any power loss with a 2.5 lift runnin 32a/t's?
Discussion in '4 Cylinder' started by tc98tacoma, Nov 5, 2010.
  1. Nov 5, 2010 at 4:09 PM
    tc98tacoma
    tc98tacoma [OP] Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    and also gas milage
  2. Nov 11, 2010 at 7:47 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    Power loss on my 2.7 4x4 2010 model is noticable on 32s.. I just regeared and the power greatly increased. 4.88 gears are a must. I have CAI, headers, catback exhaust, but the gears give it way more power than anything else.
  3. Nov 11, 2010 at 7:49 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Larger tires will always result in power loss and mileage loss. You can't beat physics. Whether or not it's "too much" is up to you.
    Personally, I felt my 2nd gen was overly peppy at the stock wheel size. With 33s it feels just right to me.
  4. Nov 11, 2010 at 8:34 PM
    tc98tacoma
    Nik
    San Antonio, Texas
    98tacoma4x4
    espek was it a big power loss or somethin you coulda delt with that wasnt too bad??
    im thinkin i might just go with 31's just 12.50 inches wide
  5. Nov 11, 2010 at 8:36 PM
    tc98tacoma
    Nik
    San Antonio, Texas
    98tacoma4x4
    i just look at your mods and your running the same daystar lift ima get in the next couple of weeks... how do you like it? is there anything not to great about it
    do you have the aal in the rear or the block one
  6. Nov 11, 2010 at 9:35 PM
    especk
    Erik
    Redding, CA
    tc, power loss was not too bad until u go offroad rock crawlin or go up some steep hills (like up to tahoe throught the Sierras gotta down shift qhite a bit). It bogs down in mud and snow quite a bit too with 32s.
    Daystar 2.5" looks great. It rides a little stiff and doesnt flex too great tho. I got 2" block in rear.
  7. Nov 12, 2010 at 3:57 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    4.88 with 32's :eek:
    That puts you at roughly 2905 RPM at 70 MPH. For 32's I think 4.88 are very excessive! Maybe a 4.30 and 4.56 tops.
    70 MPH .81 Overdrive ratio
    4.10 ~ 2440
    4.30 ~ 2560
    4.56 ~ 2715
    Mind you as well I input 32" not what 265/75/16 usually measure out to which is about 31.5-32ish. Its also not just the diameter difference that you lose mileage and power on its the width as well. The wider the more friction which means more power needed which results in more fuel used.
  8. Nov 12, 2010 at 4:12 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    according to my gps, 32's (265/75/16) actualy corrected my speedo
  9. Nov 12, 2010 at 4:15 PM
    08pretaco
    az
    My 33.10 are so so so damn close also! I watch the road mile marker and my odometer and its so so damn close its weird!
  10. Nov 13, 2010 at 5:23 PM
    tc98tacoma
    Nik
    San Antonio, Texas
    98tacoma4x4
    265/75/16 sounds good to me right now
    thanks alot guys
  11. Nov 14, 2010 at 9:44 AM
    especk
    Erik
    Redding, CA
    ya im just below 3K on the RPMs at 70mph with the 4.88s. Not too bad since I dont do a whole lot of highway miles - and when I do, it is fine. I'm glad I didnt go with anything less than 4.88s - it wouldnt have been worth it. Plus my next set of tires are gonna be atleast 33s so that'll help too.
  12. Nov 15, 2010 at 8:25 AM
    tc98tacoma
    Nik
    San Antonio, Texas
    98tacoma4x4
    those 4.88s seem too big i like to cruise at 80 and its right under 3k lol
    took the truck past 115 this weekend
  13. Nov 15, 2010 at 8:32 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    x2 on the excessive gearing!
    I'll be sticking with 265's rather than going to 285's for mpg purposes.
  14. Nov 15, 2010 at 10:12 PM
    tc98tacoma
    Nik
    San Antonio, Texas
    98tacoma4x4
    espek im going to purchase the lift you currently have do you think thats a good starter lift cuz i mainly drive on the road but when i do go offroad i eant it to perform pretty good for the price off the lift would you say it was definitely worth it?do you kno any parts that will help smooth the ride abit too??
  15. Nov 16, 2010 at 8:49 AM
    especk
    Erik
    Redding, CA
  16. Dec 1, 2010 at 9:33 PM
    JLaScala
    JLaScala Super White is gonna treat you right.
    Snohomish Washington
    2010 TRD Sport 4x4 long bed crew cab.
    Secondary air filter removal, K&N drop in, Removed front mud flaps, Toyota all weather matts, skid plate, bug guard. Bilstein 5100's all around fronts set at 2.5", OME add a leaf, Goodyear Wrangler Authority 265/70/17, stubby 6.5" antenna, smoked tail lights, blacked out badges.
    265/75 16 worked great for me. A little power loss but not much. Same with fuel economy.
  17. Dec 2, 2010 at 10:52 AM
    08pretaco
    az
    for the second gen our overdrive is .81 right? or is it .85? I cant ever remember
