Anyone else experiencing unstable driving?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jrotts, Apr 5, 2009.
  1. Apr 5, 2009 at 8:45 PM
    jrotts
    jrotts [OP] Member
    2008 Tacoma Double cab 4X4 TRD Off Road
    Leveling kit, bug shield, spray-in bed liner
    I have an 08 4-door short bed. I have 265/75-16 Nitto terra graplers. This truck seems very unstable on the roadway. The slightest gust of wind or uneven road and my truck will go were it wants to. I aligned the the truck when the new tires were put on. I have about a 1000 miles on the new tires. About 12,000 on the truck. Any advice?
  2. Apr 5, 2009 at 8:47 PM
    sbeau1960
    sbeau1960 Well-Known Member
    Scott
    Indianapolis
    09 Tacoma Double Cab TRD Sport Pyrite Mica
  3. Apr 5, 2009 at 9:18 PM
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
    Only when I've been drinking.
  4. Apr 5, 2009 at 9:26 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    make sure your tire pressure is at or below 35psi for starters. I like 32psi.
  5. Apr 5, 2009 at 9:27 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    mine did the same thing when i put the bfg at's on, had to get it aligned twice, no more wondering.
  6. Apr 5, 2009 at 9:59 PM
    BONES
    BONES Well-Known Member
    SoCal
    06 PreRunner SR5 w/TRD Offroad pkg
    AFE 'Pro-Dry S' OE air filter, Westin bull-nose guard & side steps, TSB leaf pack, TSB intake-hose, rubber bed mat, Bridgestone Dueler A/T Revos, Stubbie 21" antenna, Goodridge G-Stop s/s brake lines
    I've found that if the pressure is too high in the front tires, the front end feels like it's floating at highway speeds. I go by my doorjamb sticker now: 29lbs/front & 32lbs./rear, I think. No more wandering on the highway ever since. Btw, I run A/T Revos.
  7. Apr 5, 2009 at 10:07 PM
    darkturtleninja
    darkturtleninja 9th level dungeon master
    Illinois
    95 2.7 3rz turd
    cold air intake, body lift, suspension lift.
    i think it is just because the tacoma's are light trucks.... immagine how mine does in the wind....
  8. Apr 5, 2009 at 10:14 PM
    aaronk
    aaronk Well-Known Member
    2009 Dbl Cab V6 TRD
    Dueler A/T Revo's here at 32psi all around with stock suspension.
    In a cross wind it's no fun to drive, but otherwise mine seems to track OK. Well worn pavement (the kind with the tire track gulleys) is difficult to keep it tracking straight, but no more so than the other cars I've driven.
  9. Apr 5, 2009 at 10:21 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    It may be the tires. I had BFG G-Force tires on my truck and the tires would grip any ruts in the road. If you didn't have a tight grip on the wheel at all times, it would yank it out of your hands when I would hit ruts in the road. Alignment didn't help. It is the nature of the tires. When I changed my tires to Nitto NT's and the problem went away.
  10. Apr 6, 2009 at 5:30 AM
    sbeau1960
    Scott
    Indianapolis
    Discussing this in two threads, check out the link above as well. Do you guys both have C-rated Revos or are they P-Metric? Are they stock size or 265/75R16? I'll try lowering my tire pressure again to see if that makes a difference, currently running at 40psi, but I tried that when I first got the suspension and tires done and thought it didn't feel right.
  11. Apr 6, 2009 at 6:03 AM
    bajamoon
    STEVE
    Whittier
    my brg's run good at 35 and 40 psi, the max is 50psi, but i have 17's, just play around with your tire pressure and see how it goes.
  12. Apr 6, 2009 at 7:12 AM
    TacoTime
    TacoTime New Member
    2009 DC Sport Black
    I hear exactly what you are saying. I just traded my new 09 DC Sport in for a new 09 4Runner Sport Edtion.
    The Tacoma was just far too unstable. I was constantly correcting the steering - at times, having to use both hands to just keep it in its lane. Kinda felt like I was a bull rider at a rodeo...lol... On smooth roads it was fine, but with the winters we have in Wisconsin - there are few, if any, smooth roads.
    In the city and for short highway trips it was OK, but we have some road trips planned for later spring and summer and there is no way I would want to be fighting this for 100+ mile trips.
