Anybody own a Corolla?
Discussion in 'General Automotive' started by RamboTaco, Jan 29, 2017.
  1. Jan 31, 2017 at 10:02 AM
    Toyojake
    Toyojake Well-Known Member
    Jay
    Central TX
    2009 T4R Sport 4x4
    Fantastic little cars, I had a 7th gen (1995) with the little 1.6 4AFE and it went forever, 5 speed manual with 289k when I sold it on the original clutch. My friend has an 09 and has nothing bad to say about it, as mentioned earlier not the best handling car but will never leave you stranded with proper maintnence. If you get one with the 1ZZ (1.8) check the timing chain tensioners and the timing cover for oil leaks. They are known to do that as they age. Also the oil consumption on those cars up until around 2005 IIRC, but if your concerned Toyota can do an oil consumption test. For a DD they are hard to beat, I just can't stand sitting that low to the ground!
    RamboTaco[OP] likes this.
  2. Jan 31, 2017 at 10:02 AM
    Rod03
    Rod03 Well-Known Member
    14 DCSB OR 300k+ Miles DD
    22 T4R OR, 12 TX Pro, 21 Taco Skewp!, 02 Taco OR (All Sold)
    I don't know if this one applied to all of them, my 2002 never burn any oil and I drove cross country from Virginia to Cali when I move for the military. Only maintenance I did in 3+ years of owning the car was gas, tires, and brake pads.
  3. Jan 31, 2017 at 10:03 AM
    Toyojake
    Jay
    Central TX
    2009 T4R Sport 4x4
    They will tell you that, and even the service guys agree that Toyota's acceptable guidelines for oil usage are bullshit.
  4. Jan 31, 2017 at 10:05 AM
    A Salt Weapon
    A Salt Weapon Well-Known Member
    T
    Southeast Alaska
    2017 Blue DCSB TRD OR
    I had an 09 I got rid of when I got the Tacoma. No issues with it whatsoever. My dad has a 14 and loves his.
  5. Jan 31, 2017 at 10:06 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Not all Corolla's was affected but unfortunately a lot was. Toyota even have a website dedicated to this because they are still doing the repairs. My Scion was an 08. Campaign LSC ZE7.
  6. Jan 31, 2017 at 10:07 AM
    Rod03
    I see that makes sense, I heard of it before but didn't know that it had affected that many.
  7. Jan 31, 2017 at 10:10 AM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    My thoughts exactly. Any car using a quart of oil a month is unacceptable. Basically in a 5K oil change interval, they expect you to go through 5 quarts and it is "normal".
  8. Jan 31, 2017 at 10:14 AM
    Toyojake
    Jay
    Central TX
    2009 T4R Sport 4x4
    We had NEW cars with less than 20k on the clock, with the 2AZFE using a quart of month being told that was acceptable. I never blamed a single customer for ditching that car.
    OP, just inspect the car carefully. Or if you buy a new one your in the clear :D
  9. Jan 31, 2017 at 10:56 AM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    My friend just picked up a 2016 Corolla iM. Like all Scions there were no options other than colors. Came with power folding mirrors, cruise control, auto climate control & a pretty decent touch screen radio. I love that little car for what it is, reminds me of my old Nissan Versa hatch. I love CVT's for their efficiency both at low rpm cruising regardless of speed as well as their ability to hold the engine in its powerband as long as needed. To say there's a lag when you floor it.... well I've driven automatic slushbox transmissions that felt like they needed to download shift logic from the cloud whenever I pressed the skinny pedal. Buy it for what it is: an econo-box. If you expect a S600L, you'll be disappointed. If you expect it to ride like a Bentley, you'll be disappointed. If you expect it to get the range of a diesel VW with a 20 gallon tank, you'll be disappointed. Small car, small engine, small gas tank, small suspension: thems be what they be. But for a city car/commuter I think they're awesome.
    Redeemed and RamboTaco[OP] like this.
  10. Jan 31, 2017 at 6:51 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    02 and older with the 1zzfe. See them in all the time with about a quart of oil in them. The revised ones are much better. Easiest way to spot the old burner engine is the aluminium intake manifold that looks like exhaust runners.
