008 at 6:30 PM
    chad68
    chad68 [OP] Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    Anybody have any pics of '05+ taco with 3" lift and 33" tires?
    Specifically what I'm looking for is pics with the front muflap removed and pics of the front wheel taken at differnt angles (straight, full lock and in between).
    In other words I'm trying to find out how close they are to rubbung in the back (on the frame), when wheels are turned at the point the creates the least amount of clearnce to the frame behined the tire.
    Need to know what the wheel offset is too.
    I know pretty much everybody at least rubs the plastic offroading but with the suspension fully compressed, is it going to hit the frame?
    Trying to determin how much if any of the frame would have to be modified to allow a 285/33/16 tires on 8" 4.0 backspaced wheel, to clear the frame with the susupension fully compressed.
  2. Jan 8, 2008 at 8:20 PM
    L_Jackson
    L_Jackson Well-Known Member
    Houston, TX
    2007 Black Sand Pearl PreRunner Acce
    Tinted Windows, Tow Hitch, 3" Toytec Lift, American Racing Outlaw II Wheels, Cooper Discoverer 33's, Aries Bull Bar w/ (2) 5" Lights, Nerf Bars, Fog Lights as DTR Lights, Roll Bar w/ (4) 5" Lights, Sony Speakers, 2 Extra Tie Downs
    if you look at my pics, you should see some diff. angles and my flaps are gone. not close up pics tho.
    i rubbed the plastic with no load and no off roading, the plastic nob that hangs down up front and inside of the wheel well. i'll take pics of what i'm talking about tomorrow. that is easy to cut away.
    i think i have a 4" offset with my american racing outlaw II rims, but you can look up the specs to make sure.
    i don't think you should have to modify the frame at all.
    like i said, i'll take pics tomorrow, camera takes crap pics at night.
  3. Jan 8, 2008 at 9:23 PM
    L_Jackson
    Houston, TX
    i was wrong, my gallery sux for no mud flap pics.
    these actually showed up at night, i labeled them to show what i was talking about, hope they help. no load at all.
    let me know if i can do something else to help. i can even PM you with my number if you need to call.
    i have more than 5 pics so i'll put them in 2 post.
  4. Jan 8, 2008 at 9:27 PM
    L_Jackson
    Houston, TX
    more pics
  5. Jan 8, 2008 at 11:06 PM
    chad68
    Chad
    Thanks for the pics Jackson, that's pretty much exactlly what i was looking for. I believe your wheels are 4.5" backspace somebody else and myself looked it up before, so I would be about 1/2" closer than that. WOW talk about cuting things close LOL
  6. Jan 8, 2008 at 11:54 PM
    chad68
    Chad
    In the pic far left it says bull bar and front with arrows. Is that correct or is that your nerf bars? I thought those welded body mount things that come off of the frame where only on the back side of the wheel, near the cab?
  7. Jan 9, 2008 at 7:00 AM
    L_Jackson
    Houston, TX
    sorry dude!!!!!
    i got drunk last night and thought "i wonder if those pics will show up even tho it's dark" and they did. when i posted those pics my thinker was not at 100% :rolleyes:
    your right, the arrow is wrong and that is the nerf bar
  8. Jan 9, 2008 at 7:01 AM
    L_Jackson
    Houston, TX
    yeah, i knew a couple people looked 'em up before, i think you and jedi, if yours half 1/2" less back spacing it will be VERY close
  9. Jan 10, 2008 at 1:12 AM
    chad68
    Chad
    A question about that pic you have of the clearance from the body/frame mount to the back of the tire with the wheel tuned.
    From that angle of that pic, it's hard to see exactlly how much clearance you have between the tire and body mount.
    Would you says it's about 1/2"? And or do you think with yours wheels turned at that angle, would clear the body/frame mount, if your suspension was fully compressed? Like if you were to compress your suspension to the point that the mount would be at the centerline of your hubs?
    I'm almost positive I will need to get creative with a grinder and a big ass hammer. lol.
  10. Jan 10, 2008 at 1:24 AM
    chad68
    Chad
    Ok first lets see if it will let me upload this pic. Ok it worked but you will need to click and enlarge it to see my art work LOL.
    Ok what I was thinking about doing is grinding a 45 degree chamfer indiacted by the blue line, back to about the center line of the body mount bolt/bushing, which is about half the length of the mount (may not even need to go back that far with my offset). Grind that 45 degree chamfer until it grinds away all the weld, to the point to where you can start to see the first hint of daylight, where the two halves were once welded together.
    Then grind away the area hilighted in red. Then beat the top half of the body mount into submission, until it gets bent back and lines up with the red line. Then would be a good time to add a weld bead to it too.
    OR
    Just buy 275/70/16 tires:(:mad::D:(
  11. Jan 13, 2008 at 4:32 PM
    L_Jackson
    Houston, TX
    sorry for the late reply, spent a couple days in san antonio....
    it is CLOSE... no load, not even anyone in the truck, it is only about 1/2" clearence :eek:
  12. May 8, 2008 at 2:36 AM
    jtaco
    jtaco Well-Known Member
    07,trdOR,DC,4x4,v6,saw2.5s,OMEdakars,LRarms
    saw2.5s,AEMshortair,skyjackershocks,LRa-arms,OME dakars,Alpine,JL audio 6x9 3 way in front doors
    i thought less backspacing meant better clearance?
    ok by readin this, am i going to have to do some trimming in front and back with 3 " lift and diff drops on my 05 taco acc cab 4x4 if i want to add rims with -11 offset , 4" backspaceing, and 275/70/16 or 285/75/16 tires? Or rims with 0 offset with 4.5" backspacing?
    i know my eyes arent playin tricks on me. i see these wide ass tires on older model tacomas all over the place. much wider then 285.