  13. Apr 6, 2009 at 7:18 AM
    sbeau1960
    Scott
    Indianapolis
    Well that's not very encouraging. Your description matches my experience exactly and it was not fun to fight for an 800 mile round trip. Are the 4-Runner and Tacoma front suspension the same? If so, then is it the lighter weight of the Tacoma that causes this issue? Wonder if installing a bed shell would help by adding weight?
    Is this the unspoken achilles heel of the 2nd gen Tacoma? I'd like to hear from more people that DON'T have this issue and what setups they're running.
    Not trying to hijack your thread jrotts, we're both searching for the same answers.
  14. Apr 6, 2009 at 7:43 AM
    Joe B
    Joe B Well-Known Member
    :confused:
    I have a '09 TRD Sport DC and haven't found anything unusual with the ride characteristics on any types of roads.
    Also did a 500 mile trip and a few 100 miles trip and found the truck to be like any other truck or SUV.No problems at all.In fact the ride was pretty comfortable for a truck and that's with a more aggressive stock size all terrain Silent Armor tire.
    After reading sbeau1960's thread,I'm leery about going with 5100s at .85 now like I had planned with an appt for the install next Monday.
  15. Apr 6, 2009 at 7:57 AM
    TacoTime
    TacoTime New Member
    2009 DC Sport Black
    Hi Sbeau,
    Yeah - the suspension is different on the 4Runner.
    I responded to a post last week here about the same issue. It was recommedned that I take it to the dealer to check the alignment. So, I went to the dealer and they tested it and the alignment was fine. Which didn't surprise me, because on smooth flat roads, it was fine - no pull in either direction.
    While I was waiting at the dealer and chatting with the salesperson, he mentioed that if I wanted a more stable ride, maybe I should test the 4Runner. I did just that and it was a night and day difference. I actaully went about 20 miles on the freeway (something I should have done with the Tacoma before purchasing). Being that they are both 'body on frame' trucks, I was really surprised that they could ride so differently. In the 4Runner I feel very secure and connected to the road. When I look back to check my blind spot, it holds its lane well. I am just not fighting it like I had to with my Tacoma. It seems to want to go straight and hold a line on its own. I don't need to keep both hands on the wheel and correct steering every couple of seconds.
    The main reasons I wanted the Tacoma were for the solid frame toughness and durability and towing ability and off-road ability. I find that the 4Runner gives me all that and a safe and secure feeling ride, too.
    By the way, my setup on the Tacoma was completly stock. 09 Double Cab TRD Sport package.
    Tacoma's are great trucks, with many hundreds of thousands on the road, so I am sure people manage just fine with them. Maybe bed caps, different tires, suspension, etc... could improve the stability. For me, though, the easiest and best way to resolve the issue was the trade.
  16. Apr 6, 2009 at 8:04 AM
    cyantucaz
    cyantucaz Member
    Vail, AZ
    07 4x4 Quad Cab
    5100'S ALL AROUND WITH 885 COILS AND LIGHT RACING UCA UP FRONT. 1.5 AAL IN THE BACK. SPIDERTRAX SPACERS. IPOD ADAPTOR. SEXY WIFE IN THE PASSENGER SEAT!!
    I have an '07 and its starting to sway a little bit. I have 52k on it and 2" blocks in the front. I was thinking, after reading the negatives on spacers in the front, that was the problem for me. I ordered some 5100's and, depending how everthing looked when i was installing them, that i might replace my uca's.
  17. Apr 6, 2009 at 8:05 AM
    cyantucaz
    cyantucaz Member
    Vail, AZ
    07 4x4 Quad Cab
    I have the same tires and size as you too...
  18. Apr 6, 2009 at 8:10 AM
    sbeau1960
    Scott
    Indianapolis
    Thanks for the detailed history of your experience. I'm wondering if it's just a common characteristic of some Tacomas and my suspension and tire combo has exaberated the problem.
  19. Apr 6, 2009 at 8:28 AM
    jrotts
    jrotts [OP] Member
    So anyone and everyone throw out ideas on how to remedy the problem. Specific values for the alignment. I never took any interest in those values but maybe it is time. As far as tire pressures I started out at 40psi. Then went to 38psi and currently at 35psi. This is a tire rated for 45psi. Terra graplers D-rated 265/75-R16. I wrote Nitto twice asking for tire pressure recommendations based on truck weight and no response from them.
  20. Apr 6, 2009 at 9:11 AM
    sbeau1960
    Scott
    Indianapolis
    Posted my alignment specs in the other thread...http://www.tacomaworld.com/forum/2nd-gen-tacomas/32862-alignment-advice.html#post515163