  11. Jan 31, 2017 at 6:55 PM
    Bishop84
    Bishop84 Well-Known Member
    The new 17' corollas all got a lot more safety features with standard pre collision hardware, lane departure etc. This is good for many people, and it can all be disabled if not desired.
    I haven't seen many issues with the 13+ CVT generation corollas. The engine is quite dated now, only the valve-matic has really been introduced (valvematic is in the iM as the only choice).
    The CVT is a little annoying but can be fun in the S or now SE/XSE models. The manual is solid and offered in many trim levels.
  12. Jan 31, 2017 at 6:56 PM
    whiskeytacos
    whiskeytacos Well-Known Member
    New York
    '14 DCSB Off Road MGM
    OME 886 springs on 90000 struts Total Chaos UCA OME Dakar + AAL energy suspension steering rack and sway bar bushings SCS SR8 wheels Cooper ST Maxx 285/85r16 Pelfreybilt IFS skid plate Pelfreybilt hidden winch mount broken ass winch Softopper All Pro Off Road OTT pack rack
    Excellent car. My wife had an 07 that we got with 84000 miles on it (I wasn't a part of this purchase). Oil was black, spark plugs were Russian, tranny fluid was brown. I did a tune up (not including a timing belt) putting OEM spark plugs and filters on, and switched to a high mileage synthetic blend oil. Oil changes every 5k, did a pan drain and fill on the trans at each oil change until it was finally pink, and we had it for another 60,000 miles before selling it to get a Subaru. I fully planned on running that car into the ground but my wife didn't want to deal with another Northeast winter in a 2wd car. We got her a 2013 Subaru Impreza with 14000 miles on it for a steal. I do miss the mileage of the corolla (regularly 35-40mpg hwy even at 130k) but she's happier and more confident in her Subaru.
    If your driving conditions are fine for a 2wd car all year long, the Corolla is a fantastic option. The factory spark plugs are rated for 120,000 miles for christ sake.
  13. Jan 31, 2017 at 6:58 PM
    Andres
    Andres Well-Known Member Vendor
    Andres
    Hawthorne, CA
    2013 Toyota Tacoma TRD off-road
    Wifie has a '03 Corolla with 180,000 still running good.
    If you take care of your cars they'll go a long way.
    RamboTaco[OP] and whiskeytacos like this.
  14. Jan 31, 2017 at 6:58 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Wife has a 15. Not a bad car. Great mpg way nicer interior than my tacoma
  15. Feb 1, 2017 at 6:20 PM
    #35
    RamboTaco
    RamboTaco [OP] Active Member
    2015 TRD sport DC 4x4 Blue Ribbon Metalic
    image.jpg Thanks for all the input the wife picked this 2015 S+ model up yesterday I was nervous about getting a compact car (I'm 6 foot 260 pounds) but I swear I feel like I have more room in this car than I do my Tacoma!
  16. Feb 1, 2017 at 6:24 PM
    #36
    dumontrider
    La Habra, CA
    14 GX460
    Smoooooth. Time for Kings!
  17. Feb 1, 2017 at 6:33 PM
    #37
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    My girlfriends car died about 2yrs ago and with a house shes financially strapped
    Bought her a 92 corolla with about 100k mile no rust, few small dents and a mint interior for $1100
    Car runs like a champ, easy to work on and have only done routine maintenance
    Has about 130k on it now
    Only problem is it need a ac compressor and has r12 freon
    When parked next to my taco with the lift looks like I could drive right over it
    Feels like a go cart when I drive it
  18. Feb 2, 2017 at 10:29 AM
    #38
    whiskeytacos
    New York
    Congrats OP. Here's to years of minimal maintenance
  19. Feb 2, 2017 at 10:36 AM
    #39
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    I owned a 2013. Slow as molasses and not truly the "safest" in crash testing. But their cheap to maintain, hold their value rather well and will last forever if properly maintained.
    RamboTaco[QUOTED][OP] likes this.
  20. Feb 2, 2017 at 6:42 PM
    #40
    Syncros
    Syncros Well-Known Member
    While I like the current Corolla, my favorite car in the segment is the Mazda 3.
