Any recommendations on upper and lowe ball joints ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Miguel_prerunner7, Nov 7, 2017.
  1. Nov 8, 2017 at 10:43 AM
    #41
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Honestly, you shouldn't expect any part to fail "prematurely". That just means you installed it wrong, aren't using it for its intended purpose, aren't following maintenance procedures, or bought cheap parts.
  2. Nov 17, 2017 at 5:11 PM
    #42
    Roadeater
    Roadeater Well-Known Member
    Kennesaw, Ga
    2004 Black Tacoma Prerunner TRD V6
    I have Moog 555 in my truck... I prefer Moog 555.
    OEMs are the ones causing accidents out there.
    70k miles and working like the first day.
    Just saying :rolleyes:
    :crapstorm:
    El Taco Diablo likes this.
  3. Nov 18, 2017 at 2:41 AM
    #43
    tony2018
    tony2018 Well-Known Member
    i no longer debate, get whatever fits your budget.
  4. Nov 18, 2017 at 6:24 AM
    #44
    rybern
    rybern Well-Known Member
    N Alabama
    2025 TRD OR & 2000 SR5
    I replaced my original(OEM) LBJ at 292K miles. My original LBJ's with that many miles on them actually seemed fine. But I went ahead and replaced them with OEM. OEM LBJ's can be found for $200 including shipping.
  5. Nov 18, 2017 at 9:26 AM
    #45
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    I just replaced mine with OEM lower toyotas and used AC delco uppers that are the same design and construction as OEM but only cost $30.
    https://www.rockauto.com/en/moreinfo.php?pk=440150&cc=1357589&jsn=671 Uppers
    https://www.toyotapartsdeal.com/oem...ation=front-axle-arm-steering-knuckle,,43340A Lower Left
    https://www.toyotapartsdeal.com/Pag...0=VZN170L-CRPGKAB)&Keywords=Lower+ball+jhoint Lower right
    OneWheelPeel likes this.
  6. Feb 7, 2018 at 10:42 AM
    #46
    TacoS805
    TacoS805 Well-Known Member
    So Cal
    2004 White 2.7L 4x4 5 speed Xtra Cab
    Anyone have any experience w/ 555 LBJs from Low Range Off-Road?
  7. Feb 7, 2018 at 10:49 AM
    #47
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
  8. Feb 7, 2018 at 4:16 PM
    #48
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    I have to agree. This debate has been raging since time began. Do whatever makes you happy.
    otis24 likes this.
  9. Feb 7, 2018 at 8:06 PM
    #49
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    There you have it folks, 230 THOUSAND miles on OEM ball joints. OEM.
  10. Feb 7, 2018 at 8:08 PM
    #50
    tony2018
    and why would you trust anything else
    2002Tacoma4x4 likes this.
  11. Feb 7, 2018 at 8:08 PM
    #51
    Brice
    Brice Turbo Member
    Brice
    Texas
    To be clear there is a recalled OEM lower ball joint. My truck had the non recall version, they seemed to have a smaller ball.
  12. Feb 7, 2018 at 8:11 PM
    #52
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Every time I see threads like this I have yet to find any reports of an OEM ball joint failing before 200k Miles, many of which are lasting 300k miles or more. That's a HELLUVA lot of a miles, guys. These should be changed out every 100k, but you could very easily stretch it to 200k it seems. Just know how to check it for play!
    This is a 2001 Tacoma. That means these ball joints lasted 17 YEARS. Cost of OEM replacement - $200.
    Conservatively speaking, let's say they last just 12 years before being replaced again.
    That makes the total cost $16 per year, or a whopping $1.38 per month.
    Perhaps I should start financing OEM ball joints on a low low monthly payment of $5 for 5 years!!
  13. Feb 7, 2018 at 8:13 PM
    #53
    Brice
    Brice Turbo Member
    Brice
    Texas
    Mine were sorta loose at 180k They were probably fine to leave on, but hey insurance right?
  14. Feb 7, 2018 at 10:25 PM
    #54
    Gunrunner269
    Gunrunner269 Well-Known Member
    Moog = Sankei
  15. Mar 25, 2018 at 11:59 PM
    #55
    97standardcab
    97standardcab New Member
    artie
    97 standard cab 4x4 4cy 5sp
    stock
    303000miles on oem ball joints.After seeing ball joint failure on thred,i parked truck and im ordering oem ball joints tomorro.
