Anybody know the weight of Hankook's Dynapro ATM RF10 in 265/75/16??
Discussion in 'Wheels & Tires' started by Dakota 08, May 21, 2011.
  1. May 21, 2011 at 4:02 PM
    Dakota 08
    Dakota 08 [OP] Well-Known Member
    Portland
    08 Dbl Cab
    I know its a specific question...but I've scoured the internet and cannot find the answer.
    Reason why I'm asking is because I just oredered and mounted Falken's new Wildpeaks in 265/75/16 and they are heavier than shit (56 lbs each). Although the tire has a bad ass, aggressive looking tread pattern, I've experienced a complete loss in power and mpg's.
    I want an aggressive all-terrain that is much lighter than Falken's and I'm down to deciding between Dynapro's AT or Toyo's AT, or any others you guys can suggest.
    Thanks for the help.
  2. May 21, 2011 at 4:30 PM
    Dakota 08
    Portland
    08 Dbl Cab
    Which ever one is the lighter of the two. I'm guessing that is LT? Just curious, where did you find the weight?
  3. May 21, 2011 at 4:44 PM
    Dakota 08
    Portland
    08 Dbl Cab
    Can you find the weight of the P model? I'm looking and cannot find? What's the ultimate difference between a P and LT model tire?
  4. May 21, 2011 at 5:04 PM
    Dakota 08
    Portland
    08 Dbl Cab
    bump for finding the weight of the P model
  5. May 21, 2011 at 5:06 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I would assume that you bought the Falkens in a load range E. This would account for your fuel mileage going into the crapper.
  6. May 21, 2011 at 5:32 PM
    Dakota 08
    Portland
    08 Dbl Cab
    You're exactly right, I did buy them in a load range E ... but only because I had to. Falken doesn't offer that size in anything less.
    Thanks for all the help from everyone so far. But again, difference between a P and LT tire model? And anyone know the weight of the DynaPro ATM's in the p model?:confused:
  7. May 21, 2011 at 6:31 PM
    Mescalero
    Mescalero Beretta Taco
    Anderson, SC
    '15 DCSB TRD PRO Mag Gray
    dont know the exact weight, but its somewhere around 37-38 lbs
  8. May 21, 2011 at 7:18 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    I'm pretty sure my UPS labels said 33 lbs/pc. P-series.
  9. May 22, 2011 at 12:33 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The Dynapros are sure great tires... I am really impressed so far with mine... P model (which is what the Rugged Trails are). Quiet on highway, awesome in snow and mud, and great in desert sand. Next week, to Baja and the bottomless sand beaches!
  10. May 22, 2011 at 8:25 AM
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    I think I saw them for 41lbs each.
    To threadjack slightly, does anyone have a pic of them running 245/75/16? I have a 2" lift, wondering if it'll look too small, even though it's essentially the same as the stock dunlop: 265/65/17 (yes, I changed wheels)
