Any Topper Leak Problem??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by janesburg, Sep 15, 2010.
  1. Sep 15, 2010 at 1:26 PM
    janesburg
    janesburg [OP] Member
    WI
    2010 SR5 Crew 4x4
    I just bought a 2010 Crew SR5 4x4 and am shopping for a topper. I have spoken with 4 different topper dealers and 2 of them said they have had issues with rain leaking in under the top edge rail of the composite box and then running down and getting inside the box. They both blame the design of the composite box. Have any of you experienced any leaking after a topper was installed? If so what was the brand of topper and the results? Thanks!!
  2. Sep 15, 2010 at 1:42 PM
    Furb
    Furb Well-Known Member
    NoVa
    09 TRD OR, 93 Supra TT, 93 MR2T
    what exactly do you mean by "topper"? Soft top, camper shell, etc?
  3. Sep 15, 2010 at 1:44 PM
    janesburg
    WI
    2010 SR5 Crew 4x4
    My bad I should have stated a shell.
  4. Sep 15, 2010 at 1:52 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Leer 100XR on mine. Sits outside in rain and snow, and never had a leak. Most of the time if they do leak, it's when you have roof rack tracks mounted on top (which mine does). But if it were to ever leak, Leer provides a lifetime warranty on that. So do most of the others.
  5. Sep 15, 2010 at 2:58 PM
    Taco4x4NC
    Taco4x4NC Well-Known Member
    David
    Western North Carolina
    2010 4x4 DC/LB "Pytrite Mica/Katzkin leather
    3m clear bra or Venture, stant locking gas cap, Shield, front windows tinted, weathertechs, ARE "Z" topper. Sockmonkey decal, Billy 5100's x 4 corners, Eibach coils, Toytec 1.5 AAL. Michelin 265/75/16 MS2's, Grillcraft MX series/TOYOTA badging. FJ/SE TRD Anthracite gray wheels. Katzkin leather/heated seats.
    No leak since install. Love it! ARE "Z" series. For what I paid it better not leak. No leaks to date and I have been through a touchless car wash to check. So far so good, no leaks. My dealer took extra care when weather sealing the topper to my bed rails. If your dealer did not you will probably have a leak. I am just sayin....
    Cheers!
    Taco4x4
  6. Sep 15, 2010 at 3:04 PM
    MountainEarth
    Bryan
    CO
    2010 TRD OR Access
    Make sure your topper has "skirted sides". These go all the way over and overhang the bed sides. I did see a Jason topper that actually sat on top of the rails, and all they used for a seal was a thin strip of closed cell foam. That would have leaked.
  7. Sep 15, 2010 at 3:07 PM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    i got one that sits on the bedrails and it doesn't leak at all. so ^^^^^that is false.
  8. Sep 15, 2010 at 3:35 PM
    cobrakenny
    cobrakenny Well-Known Member
    Ken
    Raleigh, NC
    09 TRD Crew Cab 4x4 LB
    ARE with the side "windoors" and not a drop inside after 5 months!
  9. Sep 15, 2010 at 5:31 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Mine does not leak at the rails, but they put some extra mastic type material in the front corners when they installed it. Mine's a Leer and it does have a small leak at a seam in the aluminum frame for one of my side windoors. I am going to pick up some black silicone for that, no big deal.
  10. Sep 15, 2010 at 5:41 PM
    meafordmike
    meafordmike Well-Known Member
    New Brunswick Canada
    08 Tacoma 4X4/ 4Dr 6 speed, Sport/ Towing
    Devil Horns, Wet Okoles, WeatherTechs, Radflo Coilovers, OME Dakar's, FJC Gun metal rims, 265/75/16 BFG All Terrain TA/KO, Rear Diff breather Mod,
    My ARE Z series does leak like the salesman told you. Only a little and yes its coming under the bed skirts side rails. I could probably fix with some sealant but its a very little leak. Not ARE fault but Toyota's design.
  11. Sep 15, 2010 at 6:28 PM
    bmactexas
    bmactexas Member
    Kentucky
    MGM
    ARE Shell, tint front and back.
