Any recommendations for oversized oil filters for my 2006 2.7L?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by saugus, Sep 10, 2011.
  1. Sep 10, 2011 at 7:07 AM
    saugus
    saugus [OP] Well-Known Member
    I guess all of the Tacomas, Tundras and Landcruisers made in 2006 use the same size oil filter. I am going to buy a pureone oil filter and test whether it fits on my Tacoma. I want the biggest one that I can fit on comfortably. Anybody have a recommendation? I found that this one has the same threads and diameter and is 1.38" longer.
  2. Sep 10, 2011 at 7:32 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    i use the bosch oversized filter. don't remember the part number off the top of my head. no fitment problems though.
  3. Sep 10, 2011 at 7:55 AM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    I wouldn't bother:
    - The 2.7L has a fucking enormous oil capacity, something like 6q.
    - The OEM Toyota filters typically have much more media surface in them than aftermarket.
  4. Sep 10, 2011 at 8:13 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
  5. Sep 10, 2011 at 9:00 AM
    myname150
    myname150 Well-Known Member
  6. Sep 10, 2011 at 11:34 AM
    Gordon-Gekko
    Gordon-Gekko Member
    Fort Lauderdale, Florida
    08 2.7 PreRunner SR5
    Ivan Stewart Wheels, RollBak Tonneau, Hellwig Rear Sway Bar, URD Short Throw Shifter, LC Engineering Header, Fumoto F-103, WT SW Deflectors
    This is the tall filter Toyota sells that fits many Toyo applications including our 4 Cyl 2.7 trucks. I have an '08 and have been using these since I bought the truck. Search for the part number on ebay and you will find dealers that sell them by the case ( Qty 10 ). The case cost me $39.00 in 2008
    Genuine Toyota Oil Filter 90915-YZZD3
  7. Sep 10, 2011 at 12:33 PM
    saugus
    Sweet. That is what I want.
  8. Sep 10, 2011 at 2:28 PM
    CraigS
    CraigS Member
    Maryland
    11 4dr TRD Sport
    That's what I use on mine.I work at a lexus dealer and prior to 06 we had a D1 for 6 cyl and the D3 pictured above for V8s.I took the number from the short filter that my truck came w/ ( not a D1) to work and asked the parts man to check in the Lexus system. It crossed to the D3. So I get D3s now.
  9. Sep 10, 2011 at 5:28 PM
    650H1
    650H1 Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
    What's a bigger oil filter do for us?
  10. Sep 10, 2011 at 5:34 PM
    jandrews
    The theoretical advantage is that filters with more filter medium will hold more contaminants, and can thus go longer between changes with minimal risk to the vehicle.
    Large filter housing does not equal more filter media though.
  11. Sep 13, 2011 at 7:01 AM
    Kelson
    Kelson
    Honolulu, Hawaii
    it does make the filter easier to take off. true story bro.
  12. Sep 13, 2011 at 10:32 AM
    saugus
    I now understand your username.:rolleyes: Reread your first sentence. Are you a toyota engineer?
    First off, are there any disadvantages? Don't think so
    Second, the larger filter holds more oil = a little more dilutution.
    Third, larger filter = less resistance. After 7000 miles, do you really think the stock filter is still flowing at the same rate with the same pressure as a brand new one?
    Forth, they are the same price.
