Any rear lift from just replacing stock shocks with 5100s?
Discussion in '3rd Gen. Tacomas (2016+)' started by CristiaanC, Dec 13, 2018.
  1. Dec 13, 2018 at 6:16 AM
    CristiaanC
    CristiaanC [OP] Well-Known Member
    Austin, TX
    2017 Inferno 4x4 SR5 DCSB
    King 2.5 Coilovers, SPC UCAs, OME Nitros, Deaver Springs, SCS SR8s. Hercules TerraTrac M/T
    My brother recently got his 2019 Tacoma TRD-OR, DCSB. I've told him about TacomaWorld and he'll be joining soon; he hasn't gotten around to it. At any rate, he just purchased 5100s for the front and rear as well as Eibach coils, and I'll be helping him with the install. I was curious what the lift would be in the rear if he did not install an AAL in the rear. Would there be any difference in lift whatsoever with the new shocks only? I know there have been hundreds of threads on the 5100s, just didn't happen to find one where that question is answered. Thanks.
  2. Dec 13, 2018 at 6:20 AM
    DLRIII
    DLRIII Well-Known Member
    David
    Baton Rouge
    2018 Quicksand SR5 DCSB V6
    I have always read that they will not lift the rear at all if you only replace the shocks. He needs an aal probably to compensate for the front lift
  3. Dec 13, 2018 at 6:24 AM
    CristiaanC
    Austin, TX
    Yea, that's what I figured; just wanted to make sure. The AAL looks like a pain to install.
  4. Dec 13, 2018 at 6:26 AM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    Rear shocks do not provide lift.
  5. Dec 13, 2018 at 6:29 AM
    DLRIII
    David
    Baton Rouge
    I'm installing one on mine this weekend, it really does not look that hard man and I have nothing but amateur driveway mechanic experience. Here's the video I'm following for it
    https://youtu.be/Eq9nv_3vU4Y
  6. Dec 13, 2018 at 6:42 AM
    CristiaanC
    Austin, TX
    Great vid, thanks man. Looks fairly straight forward.
    DLRIII likes this.
  7. Dec 13, 2018 at 2:01 PM
    Sapnjack
    Sapnjack Well-Known Member
    Daniel
    Phoenix AZ
    2016 TRD-OffRoad
    Bilstein 6112/5160 Dakar EL096R Leaf Springs KO2 265/75/16 Tires OCF Rock Sliders Cali-Raised Hidden Lightbar Diamonback Cover HD KB VooDoo Premium Rack CVT Tent ARB Awning
    Shocks don’t raise the rear, but in general the rear is higher than the front. So if you want to level things out you could probably just raise the front by 1 inch.
    You’d have to measure from the middle of the wheel to the fender for the front and back though to see the actual difference
  8. Dec 13, 2018 at 2:06 PM
    Sapnjack
    Daniel
    Phoenix AZ
    2016 TRD-OffRoad
  9. Dec 13, 2018 at 2:08 PM
    Gunshot-6A
    Gunshot-6A Not A Fed
    Conner
    Salt Lake City
    2015 TRD Offroad
    Here's a good vid for all the front suspension as well!
    https://www.youtube.com/watch?v=bbsTJgb6S_c
  10. Dec 13, 2018 at 2:09 PM
    420taco
    420taco Well-Known Member
    Justin
    PA
    Just make sure to have clamps for the existing leaf packs when you unbolt them.
  11. Dec 13, 2018 at 3:41 PM
    DansSr5
    DansSr5 Well-Known Member
    2016 Sr5 double cab silver 4x4
    P265/75/16 Destination AT stock wheels 12v socket bed pocket install diy Truck bed beer bottle opener No drill hidden/uv5r ham radio installed GoPro hero 5 session Center console organizer and top tray Front air dam delete Sidestep delete Add factory mudguards Recovery/equipment: Everything fits behind or under the seat Tool roll up bag Battery terminal cleaner Electrical grease for terminals Digital multimeter Alternator tester 4 gauge jumper cables Breaker bar with 19&21mm sockets Viair compressor Tire deflator Tire repair kit Tarp Hitch with d-ring Standard hitch 1 1/8 to 1 1/2 open ended hitch wrench Rope Ratcheting tie downs Tire gauge Cellphone charger wall/socket adaptors Gloves Recovery strap Crowbar Mighty might fishing pole Small tackle box First aid kit Michelin road atlas (4) 1 liter water bottles in rear doors 1 empty grey plastic ammo can (not sure what to put in it yet).
    Got my rear about as high as the jack would go
