Anybody have a 4.0l V6 timing belt break?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by apoolguy, Dec 15, 2011.
  1. Mar 8, 2015 at 9:54 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    On one of the recalls, the dealer told me I better change the drivebelt soon and I only had about 40K on the truck.
  2. Mar 8, 2015 at 11:12 AM
    spp
    spp OC, Kalifornia
    OC California
    Drivebelt is not a timing belt but should last a lot longer than that.
    My 2010 had 83,000 miles when I traded it in last month and never had to change a belt or even the wiper blades.
  3. Mar 8, 2015 at 11:21 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    4.0 has a timing chain and it's an interface design meaning it is internal. Very unlikely to break but if it does it could cause catastrophic damage and punch a hole through the block. Now my 3.4 V6 and all other V6 years of first gen Tacomas had timing belts, and those are non-interface, meaning they are on the outside of the engine protected by a cover. So if a timing belt breaks in a 3.4, it wont damage the engine, it will leave you where it broke though but that's about it. Change it every 90k miles and you wont have a problem, do the water pump every other timing belt change.
  4. Mar 8, 2015 at 11:29 AM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    This is a good thread. So basically don't worry about changing it. I'm gonna have bigger problems if the chain needs replacing lol...
    163k miles. I should change serpentine belt though soon...
  5. Mar 8, 2015 at 11:35 AM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    Chain.
    ah see it's been answered.
  6. Mar 8, 2015 at 11:48 AM
    dakotasyota
    Dakota
    Ellensburg, WA
    Who needs frames? The body should still hold it together like on top gear ;)
  7. Mar 8, 2015 at 11:54 AM
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    When you say "interface" and "non interface" are you sure you are not referencing interference and non-interference?...
    An interference design means the valves will impact the pistons if timing is severely off, ie a broken timing belt( think Honda engines). And of course a non-interference engine won't be damaged by a timing belt failure(most Toyota timing belt engines are non-interference by design for ease of repair and longevity of design).
    TacoJova and blu92in99 like this.
  8. Mar 8, 2015 at 12:08 PM
    Shelf Life
    Rob
    Central Oregon
    Ya, I know. Just pointing out some of the things salesmen tell you that you don't need.
  9. Mar 8, 2015 at 3:03 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    read below
    You can have a motor that uses an internal timing change that has a non-interference design (Valves fully open will not hit the piston at the top of its stroke)
    Also... on the 3.4L v6 on the first gens.... REPLACE THE WATER PUMP EVERY SINGLE TIME YOU DO THE TIMING BELT..... the real reason for changing the timing belt on those motors is the water pumps which tend to start leaking around 100k or so... the belts themselves, you will find very VERY few stories of them actually breaking.
  10. Mar 8, 2015 at 3:34 PM
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    Quoted and put in bold font to help keep factual information alive. Internal and External timing chains are just a "packaging issue". Where the chain is located has no relevance to Interference and non-interference engines. The main advantages of an interference valve design is for higher compression and the potential for tighter clearances and control of valve overlap.
    SR-71A likes this.
  11. Mar 8, 2015 at 5:36 PM
    spp
    spp OC, Kalifornia
    OC California
    Yep. It's just part of the UPSELL that they do to the uneducated.
    My 1999 was in for a 5000 oil change and recommended a drivebelt.
    I said to leave it until the next one at 45000.
    When I took it in I told the service writer. When I got the truck back the tech said the belt was fine.
    Also had them tell me that I needed new wipers. Refused and turned out the windshield was just dirty.
  12. Mar 9, 2015 at 6:06 AM
    liddell373
    liddell373 Member
    Dave
    South Jersey
    2011 Doublecab 4WD Base
    You guys rock! Absoutely the best website with the best people i've ever been on. Thanks!!
  13. Mar 9, 2015 at 7:56 AM
    Focusjon
    Focusjon Active Member
    Jon
    Cincinnati Ohio
    2016 TRD Off Road double cab stock
    I am surprised the chain is a lifetime chain on the 4.0 2011. It is fantastic to hear though ha ha.
  14. Mar 9, 2015 at 8:07 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    At 90,000 miles, on my 2001, had the timing belt changed as recommended, and the water pump too, as it was dripping (they said).
    My 2005 went 102,000 miles and with a chain, nothing to change.
    My 2010 is going on 72,000 miles, and no chain issues, but at 66,000 miles the water pump was replaced.
  15. Mar 9, 2015 at 8:29 AM
    #35
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    With timing chain there are only two (three if you split guides) to maintain.
    Idler (yes they have idler too) and guide(s) shoes. Now if you use good oil, and lubrication system works as supposed to than both should last for very very long time.
    If oil is cheap, and lubrication is not up to the par, both will need replacing at some point, most likely along side the engine.
  16. Oct 29, 2015 at 7:26 PM
    #36
    zkdawg
    zkdawg Greenville Taco
    zach
    Mauldin, Sc
    06 DCLB TRD Sport
    Fog light mod, JBA LT headers, drop-in k&n filter, energy bushings, tried fold topper, 2nd air filter removed, all new stereo system minus subs, plastisol the wheels.
    I have 254,XXX on i belive is the original motor right now and I have heard that the chain would go out between 250-300k miles. This is my families only vehicle. Should I replace the thing just to be on the safe side? By the way, I'm an auto tech so I would do it my self.
  17. Oct 29, 2015 at 8:08 PM
    #37
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
  18. Jul 23, 2018 at 3:29 PM
    #38
    Bigswag17
    Bigswag17 Bigswag
    North Augusta, south Carolina
    2019 TRD off-road
    This thread was great, I have an 05 , now that I know that I have the chain, I wonder how important it is to deal with the transmission flush, or dealing with my lifters. I run royal purple full synthetic in it, and it's now at 185,000 miles. Any suggestions?
  19. Jul 23, 2018 at 3:40 PM
    #39
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    The transmission is kinda up to you. We have people with over 300k that have never serviced theirs. Toyota used to say 100k under severe service such as towing, but has since backed it up to 60k miles.
    https://www.tacomaworld.com/threads/how-to-drain-refill-automatic-transmission.63851/
    https://www.tacomaworld.com/threads/diy-full-flush-for-automatic-transmission.68462/
    As far as the lifters go, they are shimless buckets, you can’t just adjust them. You have to buy new buckets. Most people don’t bother with adjusting the valves unless they’re tapping/making noise. Some people opt to re-do the heads when they have to do the head gaskets on the 05 and 06’s.
  20. Jul 23, 2018 at 3:40 PM
    #40
    David K
    3+ years later, my 2010 has 113,000+ miles now. No chain issues still.
