Anybody have any experience changing Oil Filter Housing 4L 2007
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CanoeCarrier, Jul 26, 2017.
  1. Jul 26, 2017 at 7:09 PM
    CanoeCarrier
    CanoeCarrier [OP] '19 TRD Off-Road AC
    North West, North Western Ontario
    My oil pressure sending sensor started leaking so in my attempt to change it I managed to snap a piece right off the housing. I've looked and looked for some info on changing this part and nothing, which tells me I may be the only dumb ass to do this.
    Anyhow, I have the old one out and am waiting for the parts. I ordered from Toyota Parts Direct and while the price was decent it is going to end up taking almost 2 weeks to get. Ordered last Thursday and due Tuesday next week.
    I am looking for any advice on how to get this together without any mishaps, I am not terribly good mechanically but follow directions real well. Do i need to use anything like thread lockers or gasket material to put it back together?
    Any tips or advice is welcome.
  2. Jul 26, 2017 at 7:11 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    What piece broke off the housing? Did you get the entire old sensor out?
  3. Jul 26, 2017 at 7:54 PM
    CanoeCarrier
    Where the sensor screws in is where it broke. The sensor didn't break but the housing did. It is 100% broke and not fixable. I ordered another new sensor in case I find the other one is broke. I still have to find it in the skid plate somewhere. Truck has been parked since it happened. Driving my 99 Xplorer to work since.
  4. Jul 26, 2017 at 8:12 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    So the metal housing is what broke?
  5. Jul 26, 2017 at 8:26 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    #13?
  6. Jul 27, 2017 at 3:31 AM
    CanoeCarrier
    Yep #13. On the front left side of it there is an oil pressure sending unit. Not sure if i cross threaded it or what but the corner of the housing broke right off. If you have the 4L you can see it right beside the oil filter
  7. Jul 27, 2017 at 3:48 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  8. Jul 27, 2017 at 3:51 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Should be fairly straight forward, I would blast out the threaded holes with brake cleaner or the like to prevent the hydraulic effect that may have caused you to snap the first housing. Clean clean clean everything you can, and generally if it keeps oil from leaking Toyota want's you to apply FIPG to some degree, it's about $10 a tube on Amazon and has a million other uses. Made by 3 Bond, you could also use Black RTV but I find it doesn't last as long or seal as well.
    Blockhead likes this.
  9. Jul 27, 2017 at 5:18 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Depending on mileage of your engine, you should seriously consider a new O-ring. Or a silicone as mentioned above.
    Just a few bolts and nuts, and it will slide right off of the two studs. That sensor uses a metric thread. If you were curious.
    The arrow directly above the #13, points to a plug. That is interestingly an SAE thread pitch.
  10. Jul 27, 2017 at 7:40 PM
    CanoeCarrier
    EatSleepTacos[QUOTED] likes this.
