Anyone been pulled over for not having mud flaps?
Discussion in 'Arizona' started by Aw9d, Apr 21, 2012.
  1. Apr 21, 2012 at 9:04 AM
    Aw9d
    Aw9d [OP] That one guy
    I knew we had a mud flap law but I never read it. Has anyone actually got a ticket for this? I've had TONS of cops behind me, none pulled me over for not having my mud flaps. Or does this not apply to me since I have not modified my suspension at all? Just curious.(read bold section)
    A.R.S. Section 28-958.01 sets forth Arizona's mud flap law:
    28-958.01. Rear fender splash guards A. A person shall not operate a truck, trailer, semitrailer or bus on a highway unless the vehicle is equipped with rear fender splash guards that comply with the specifications provided in this section. B. The splash guards: 1. Shall be attached in a manner that prevents the splashing of mud or water on the windshield of other motor vehicles. 2. Shall extend to a length of not more than eight inches from the ground. 3. Shall be wide enough to cover the full tread or treads of the tires being protected. 4. Shall be installed close enough to the tread surface of the tire or wheel to control the side throw of the bulk of the thrown road surface material. 5. May be constructed of a flexible rubberized material. 6. Shall be attached in a manner that, regardless of movement either in the splash guards or the vehicle, the splash guards retain their general parallel relationship to the tread surface of the tire or wheel under all ordinary operating conditions. C. This section does not apply to: 1. A vehicle commonly known as a pickup truck with a manufacturer's rating of three-quarter ton or less, except that this section applies if the pickup truck has been modified from the original bumper height design to raise the center of gravity of the pickup truck. 2. A truck tractor or converter dolly when used in combination with another vehicle. 3. A single axle trailer with fenders wide enough to cover the full tread or treads of the tires being protected and that extend to a length of not more than fourteen inches from the ground.
  2. Apr 21, 2012 at 9:18 AM
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    Good to know. I was about to take mine off.
  3. Apr 21, 2012 at 9:21 AM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    I thought it was for semi trucks and such
  4. Apr 21, 2012 at 10:32 AM
    Aw9d
    See from what I'm reading I think a stock tacoma doesn't require them, unless you lift it. I never understand these damn laws.
  5. Apr 21, 2012 at 10:47 AM
    1980 Well-Known Member
    The Dust Bowl
    I was driving on a road they were redoing near Aspen one summer that was covered with loose gravel and had a 45 mph speed limit. About every 200 yards there was a "Do not pass" sign, which about 40 of us were obeying. Then some yahoo in a lifted pickup truck with no mud flaps came tearing down the left lane at 70 mph and proceeded to throw rocks into everyone's windshields. I only hope that someone caught the bastard down the road and gave him the fines (or beating) he deserved.
  6. Apr 21, 2012 at 10:49 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Arizona's laws are much stricter than ours in Washington St. I think when i looked I could lift my truck 4" and run 285's and still not be required to use flaps.
  7. Apr 21, 2012 at 10:50 AM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    That's the way that I understand it. I've been running no mudflaps for about a year. Never been pulled over.... Though now that I've said that I probably will.
  8. Apr 21, 2012 at 10:51 AM
    Fightnfire
    Marysville, WA
    You are correct. A stock 3/4 ton or less pickup does not have to use flaps. If you raise the height of the truck at all, it applies and you would need to run flaps.
  9. Apr 21, 2012 at 12:44 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Ive never had an issue with all three tacos and the one jeep I've had.. my stepdads silverado 1500 that's lifted has tho. So im sure its the size and weight of the truck.
  10. Apr 21, 2012 at 1:17 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I haven't yet, and I haven't seen or heard of anyone get it yet unless it was a skyjacker. That said, to the letter of the law, I'm breaking it right now without any. Most cops around here don't seem to mind much though, in fact most seem to drool over our trucks anyway.
    Plus, I think a lot of the cops are tired of people tailgating constantly and probably figure if someone gets a rock in the face from a truck without flaps, they earned it. That's just my thought process though.
  11. Apr 21, 2012 at 4:22 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    x2 no issues with my truck, but my uncle in his huge 2500 chevy got cited. don't think he ever put em back on though :p
  12. Apr 21, 2012 at 4:36 PM
    zachc113
    zachc113 Well-Known Member
    Not sure if we have a law like that in GA but I would think it is one of those things that some counties enforce and some could care less. Like illegally tinted windows, in my town youll never get pulled over. Go twards ATL you be pulled over as soon as you get into a populated city.
  13. Apr 22, 2012 at 1:15 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    I forget the numbers, but if the rear of tire, to rear of bumper is a certain number in reference to the height of rear bumper to ground then you need flaps.
    Some states require fender flares as you can have zero tire sticking out.
  14. Apr 22, 2012 at 9:20 AM
    TacoBran
    TacoBran You're Unique, Just Like Everyone Else
    Brandon
    Peoria, AZ
    03 Double Cab 4x4 TRD SOLD, 02 Double Cab Pre-Runner
    Icon coilovers, TC UCA, icon shocks w/resi's, deaver leafs - 4x4 swap in progress
    It's all in the interpretation of the cop that pulls you over. The Az law was written when a truck was more of a semi or a flatbed. Since pick ups have become popular they need to rewrite the law. What's the difference from my lifted truck and your lifted jeep? If I have to run em but jeep guy doesn't what's the difference. He k at least I have some bed after my tire where jeep guy has nothing lol
    I used to get hit all the time in my other truck, being on 37's made it stand out more. I just put removable flaps on for wheeling
    It's just a fix it ticket anyway. It's nothing that goes on your record and most judges throw em out anyway because they realize it's a waste of time and it's usually just the police officer being picky.
  15. Apr 22, 2012 at 9:28 AM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I have 3" lift and no mud flaps (tore em up off roading). Never had any issues.
  16. Apr 22, 2012 at 11:14 AM
    Aw9d
    Good info. I've had mine off for months and never had issues. I've been pulled over a few times and they never said anything.
  17. Apr 22, 2012 at 11:24 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    That is what I read.
  18. Apr 22, 2012 at 2:31 PM
    TacoBran
    Brandon
    Peoria, AZ
    Alot don't even know about it lol usually the ones giving tickets have a hard on about it. A few Leo friends of mine say its stupid and don't wanna waste their time with something so petty there is bigger better things going on
    Sorry if any Leo's on here that give mud flap tickets get mad :D
    Also laws are to the discretion and interpretation of the Leo issuing the citation. That's why you go to a judge and can plead your case. The Leo issuing isn't ALWAYS in the right.
  19. Apr 22, 2012 at 3:26 PM
    TacoBran
    Brandon
    Peoria, AZ
    Ya your attitude deffinatly comes into play of your gonna get the book thrown at you or not lol
    Although each time I was pulled over for flaps it was for just that. Not speeding, not driving like a douche, etc. heck one time the Leo pulled me over because he had just gotten a chip in his windshield on his personal car. Needless to say I fabbed up some removable flaps for wheeling.
    Havent taken em off the DC yet either, prob won't till I make some removable ones
  20. Apr 24, 2012 at 1:50 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Had em off for years. Never an issue. Usually the cops are too busy checking out the truck and paying compliments, and I don't drive like an ass to draw attention to such petty ticket-worthy things.
