Any street mods on 2nd generation prerunners....not 4x4?
Discussion in 'Street Trucks' started by Jubei71, Apr 18, 2019.
  1. May 8, 2019 at 3:18 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Check out performance and tunning section Threads on turbos supercharger and na mods . Be prepared:spending:
  2. May 13, 2019 at 9:55 AM
    pinktaco808
    pinktaco808 Hot Steppa
    Need handling too hang turns
  3. May 14, 2019 at 11:26 AM
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
  4. Jan 31, 2020 at 7:57 PM
    SpaceCoastTacoma
    SpaceCoastTacoma Member
    Damian
    2005 Tacoma PreRunner
    Lift Tires Fiberglass Regear’d
    I have a 05 prerunner 2.7L 5 speed that I’ve prepped a 2Jz for a swap for...but first I’m going to see how much boost the stock high mileage 2tr fe engines will take. I’ll let ya know
    pinktaco808 likes this.
  5. May 28, 2020 at 7:54 PM
    tacokarl
    tacokarl Big Blue
    Karl
    Connecticut
    2008 Pre-Runner SR5 DCLB
    2008 pre-runner here. I'm doing what I can to make a street truck out of my Tacoma. Knowing what I know now I should have bought a base model for my street truck goals but I got a great deal. I'm doing as much suspension work as I can, bushings, rear sway, street tires, etc. Coming from the Subaru world I'm really surprised how little aftermarket support their is for lowing a pre-runner. Yes it's a truck designed and built to off-road with but compared to other vehicles there is almost no options for "street trucking" a pre-runner.
  6. May 28, 2020 at 8:05 PM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    You mentioned shocks early on- KYB gas adjust are decent priced upgrade to factory shocks- probably work good with a drop spindle but maybe coil overs would be better if you try to get real low? Dont over look the weight- One of the best ways to make anything stop faster, turn better and accelerate better is lose the weight. Spare tire/ rear bumper- interior bits the jack- losing a few bolts here and there- move that battery to the rear- go smaller- all just ideas. Your rim tire choices look heavy- consider smaller rims if performance is a bigger factor than style. Losing weight is great but losing rotational weight is even better.
  7. Jan 2, 2021 at 9:20 PM
    Jubei71
    Jubei71 [OP] Well-Known Member
    2005 Toyota Tacoma 2wd PreRunner
    Custom rims, bull bar, billet grille, grille led lighting
  8. Jan 2, 2021 at 9:20 PM
    Jubei71
    Have you made any street mood changes?
  9. Jan 2, 2021 at 9:35 PM
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Updated pics post 15 . Also found coilovers that work
  10. Jan 5, 2021 at 9:04 PM
    Rojas
    Rojas Member
    Dennis
    VA
    2008 Toyota Tacoma Prerunner
    What kind of exhaust would be best, I was looking into a magnaflow street series. What do y’all got
