Anyone built a TPMS pipebomb?
Discussion in 'Wheels & Tires' started by Shadow3, Aug 30, 2011.
  1. Sep 25, 2012 at 12:04 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    x2 please
  2. Sep 25, 2012 at 12:22 PM
    D44boy
    D44boy Well-Known Member
    Kaneohe, hawaii
    2011 prerunner double cab
    Many of us have changed our rims with no TPMS installed. When not installed, you get an annoying warning light that comes on your dash alerting you your tires are not properly inflated. Even though they are, the computer senses no psi because there's no sensors. By putting the 4 stock sensors into a pressurized little pipe and leaving it on board somewhere (in my storage in the bed), the computer picks it up and turns the light off. An alternative to putting tape over the light or rewiring it.
  3. Sep 25, 2012 at 2:33 PM
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    I built a pipe bomb using the directions on this thread.
    Neatly stored under the seat, and no problems. Light out, and haven't had to add air to it yet. Works perfect.
  4. Sep 26, 2012 at 11:00 AM
    Shadow3
    Shadow3 [OP] Well-Known Member
    Carmel Valley, CA.
    2011 PreRunner SR5, Magnetic Grey
    Bilstein 5100 set at 1.75" Leaf Spring TSB HomerTaco Satoshi grill Brute forcefab rear bumper Sirius-XM radio Fog Light kit Wet Okole seat covers Metalmiller-Punisher
    Just to update this post: When I had my DC2 wheels and tires done, the tire company installed my existing TPMS sensors ( From the steel wheels) into my new wheels no problem. They work fine. People don't need to deal with using new TPMS sensors if they change out wheels. They may use a rebuild kit to do it, (not expensive) There is some mis-information regarding the TPMS sensors and new wheels floating around. It really is no big deal. And NO, I have not been visited by the ATF !!! (Yet)
  5. Nov 30, 2012 at 5:06 AM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    sub'd for reference. Gonna try the strap kit first.(with steel wheel sensors)
  6. Nov 30, 2012 at 5:19 AM
    CantSitStill
    CantSitStill Well-Known Member
    FTR
    CNY
    This thread makes A LOT more sense now that it is explained that it is NOT AN ACTUAL PIPE BOMB!!!
    Wish I had seen this before I did my new rims/tires and purchased new TPMS and paid the stealership to program! Eff my luck!
    Note: maybe a new title is needed for this thread. Mods??? No TPMS light with new rims?
  7. Dec 1, 2012 at 10:49 AM
    Shadow3
    Carmel Valley, CA.
    Maybe so, but not as intriguing! I am sure some people were curious and read this post because of the titile.
  8. Oct 27, 2014 at 8:16 PM
    sixdoubleseven
    sixdoubleseven Well-Known Member
    Dave
    Boston
    14 DC 4x4
    Any problems with these things bursting? Would threaded ends be more secure than the cements ones?
  9. Oct 27, 2014 at 8:21 PM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
  10. Oct 27, 2014 at 8:22 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The pipe is rated way higher than the tire pressure you would fill it to
  11. Oct 29, 2014 at 9:25 AM
    13bajaguy
    13bajaguy Well-Known Member
    Bozeman,MT
    MY 15 Tacoma
    Stock for now
    This is BA! Never heard or thought of that. Any reason you wouldnt just put the TPMS sensors in the new/aftermarket wheels(other than they are a PAIN in the winter)? Dont you need to put the spare tire in there too?
  12. Oct 29, 2014 at 2:07 PM
    boatswain
    carl
    palmerton,PA.
    I have both summer and winter tires on two sets of rims. The pipe bomb was the perfect thing for that. No TPMS in the spare on mine, but I would assume you could just leave it in the spare as long as it's carrying the same amount of air pressure as the tires on the vehicle.
  13. Oct 29, 2014 at 4:00 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    The angles on some wheel sensors are different. For my 2010, the steel wheels had sensors that wouldn't work for the OR wheels I changed to.
  14. Dec 6, 2014 at 6:29 PM
    rodney
    rodney Well-Known Member
    Toyota Sienna Mommyvan & Ford 2fitty
    that is the reason i made a pipe bomb for my truck back in 2011. all the sensors are in there packed in bubble wrap.
    daohaus and jdg like this.
  15. Sep 4, 2017 at 4:57 PM
    #35
    Harvo
    Harvo Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    Old thread revive...
    Why do you have to reset the TPMS computer when you do this? Same sensors... just moving them right?
  16. Jul 28, 2018 at 11:23 AM
    #36
    boatswain
    carl
    palmerton,PA.
    Just sold my 09 with a pipe bomb containing the TPMS sensors tucked under the seat, I ran 2 sets of rims and tires and that worked out well.
    Now here's the question: On a 2018 with the sensors set for each wheel, can 4 smaller pipe bombs be assembled and 1 sensor be placed in each one, then place one under the front drivers seat, one under the front pass. seat, and the other two either in the back corners of the cab or in the pockets in the bed, anyone try this???
  17. Jul 28, 2018 at 11:40 AM
    #37
    Clearwater Bill
    Billy
    Largo Florida
    Just pull the valve stem core. Then replace of course when ready to pressurize.
    I agree. I guess if the light goes off you'd need to follow the reset procedure, but otherwise...........
    Using your theory of position, you could never rotate tires w/o having the TPMS re-registered. Seems pretty impractical.
    I'd still put all 4 in one container.
    Remember these are battery powered. Someday (7-10 yrs?) that battery will fail, and then you'll have to decide what to do next.
  18. Jul 28, 2018 at 1:29 PM
    #38
    boatswain
    carl
    palmerton,PA.
    They wouldn't be in the tires when I rotate them, they would be in the same position and same sequence all the time in the manner I mentioned. I would also mark them as for which wheel and tire they came out of and position them accordingly in the truck, don't know if that would work though. Since they are programed for LF, RF. LR, RR, I don't know if putting them all in one container would work, it might.
    Just thinking, all in one container might work like before, I would be overriding what they are meant to do but that's ok as long as they are sending a signal that keeps the light on the dash from being displayed. If I have this right, the only reason they would need to be reset is because once the tires are rotated they would tell you that the wrong tire is low on air pressure.
    SOMEONE must have done this, or at least tried it!
  19. Jul 28, 2018 at 1:35 PM
    #39
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    Why do that? The 4 sensors are to see your actual psi per tire. No sense in doing 4 separate ones just to trick a light when you get the same effects from one tube.
  20. Jul 28, 2018 at 3:04 PM
    #40
    Clearwater Bill
    Billy
    Largo Florida
    You miss the point.
    When they are in the tire on the vehicle, you rotate tires, right? Meaning you move the position/corner the sensor is on.
    So how does it 'know' it moved positions?
    It's why I said
    What does your owners manual say in reference to the TPMS and tire rotations. That will be your clue.