    I've had an are...v series, I think...since 9/08 with no leaks. And, I should update my post in another thread from a year or so ago... The are has proved to be a good shell. The dealer and are resolved my issue with no questions asked. I have rails installed on mine, and it is not hard to pull the bolts and shoot them full of caulk, if you are worried about leakage at those points. I did it. One warning, when standing on your shell, avoid putting a foot on the truck roof, I put a nice dent in my roof with hardly any weight (it popped out)... I stood on top of my '95 t100 plenty and never thought about it caving...I guess the gas savings are worth the thinner sheet or less support...whatever it is. Ok, enough.
  12. Sep 18, 2010 at 7:44 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    I have a Leer 100XQ, and my dealer told me about the leak problems before I bought mine. They said the biggest problem is at the front of the bed on each side where the composite bed ends, and the sheet metal begins.
    They laid down a bead of clear silicone caulk at that joint before installing the cap.
    I do get a very little bit of water coming in, but I also have a bed mat, so it's no biggie to me. The little bit of water that gets in goes down under the mat and goes out the drain holes, so my stuff stays dry.
  13. Sep 18, 2010 at 7:53 AM
    swendling12
    swendling12 Well-Known Member
    Sean
    Nebraska
    09 Reg Cab SR5 4 cyl 5spd 4x4
    I had a bit of trouble in the front corners of my bed where my ARE CX met the composite bed, a bit of clear silicon, and it sealed right up. The only other place it occasionally lets water in is around the tailgate. But it's not too bad.
  14. Sep 18, 2010 at 8:09 AM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    Same here, but I ignore it, only when I wash the truck not when is raining. How about the gap left on both sides of the closed tailgate?
    No biggie, unless our friend intends to live in the back of his truck.
    Take care
    vbibi:(
  15. Sep 18, 2010 at 8:22 AM
    zebra1550
    zebra1550 Well-Known Member
    Midwest
    4X4 SR5 DC OR Package
    16X8 Raceline Renegade 6's, 265/75R16 Revo 2's, Jason Tonneau, De-Badged, De-Chromed, Wet Okole's, 5100's & Rear TSB, Window's Tinted
    My Jason hard Tonneau leaks near bed of the cab. Not bad enough to bother me, but I definitely don't keep anything in there that I can't afford to get wet.
  16. Sep 18, 2010 at 11:20 AM
    ozmon420
    ozmon420 Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
    no leaks with my leer
  17. Sep 18, 2010 at 11:36 AM
    cobrakenny
    Ken
    Raleigh, NC
    When I purchased my cap (This is my 4th A.R.E. cap and I've been very happy with each one) I reminded the installer that I regularly carry tools and exotic hardwood trims that simply cannot get wet, and that this was a deal breaker for me. After he dutifully advised me of the inherent Tacoma leak problem he applied 2 layers of gasket material to the front 1/2 of the cap at no extra charge and I have not had a single drop of water inside yet. Guess this was not his first rodeo with the Taco!
    Now I WAS untill recently getting a major amount of road dirt and dust (no water however) from the really usefull storage compartments molded into the the bed of the Taco. Turns out it was comming from the drain holes in the bottom of the cubbies. I sealed them up with gaskets and plugs since I have a cap and don't have to worry about them draining anything out, just crap getting in... but that's another post...
  18. Sep 18, 2010 at 11:42 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Sherpa Grand Teton/Crows nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights
    My SnugTop SuperSport hasn't leaked except for the time the brake light on the back became loose...tightened it back up and hasn't leaked since. The only water and dust that's able to get in is through the sides of the tailgate. To cure that I just ran some weather stripping along the inside edge of the brake lights.. closes up the gap on both sides about 6" down from the top edge of the gate.
  19. Sep 18, 2010 at 5:45 PM
    TakDwn
    TakDwn Well-Known Member
    PA
    2010 Tacoma DC V6 Shortbed 4x4
    Bili's all around, front 5100's at 1.75", rear TSB w/AAL, 265x75/16 BFG AT, Wheelers steelies Type B 4" bs, LEER cap, Tinted, Relentless hybrid sliders welded, Cab mount chop, Plastic trimming, Sock retros, Mirror lift, Satoshi with old school emblem, WeatherTechs, Mudlaps gone, RedLine hood struts, Fumoto valve, Tailgate clamped, Console organizer, Mobtown Offroad Front Recovery Bar
    I've had a Leer on for about 2 months now...no leaks at all.
