Any reason why this Add a Circuit is limited to 10amps?
Discussion in 'Technical Chat' started by iJDub, Mar 13, 2014.
  1. Mar 13, 2014 at 6:52 PM
    iJDub
    iJDub [OP] Well-Known Member
  2. Mar 13, 2014 at 8:28 PM
    trdtoy
    trdtoy Well-Known Member
    North Carolina
    02 sr5 4x4 auto v6 turbo (sold)
    Turbo with supporting mods and tranny to hold power.
    Says use with ato fuses up to 10 amps. Not sure if this means 10 amps total or per fuse and 20 amps total? Either way amp limitation is for safety. Limitation is likely wire size/gauge and fuse block assembly itself. You can run larger amp fuses and power through electrical circuits with risk of components heating, melting, or even catching on fire. This is at your own risk.
  3. Mar 13, 2014 at 8:36 PM
    Nick82
    Nick82 Well-Known Member
    Nick
    Richmond ky
    2012 DCLB MGM 4x4 sport tow nav
    ARB winch bumper
    What he said!! Toyota engineers design the wire size in corillation with it's intended use. When you tap in t borrow extra power the wiring just wasn't designed for. There is probably wiggle room for an extra 10 amps but if you need more better be safe and run a new wire.
  4. Mar 13, 2014 at 8:37 PM
    moondeath
    moondeath The answer to divorce...... Tequila!
    Pa, Carlisle
    2013 TRD Sport DCLB 4x4
    5100 @ 1.75", 1.5" Icon Progressive 3 leaf, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
