anyone added class 3 hitch?
Discussion in '5 Lug' started by hammerman, Nov 15, 2011.
  1. Nov 15, 2011 at 4:41 PM
    hammerman
    hammerman [OP] Well-Known Member
    ohio
    2012 access auto pyrite
    dealer told me i do not need one because bumper is rated for 3500 lbs but i do not like having trailer so close to truck,especially backing.afraid i will get into bumper.anyone know if they bolt on with existing holes? i have a 2012 but assume newer ones would be the same.any input would be appreciated.
  2. Nov 15, 2011 at 5:27 PM
    Thorpedo26
    Thorpedo26 Well-Known Member
    Brandon Thorpe
    Justin TX
    2006 silver 4 cylinder
    Blacked out badges, weathertechs, painted grill, cut tailpipe, removed mud flaps, black head lights, red calipers, tinted tails, front and rear bilsteins are here along with fatbobs spacer and aal awaiting install, also a set of 16 inch pro comps are here and 265/75/16 dynapros
    Im pretty sure a few 5 luggers on here bolted on used trd hitches ive looked into it myself
  3. Nov 15, 2011 at 5:36 PM
    LostRebel
    LostRebel Well-Known Member
    Almost Canada, USA
    Black Access Cab 4x4 TRD Off Road
    Fisher plow, BakFlip and Snugtop cap, Demello Sliders, Scanguage,
    I installed a Hidden Hitch Class 3/4 on my 2009. It bolted to the frame and bumper using existing holes and came with a few spacers and extra bolts for attachment to the frame. I bought the hitch and wiring harness at JCWhitney. If you need it, I can probably dig up the part numbers.
    Edit: Just noticed I'm in the five lug forum. My 2009 was a six-lugger and my experience may not hold true for a five-lugger,
  4. Nov 15, 2011 at 5:38 PM
    Oat
    Oat Well-Known Member
    Florida
    2001 Prerunner
    Gibson Exhaust, Painted factory steel wheels, Chrome wheel caps, K&N Air intake, Tint, Regular Bilstein (yellow/blue) all around, Leveling spacer kit upfront, Partially de-badged, Westin Bullbar with skidplate, White, Double Cab Prerunner SR5
    Try what the dealer told you, and when your bumper flys off down the road make em give you a new one :D
  5. Nov 15, 2011 at 5:45 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  6. Nov 16, 2011 at 4:18 PM
    hammerman
    ohio
    thanks for the replies,the video of installation was very informative.looks so easy.tthanks all
  7. Nov 16, 2011 at 5:45 PM
    KenLyns
    Belly of the Beast
    It's easy if you have a helper or a transmission jack. The hitch weighs about 80 lb I believe.
  8. Nov 20, 2011 at 5:59 PM
    TurnTheLead
    TurnTheLead Active Member
    Mississippi
    2012 PreRunner SR5 4x2 2.7
    Rubber bed mat, Tuff Tonno cover.
    I just installed the Curt class 3 hitch, model number 13323 (the 2011-approved hitch) on my 2012 Tacoma Prerunner. I had to take the whole bumper off to get it on (not a big deal) but it fits snug and seems very secure. I ordered it from Amazon.com. It came to me in Mississippi in about 3 days with their free shipping.
  9. Nov 20, 2011 at 6:04 PM
    Oat
    Florida
    2001 Prerunner
    Nice, curt is a good brand...Pics?
  10. Nov 26, 2011 at 4:28 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    I use a class 3 hitch on my custom rear bumper on my 5 lug. works great!
  11. Nov 28, 2011 at 10:29 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I have I think a Reece hitch on mine... I didn't put it on a local trailer place did. I know the guy said the whole bumper had to come off to mount it but that's about it.
    Do it now though if you're gonna... I waited till I jackknifed a trailer into my bumper to put it on and now I have a nasty crease as a reminder.
  12. Dec 6, 2011 at 1:07 PM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    I put the same Curt hitch on my 2009 Access Cab but purchased it from eTrailer.com. I pull my Carolina Skiff back and forth across Florida with no problem. I do put the transmissin in third if it starts to hunt between third and fourth gear but am usually able to leave it in 4th. It is more of a problem with the cruise control on.
  13. Dec 7, 2011 at 8:57 AM
    hammerman
    ohio
    i did order a curt from Amazon for 133. and free shipping.had bus mechanic who rents from me put it on and he came at lunch and did it with hand sockets and was done in less than hour.you do not take off bumper on my truck.loosen only and then a spacer goes there after you in stall the hitch.looked easy and we had a video showing it put on a 2010 so he knew exactly what bolts to loosen and the 2 that came clear out.
  14. Dec 7, 2011 at 6:15 PM
    MowTaco
    Kansas
    Must differ from 1st to 2nd gen then. I distinctly remember the mechanic guy betting his service writer he could do it in a half hour (they were about 45 min from closing). Then he was like "oh man this is one of the ones that the whole bumper has to come of to mount. Oh well I still bet I can get it done in a half hour."
  15. Dec 14, 2011 at 9:37 PM
    martya
    martya New Member
    12 Pre-Runner TRD
    I just did exactly the same. I used a tie-down strap threaded through empty the backup camera slot in the body just above the bumper to hold the hitch up when I first started the bolts.
    Took me about 1 hour. Hand sockets only. Also used the Curt connector wire kit from Amazon. Really easy.
  16. Dec 14, 2011 at 9:43 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    Got mine off ebay for $160 shipped, came with everything accept the ball. Just had to have the cool plug.
  17. Dec 14, 2011 at 9:52 PM
    ACBWV91
    ACBWV91 Well-Known Member
    Adam
    Charleston/Motown WV
    08 Access Cab 4x4
    Are these aftermarkets hanging down so you can see the crossbar on the whole thing? Ive been meaning to do some searchin for some pictures to find one that all you can see is the reciever. Any suggestions?
  18. Dec 14, 2011 at 9:54 PM
    Johns Taco
    Albuquerque, NM
    All the aftermarket hitches seem to be copies of the factory Toyota ones, the place where you hook up the chains looks to be the only difference.
  19. Dec 14, 2011 at 10:05 PM
    stockplus
    stockplus Well-Known Member
    L.J.
    Way way north of Redding
    06 4x4 SR5 Access Cab
    TC, ToyTec, Boztec, All-Pro, ATO
    I bought a receiver from U-Haul (Valley brand) several years back for my '06 4-banger. Price was around $120. Very easy installation, and one of the more attractive designs available IMHO. (The horizonal "crossmembers" are unobtrusive angled round tubes that tuck away beneath the bumper.). I've hauled some heavy stuff with this receiver and it hasn't let me down.
    Good luck!
  20. Dec 14, 2011 at 10:19 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    I have the Class IV hitch from the factory but if I was going to tow with your truck I'd get a hitch. I'd never tow from the bumper. I don't care what the dealer says, it's just not a good idea. I had a U-Haul hitch on my old Ranger and it bolted right up with no modification needed at all. It worked great. If I needed on for my Tacoma I'd buy one from them again.
    Good luck with your choice and congrats on the new truck!
