Anyone else? Crank Shaft Position Sensor problem in the 2016 TRD Off Road
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Port9980, Dec 4, 2015.
  1. Feb 7, 2017 at 1:52 PM
    #141
    PEAKIT
    PEAKIT Well-Known Member
    UT
    24 Off Road long bed Premium Taco.
    OME 888 nitro front, SPC upper arms,B110 rear shocks, Timberen bump stops, extended brake hoses, U bolt flip, sway bar delete, Dakar HD leaf pack with extra leaf, Snug top HD shell, MobTown Skid plate, cooper Maxx 255-85-16 4:88 Nitro gears,Spider trax 1.5 spacers, AirBedz, debadge, Pro grill.
    I'm chilling at the dealer right now.
    Came in for my 2016 TRD Off Road 10k Oil change and to complain about the stupid shifting flares.
    They did the oil change and when I hopped in it to drive away it got a Crank Position Sensor code and Traction light.
    They are Diagnosing it now
  2. Feb 7, 2017 at 2:43 PM
    #142
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Good luck, hope they fix it.
  3. Feb 7, 2017 at 5:13 PM
    #143
    macdadmorgan
    macdadmorgan Clean like ammonia, Sick like pneumonia
    IG@overlandonthefly
    W-Mass
    17 TRDORMT
    Things to get me in over my head
    So Just picked up rig on Saturday. Drove it the two hours home. 17 DCSB OR MT It seems to hesitate in the mid throttle, 20-60% Range. WOT is fine and cruising is fine. Nothing crazy, but... At first I chalked it up to a new computer adapting to its world, and me being a new Tacoma owner. After 175 miles, its still there, no evident codes. Anyones rig exhibit similar symptoms before they got any warning lights, CEL?
    Thanks
    Morgan
  4. Feb 7, 2017 at 6:04 PM
    #144
    Barcared
    Barcared Well-Known Member
    Philadelphia, PA
    2016 Barcelona Red TRDOR RIP. 2020 MGM TRD OR.
    My TRDOR production date was May of 2016. talked to dealer. he said that the CPS issue was resolved by time my truck was put together. so I'm guessing your CPS is OK too?
  5. Feb 7, 2017 at 6:08 PM
    #145
    nvnv
    nvnv Stop geotagging
    Connor
    2016 Tacoma TRD OFF ROAD
    My truck died on me a few weeks ago driving down the freeway. I had it towed to the dealer but they let it sit overnight and weren't able to recreate the issue after having it for 3 days. The issue never happened again but I ended up just buying a new sensor and replacing it myself. The new sensor was a different part number from the original although the original did have that round mark on it that others have said is only on the new ones.
    shakerhood likes this.
  6. Feb 7, 2017 at 6:37 PM
    #146
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    First of all, nice avatar.
    Second, it amazes me that these trucks don't store fault codes. I'd assume the truck would throw a code for your issue. I can't see why in this day and age a dealer would even need to see it fail anymore.
  7. Feb 7, 2017 at 7:44 PM
    #147
    nvnv
    Connor
    It did throw two codes. One for low fuel pressure and one for a misfire I think. But they weren't able to narrow it down off just those codes. I did see in another thread that someone had the same codes so I'm pretty confident that was the issue.
  8. Feb 10, 2017 at 11:08 AM
    #148
    PEAKIT
    UT
    They did the 2nd version of the full drivetrain ecu Flash upgrade and It went away. I am not too confident because that would obviously erase the codes. I guess we will see if it strands me.
  9. Feb 10, 2017 at 7:16 PM
    #149
    shakerhood
    Southern Ohio
    You mean they did the Auto Trans improvement TSB or did they do something else?
  10. Feb 13, 2017 at 12:59 PM
    #150
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    FYI: CPS is only covered by 36K warranty.
  11. Feb 14, 2017 at 12:08 PM
    #151
    PEAKIT
    UT
    Something else. Already had that one
    shakerhood[QUOTED] likes this.
  12. Mar 25, 2017 at 12:24 PM
    #152
    therealitylord
    therealitylord David
    David
    Peterborough, Ontario, Canada
    2023 Tacoma TRD Pro -Solar Octane
    5" Black Step Bars, Extang Solid Fold 2 Tonneau Cover and BF Goodrich AT KO2’s
    I have been Jed to believe my CPS pooped out last night. There was no indication that it was going to go either. I stopped at a light and when the light changed to green, the truck sputtered, had no power and eventually stalled. The multi-information display stated the transmission was too hot. I tried to start the truck to no avail. I called for a tow and by the time the truck arrived, my truck had started and appeared to be fine. I towed it to the local dealership and they said it was the CPS. It's under warranty so let's see if the CPS is in fact the culprit.
  13. Mar 25, 2017 at 12:36 PM
    #153
    Friggin Fuego
    Friggin Fuego Well-Known Member
    2004 Toyota Land Cruiser, 2007 Toyota FJ Cruiser 6MT 4x4, 1988 Toyota Hilux SSR Diesel 5MT 4x4
    And the horror continues. Summer is around the corner which means more CPS fails ahead.
  14. Mar 25, 2017 at 12:45 PM
    #154
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    If you all ever leave cell service in your trucks, you had better pack a spare cps. I do.
  15. Mar 25, 2017 at 1:07 PM
    #155
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Drama queen much?
  16. Mar 25, 2017 at 1:08 PM
    #156
    swimmer
    Tucson
    2016 TRDORAC4WD
    '16 or '17?
  17. Mar 25, 2017 at 1:12 PM
    #157
    Friggin Fuego
    The drama brings itself. You know these CPS issues are a common issue.
  18. Mar 25, 2017 at 1:20 PM
    #158
    swimmer
    Tucson
    2016 TRDORAC4WD
    I know two things.
    1.that I replaced mine by myself last year to the revised part to avoid any problems.
    2. You don't own or plan to own a 3rd gen taco and your posts are all related to criticizing the vehicle. And people can draw their own conclusions on the type of person who does that.
  19. Mar 25, 2017 at 1:27 PM
    #159
    Friggin Fuego
    1. You spent your own money as a preventative action due to known issues.
    2. You are absolutely correct.
  20. Mar 25, 2017 at 7:49 PM
    #160
    shakerhood
    Southern Ohio
    Hope it does not happen on the 17s at all.
    Friggin Fuego likes this.
