Anyone else experiencing unstable driving?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jrotts, Apr 5, 2009.
  1. Apr 6, 2009 at 9:43 AM
    tacomajason
    tacomajason the anti mpg
    Arkansas
    09 ssm ac oc 6mt 4wd
    stock (for now)
    it drives like a light weight truck with stiff suspension. i am on my second 05+ taco. first was a base 4x4 single cab, now i have a 09 access cab trd off road. they both drive about the same. you guys gotta remember, these aren't cars.
  2. Apr 6, 2009 at 9:58 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    I am still running the rugged trails, did the 5100's at 1.75 this weekend. I drove it to the dealers Sunday night got it up to about 55 at the highest but it tracked great with no alignment yet.
    Just my opinion but any amount of air pressure over 35 seems really high to me...
  3. Apr 6, 2009 at 11:21 AM
    JAG
    JAG Well-Known Member
    With the way the wind is now... I feel like I am getting thrown all over the road. I am doing about 70 mph on 40 psi. Maybe I will try bumping it down to 32 psi; however, I think it is just the strong gust of winds.
  4. Apr 6, 2009 at 11:31 AM
    sbeau1960
    sbeau1960 Well-Known Member
    Scott
    Indianapolis
    09 Tacoma Double Cab TRD Sport Pyrite Mica
    I've had several 4x4 vehicles including small pickups and I still have a 1994 Toyota 4x4 pickup that is quite a bit stiffer, quite a bit taller, and quite a bit lighter than this Tacoma. The '94 does not exhibit these characteristics, not did any of my other pickups to this extent.
    I was running 40psi because I have C-rated Revos with a 50psi max rating and the tires felt best at that pressure. I lowered them to 32 front, 34 rear today and will try that, although it makes it handle more sluggishly.
  5. Apr 6, 2009 at 2:01 PM
    kbaum08
    kbaum08 Well-Known Member
    US of A
    09 trd off road dbl cab 4x4 barcelona red
    Jason Topper, Bed Rug, Weather Tech floor liners, Garmin Nuvi 760, Scan Guage, Trd exhaust, AFE dry air filter, shrockworks rock sliders, heated seats Katzkin leather, 2+ inch OME lift shocks etc heavy duty, ARB front bumper, Warn winch, Pia lights, rocktek rear bumper, locking tailgate,
    You need more air pressure if you are running LT instead of passenger tires, there is a write-up on this somewhere. Less air pressure likely worse with wind but may tend to track uneven roads itself worse. I run LT revos with 45 pounds air pressure and my truck rides great and the wind is almost always blowing here.
  6. Apr 6, 2009 at 2:06 PM
    sbeau1960
    Scott
    Indianapolis
    Hmm, maybe I should be airing them up more instead of lowering the pressure. People say both things, high air pressure will make the tires follow ruts and wander, low pressure will do the same. Guess I just have to keep experimenting and see what works best with my set up.
  7. Apr 6, 2009 at 2:14 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    Im running BFG AT's also, it wanders a bit with the high winds, but other than that it's ok - i can stay straight with 2 fingers on the wheel most of the time
  8. Apr 6, 2009 at 3:26 PM
    Boomer34
    Boomer34 Active Member
    Pensacola, FL
    07 DC TRD Sport
    When my Taco was new with stock Bridgestones H/T's 265/65/17 (Passenger tires), smooth with no tracking on the roads...
    With the rear leaf TSB and 5100 (front only set at 1.75) little taller than stock, overall good, but still pretty smooth with the stock tires.
    With the new BFG A/T's 265/70/17's (which are talling than the stock tires - that with the TSB/5100 added a good 2 inches in lift) tends to track a little more... however still easy to drive, personally I thinks its the bigger and taller you go on tires you are going to have this happen.
    I had a Ford Explore sport trac that was horrible - got about 15 mpg and (with everything stock) it tracked all over the road and with even a hint of wind it got pushed around a lot! This is by far THE best truck, NAY the best vehicle I have ever owned!
    By the way, seems everyones talking about it being windy - wonder if that's all over the country - pretty windy here in Pensacola, FL (over 20 knots)...
  9. Apr 6, 2009 at 4:16 PM
    Phantom_X-SP
    Phantom_X-SP Rude Boy |><|
    High Point, NC
    08 DC Black Sand Pearl X-SP
  10. Apr 6, 2009 at 4:16 PM
    kbaum08
    US of A
    Heading to the Pensecola area in about 10 days, please turn off the wind.
  11. Apr 6, 2009 at 4:28 PM
    Joe B
    Joe B Well-Known Member
  12. Apr 6, 2009 at 5:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    My truck tracks stright. Im running 285 width tires, 3" lift, and TC UCA's. Wind is an issue when on the highway, but the truck is light. If the road is uneven, the tires want to follow a little bit, but nothing one hand cant control. My 2000 Tacoma was the same. Drove nice and straight, except when very windy.
  13. Apr 6, 2009 at 5:23 PM
    aaronk
    aaronk Well-Known Member
    2009 Dbl Cab V6 TRD
    P metric 265/70/16 Revos here.
    I also had a 1994 Toyota Pickup prior to my 08 and I was actually running 31" LT tires on it. Haven't really noticed a difference between the two except that the 94 didn't seem to have all the feedback in the steering wheel, while it feels like every little bump in the road is transferred through the steering wheel on my 08.
  14. Apr 6, 2009 at 5:26 PM
    Boomer34
    Pensacola, FL
    07 DC TRD Sport
    Yeah, agree, my Taco is still very easy to drive. A friend of mine has a Jeep Rubi, with a 6in lift and huge Goodyears, great for off-roading, but not so good on the road.
    Hey Kbaum, it should hopefully calm down, we just had a front come through. The biggest thing that sucks about it is that there's been a red flag at the beach everytime i call for the surf report, good waves, but real choppy.
    What you going to be doing inP'cola?
  15. Apr 6, 2009 at 5:28 PM
    #35
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Give it a day or two...it'll change and then change back...It's still nice down here either way.
  16. Apr 6, 2009 at 5:31 PM
    #36
    Boomer34
    Pensacola, FL
    07 DC TRD Sport
    Hey Brunes, where are you stationed at for the CG? Unfortunately I'm up at Whiting, wish I was down at Main side - closer to the Beach (easier to ditch work and head out surfing).
  17. Apr 6, 2009 at 5:37 PM
    #37
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I'm up Whiting too...VT-6 SNA for Primary. I live in North Pensacola off Davis.
    I hear you on ditching work to hit the beach tho...It's nice to get the good days!!
  18. Apr 6, 2009 at 5:44 PM
    #38
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    The wind is very strong here today and, sure, it was bobbing about on the road but I've never owned a truck that didn't in this kind of wind. In normal weather, not one problem. These trucks ride very well compared to others I've owned.
    In the end, it has the aerodynamics of a brick so what can anyone really expect to happen in strong wind.
  19. Apr 6, 2009 at 5:46 PM
    #39
    Boomer34
    Pensacola, FL
    07 DC TRD Sport
    Brunes, Yeah, i live just off Spanish Trail, had to compromise half way between beach and work... Man I gotta tell ya, you made the right choice with CG. I've got a lot of friends jumping ship (Navy) - no pun intended to go over to the CG. thinking about it myself...
    sorry didn't mean to hi-jack the thread...
  20. Apr 6, 2009 at 5:49 PM
    #40
    Brunes
    Brunes abides.
    Rotorhead
    Around
    you've got a PM!!
