Anyone else’s bed cracking here?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mad Mark, Apr 8, 2019.
  1. Apr 9, 2019 at 12:12 PM
    #81
    la0d0g
    running for the hills
    For crawling not hauling
    97lbs seems to be the tipping point.
    Landpirate, EatSleepTacos and tonered like this.
  2. Apr 9, 2019 at 12:14 PM
    #82
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    If it were only from vibration wouldn't running a three pass mig weld at the intersection of the upright and that steel cross piece the d ring bolts reinforce it against the vibration? Or would it crack or tear above the weld instead. There is some local stress right in the same spot it seems.
  3. Apr 9, 2019 at 12:17 PM
    #83
    Troyken
    NY
    I do the same thing and I drilled the front corner drain holes out to a larger size. That helps wash out too. I have a roll up cover and bed mat.
  4. Apr 9, 2019 at 12:20 PM
    #84
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    A word of caution there. The left drain hole is right over the fuel filler neck.
    There have been at least two cases where that was nicked and leaked. Not a cheap repair.
  5. Apr 9, 2019 at 12:21 PM
    #85
    Troyken
    NY
    Good Point!!! Beware!!!!
    tonered[QUOTED] likes this.
  6. Apr 9, 2019 at 12:25 PM
    #86
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Been a problem on working trucks as long as I can remember.
    tonered likes this.
  7. Apr 9, 2019 at 12:25 PM
    #87
    MFTAF13
    MFTAF13 "If it ain't broke, fix it till it is"
    Bob
    NorCal
    13 MGM TRD OR
    Lift, sliders, skids & some other stuff.
    LOL...:sadviolin::facepalm:.
    tonered likes this.
  8. Apr 9, 2019 at 12:31 PM
    #88
    scocar
    scocar hypotenoper
    Soooooooo last decade.....
    MFTAF13 likes this.
  9. Apr 9, 2019 at 12:34 PM
    #89
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    I guarantee you I can open a bottle on mine.
  10. Apr 9, 2019 at 12:56 PM
    #90
    HiProofProducts
    HiProofProducts Well-Known Member
    NE Ohio
    2017 Tacoma TRD Sport
    Mine has less than 10k miles so I’m planning a set for preventative maintenance most likely the Cali Raised. I used a set of their lower grill LED mounts and they were a spot on fit and finish. I like that in a product/company.
  11. Apr 9, 2019 at 1:40 PM
    #91
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    It's still a truck with a base price of 26k or whatever. I've welded, cut and drilled into my truck several times already. It's not a classic collector's item. It's a truck.
    FlavorChef7, frenchee and tonered like this.
  12. Apr 9, 2019 at 1:54 PM
    #92
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm still not convinced bed stiffeners actually do anything.
  13. Apr 9, 2019 at 1:57 PM
    #93
    scocar
    scocar hypotenoper
    Ouch what do you have loaded up on that cap?
  14. Apr 9, 2019 at 1:59 PM
    #94
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That's not me, that's @tacoma16. IIRC he just had an RTT and was doing some light wheeling.
    tacoma16 and scocar[QUOTED] like this.
  15. Apr 9, 2019 at 2:03 PM
    #95
    scocar
    scocar hypotenoper
    LB or SB? Does he have anything loaded on the side tracks?
  16. Apr 9, 2019 at 2:10 PM
    #96
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    https://www.tacomaworld.com/threads/tacoma16-flat-bed-build-on-35’s.202916/page-11#post-13230440
    https://www.tacomaworld.com/threads/tacoma16-flat-bed-build-on-35’s.202916/page-12#post-13612856
  17. Apr 9, 2019 at 2:17 PM
    #97
    VegasKnights
    VegasKnights Well-Known Member
    2019 TRD Off Road 4x4 Double Cab
    the before and after bed stiffeners photos are wow.
  18. Apr 9, 2019 at 2:19 PM
    #98
    HiProofProducts
    NE Ohio
    I agree 110%
    rlx02[QUOTED] likes this.
  19. Apr 9, 2019 at 2:21 PM
    #99
    scocar
    scocar hypotenoper
    tonered likes this.
  20. Apr 9, 2019 at 2:26 PM
    #100
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It's all the same guy, I was just posting up different parts of the story so as to paint a more complete picture. Yes he had a heavy load but not any heavier than a lot of the set ups I see on here. I'll probably make myself some stiffeners at some point as a fun welding project, but still don't think it'll really do anything.
    scocar[QUOTED] likes this.
