Any word about high capacity fuel tanks?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by whitewolf001, Jul 18, 2017.
  1. Oct 13, 2017 at 12:34 PM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    My thought exactly. The truck has the space. Toyota could have done better in the first place.
  2. Oct 13, 2017 at 12:38 PM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Fuel is weight. In this age of weight savings Toyota is not going to give up 60lbs+ to put a 30 gallon tank in.
    gsubioguy likes this.
  3. Oct 13, 2017 at 3:09 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    So why did they increase the size of the tank on the Tundra?
  4. Oct 13, 2017 at 3:34 PM
    HardCase
    HardCase Winter is coming.
    Robert
    Kalispell, Montana
    2017 Tacoma (Inferno) TRDOR 4x4 DCLB
    When I had my Tundra, gas guzzler that it was, the OEM 27 gallon tank seemed to be empty all the time, I could pass everything but a gas station. I got a TransferFlow 46 gal tank and that was great......until I had to fill it.
    So far I haven't felt that the OEM tank in the Taco is undersized, although wouldn't mind a little more capacity.
  5. Oct 13, 2017 at 3:49 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    dang it Joe I forget you are CA, you and you Liters
  6. Oct 13, 2017 at 3:50 PM
    JoeCOVA
    Joe
    Colorado Springs
  7. Nov 5, 2017 at 3:58 PM
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Typically people are towing more often with a Tundra than a Tacoma...single digit mileage with a trailer hooked necessitates a bigger tank
  8. Nov 5, 2017 at 4:22 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    My Tacoma has a cargo capacity of only 1200 lbs and has a range on the hwy of about 300-350 miles with the factory tank. I've made 4 cross country trips from GA to UT, AZ, CO, and NM. The truck is close to overloaded with 2-3 people in it plus camping and hunting gear. I can live with stopping every 300 miles before paying $300 for another tank and and reducing my cargo capacity by 150 lbs. About 120 lbs for 20 more gallons of gas plus the weight of a separate tank and related hardware.
    A 1/2 ton however has closer to 2000 lbs cargo capacity and already have 26-30 gallon tanks. Going to a 36 gal tank only adds 50-60 pounds of weight. Hardly noticeable when you have much more capacity to start with.
    My F-150 has a 36 gal tank. And on that truck is the only way to go. In fact the biggest reason I chose Ford over Tundra was the lack of a bigger tank in the Tundra at the time I was buying. But on my Tacoma adding more fuel capacity has more negatives than positives.
    specter208, nphagert and su.b.rat like this.
  9. Nov 5, 2017 at 5:00 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
  10. Nov 5, 2017 at 6:55 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I looked at the Titan 15 gallon auxiliary fuel tank to go in the bed, but decided instead of getting 3-5 gallon eagle fuel cans- https://www.amazon.com/Eagle-U2-51-S-Galvanized-Capacity-Diameter/dp/B000BQO15I
    they have flash protectors and are safer than having a large auxiliary tank in an accident - you stand a better chance of having a larger fire should there be an accident and your larger tank ruptures- what are the chances of that? I dunno, once in my lifetime at least- while I was patrolling late on night, I saw a guy in a flatbed without the bed flip after side swiping another car, and his fuel tank ruptured and all the gas poured down out of his ruptured tank onto him through the broken out back window of the cab. He was totally soaked in it. Damn if there wasn’t a fire - he was one lucky guy. So to transport my extra gas more safely when I’m pulling my trailer, I put my 3 eagle cans in a large fuel proof cargo box with a latching lid, and keep it tied down between the wheelwells in back until I need it.
    CusterFan likes this.
  11. Nov 6, 2017 at 11:59 AM
    NitroExpress
    NitroExpress Active Member
    Texas
    '17 TRD PRO
  12. Nov 6, 2017 at 2:07 PM
    CusterFan
    Glad I don't need one then.. :D
  13. Nov 6, 2017 at 2:12 PM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    yeah, the new tundras come with a 38 gallon tank...
    specter208 likes this.
  14. Nov 6, 2017 at 3:33 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Tundra Double Cab 6.5 bed 4x4 only has 1400lbs of payload.
    shakerhood likes this.
  15. Dec 6, 2017 at 11:40 AM
    #35
    codename607
    codename607 Well-Known Member
    Baltimore, MD
    I'm in the same boat needing more fuel storage. I have a FourWheelCamper in the bed of my truck and with a 4" lift, 33" tires, some gear I get around 250 miles to the tank. While I've never run out of gas I've been in some situations that I could have been screwed. I feel like a larger tank is one of the best upgrades I could make.
    whitewolf001[OP] likes this.
  16. Dec 6, 2017 at 12:47 PM
    #36
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Sounds like 4.88 gears would serve you better than a bigger gas tank.
  17. Dec 6, 2017 at 1:53 PM
    #37
    Dc2tacoma
    Dc2tacoma Well-Known Member
    Since Toyota like to share parts, maybe the tundra fuel tank will fit?
  18. Dec 6, 2017 at 1:58 PM
    #38
    Iamraiderpower
    Iamraiderpower Well-Known Member
    Yup got 38 Gal with 4.30 Gears in my 18 tundra. Its real nice to have, and can go 600+miles on a tank
    gsubioguy and James_Bond[QUOTED] like this.
  19. Dec 6, 2017 at 2:21 PM
    #39
    phsycle
    phsycle Well-Known Member
    CA
    That's one thing I miss about the F150. The 36 gal tank.
    The retrofits could be nice. But they mess with all sorts of things. Nothing major, but for my OCD, it will bug me. DTE, fuel gauge, etc.
    If I am headed into the backcountry and need more fuel, I will save myself $400 + labor (plus the above "issues") and buy myself two 5-gal gas cans and strap it to the bed.
  20. Dec 6, 2017 at 2:32 PM
    #40
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    No. The hard part would be ensuring the self-made tank plays nicely with the evap solenoids and charcoal canister, else you'd get the CEL on intermittently.
