Any Upgrades Needed after Installing a Supercharger?
Discussion in 'Performance and Tuning' started by perogie2328, May 30, 2009.
  1. May 30, 2009 at 1:56 PM
    perogie2328
    perogie2328 [OP] Member
    Saskatchewan, Canada
    2010 Tacoma Acess Cab V6 4X4 TRD + Tow Pack
    Toyota Skid Plate, Command Start, k&n cold air intake, magnaflow catback exhaust, Revtek 3" lift, HID conversion kit
    I want to install a Trd supercharger on my 4L v6, but does anyone know if i would have to upgrade my clutch? Will i have Transmission Problems? will my stock drive train handle the extra power?
  2. May 30, 2009 at 8:05 PM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    I'm still running the stock clutch on my xrunner. With lots of extra power over just the TRD blower.
    You should be fine, but a small note, the OEM clutch is a hit or miss. Some work well, others will blow out on an N/A vehicle.
    If it blows out (not wear out), it is most likely a catastrophic failure, and you can have that replaced under warranty
  3. May 30, 2009 at 8:07 PM
    Brunes
    Brunes abides.
    Rotorhead
    If you want to you can do TONS of stuff...but like XR said- you can get away with the stock equipment.
  4. May 31, 2009 at 11:38 AM
    Marazzito
    Marazzito Well-Known Member
    Dublin, CA
    07 DC TRD Off-Road 4x4
    TRD Exhaust, AFE Cold Air Intake, URD Short Shifter, OME 886 HD Lift OME Rear Springs With XL... TRD Supercharger Coming Soon.
    There are two different clutches for the Tacoma. Some are sourced from a German company and others from a Chinese company. If you get a truck with a German clutch, it will fail. The Chinese clutches are much better and shifting is significantly smoother. My truck came with a German sourced clutch, started showing the early signs and my dealer swapped it out for the Chinese sourced clutch. My truck shifts much better and the clutch engagement is way better.
  5. May 31, 2009 at 1:33 PM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    Is there a way to tell which clutch installed? Part number? Manf Label? anything like that?
    Do you have any other info about those (comp name, etc)?
  6. May 31, 2009 at 3:06 PM
    Marazzito
    Dublin, CA
    I honestly don't know, but when I brought my truck to my service department with the first signs he new exactly what it was and explained the difference between the German sourced and Chinese sourced clutches. He was able to confirm that I had a German clutch but I am not sure how, maybe VIN, maybe when he pulled my tranny and looked at it. When he ordered the Chinese clutch it was on back order (show's how much of a problem it is). He also said this is one of the most known problems with the 6-speed Tacoma's.
    On a side note, I brought it to another dealership before and they were clueless and greased my u-joints (which did nothing).
