Anyone else have a squeaky clutch pedal?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RustysTaco, Jul 14, 2017.
  1. Dec 28, 2019 at 3:23 PM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    I use a small tube of white lithium grease to lube mine every time I change the oil (5kmi intervals).
    Three places- spring pivot bushing, pedal at spring wire, pedal at push rod.
    I have to use a mirror to see the top of the push rod, and then I put a big dab of grease in front and use my finger to force it up into the cavity. Seems pretty successful so far.
    (I'm only using white lithium because that's what Toyota calls for. If I ever need the pedal replaced I don't want the dealer to give me a hard time...)
  2. Jan 2, 2020 at 11:41 AM
    Kinetic
    Kinetic Well-Known Member
    Kent
    Boerne, TX
    2019 Black Tacoma Off-Road
    Needed this. That squeaking had to stop!
  3. Jan 2, 2020 at 11:44 AM
    Rebelman21
    Rebelman21 Well-Known Member
    Cleveland
    2021 SR5 DCSB Super White
    None yet, several planned
    Mine squeaked and the dealer lubed it up some. That lasted a while then it started again, but not that bad. After telling the dealer about it they replaced the clutch pedal assembly. Seems great now.
  4. Jan 2, 2020 at 11:47 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Did you get the revised TSB with updated parts? Apparently its been updated in the past few months...I had mine replaced over a year ago and its been fine up until a few months ago, i haven't greased it at all hoping it gets bad i'll make an appt with my dealer before my warranty period is up to have them look at it again
  5. Jan 2, 2020 at 11:55 AM
    Muddycoinwash
    Muddycoinwash Well-Known Member
    2015 TRD OR access, 2000 4x4 reg
    I have had clutch peddle noise problems with every single MT taco I've owned. Starting with my 95, 04, and 2015. Most were taken care of under warranty and never made the noise again. The 2000 I recently pick up does it too. I have found fixes here on TW, just need to take the time and do it. Would have been nice if factory engineering would have fixed this 25 years ago.
  6. Jan 2, 2020 at 12:02 PM
    DESportTRD
    DESportTRD Well-Known Member
    2017 Blazing Blue Pearl DCSB Sport 4x4, MT
    Had my clutch pedal linkage and slave cylinder replaced at the dealership at 15K. Never had another issue..., now at 25K and still no more issues.
    Get the service writer to document the issue. Applying white grease, or brake pad anti-seize will only mask the problem for a short period of time!
  7. Jan 2, 2020 at 12:02 PM
    DESportTRD
    Last thing...get it done while you are in warranty.
    Muddycoinwash likes this.
  8. Jan 2, 2020 at 12:03 PM
    Muddycoinwash
    What he said ^
  9. Jan 2, 2020 at 12:05 PM
    TacoJeff19
    TacoJeff19 Well-Known Member
    Jeff
    19' DCSB OR
    OVtune, ADM, Hurst Short Throw.
    I use silicon spray grease on mine and it works fantastic
  10. Jan 2, 2020 at 12:07 PM
    Tacowin1013
    Exactly, thats why i haven't tried this time to re-grease anything because i want it to be annoying for my test drive. My 3 years in service comes up in March
  11. Jan 2, 2020 at 12:08 PM
    DESportTRD
    Yep....get it done.
  12. Jan 2, 2020 at 12:09 PM
    Muddycoinwash
    15k seems to be the magic number. My first 2 were still under warranty at the time. My 2015 was a month out of warranty and the cost was going to be around $600. After a lot of BS with Toyota USA, they picked up the cost of the parts, I paid labor. Definitely get it fixed while still under warranty.
  13. Jan 2, 2020 at 12:10 PM
    Rebelman21
    Cleveland
    The sheet references TSB T-SB-0112-19. I hope that is the one with updated parts! It was done on 12/4/19.
    6MTPro likes this.
  14. Jan 2, 2020 at 1:00 PM
    DESportTRD
  15. Jan 2, 2020 at 1:07 PM
    #35
    DESportTRD
    Ok... sorry about the pics not showing up above. Please look here by scrolling down. Good Luck with your dealer!
    DESportTRD [OP]Well-Known Member
    Today, I decided to keep my appointment with my dealer and had them changeout the necessary parts as outlined in TSB-0186-12 to rid the squeaking and creaking in my clutch pedal. My mileage was 18,360 miles.
    The repair service took 4 1/2 hours. The following is a list of parts changed out:
    Part #. Description
    SPO 31420-60032. Master Cylinder Assembly
    SPO 31311-04020. Pedal Cutch Assembly
    SPO 31434-60010. Hose Clutch Reservoir
    Work done:
    R&R Clutch Pedal Sub-Assembly, Clutch Master Cylinder Assembly, and Clutch Reservoir Hose.
    Major difference. My clutch pedal Assembly “never” worked this smooth!
    No hint of any noise. Now will this last for the next 100K, only time will tell. Here are some pics of the new parts and/or assemblies.
    I hope this info will help others!
    [​IMG][​IMG][​IMG]
    2017 Tacoma Sport wheelsrjk
  16. Jan 2, 2020 at 1:13 PM
    #36
    DTaco18
    Anyone know if the updated TSB actually has updated parts? Or did they just extend the model years covered?
    Previously, they were just installing new parts that were exactly what they were taking out. I didn't see a point in having the dealer do that when I could lubricate the assembly myself.
    If there is an updated design then I need stop lubing it so that it gets noisy before the warranty is up...
  17. Jan 2, 2020 at 1:18 PM
    #37
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    Yes there are updated parts. Not sure if Toyota has started to install them out the gate on the 2020's or if they cross their fingers and only fix as needed.
    Here is the link to the revised TSB with additional information from members if anyone needs it for reference: https://www.tacomaworld.com/threads...-tsb-t-sb-0112-19.635065/page-8#post-22370986
    tonered likes this.
  18. Jan 2, 2020 at 1:19 PM
    #38
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    This TSB is new and installs new parts:
    Here is a thread that gets into the weeds on the new parts:
    https://www.tacomaworld.com/threads...-creak-noise-revised-tsb-t-sb-0112-19.635065/
    6MTPro likes this.
  19. Jan 2, 2020 at 1:28 PM
    #39
    DTaco18
    Hmm... Those are the same part numbers listed on the old TSB...
    31311-04010
    31311-04011
    31311-04012
    31311-04020
    EDIT: There is a new part number for the assembly - 31311-04021... See post 41.
  20. Jan 2, 2020 at 2:09 PM
    #40
    brian2o0o
    brian2o0o Well-Known Member
    South Carolina
    2016 Quicksand TRD off-road
    ARE Cx HD camper shell 2” lift OME 887s with 5100s Weathertechs Bartact seat covers CVT RTT CVT awning Prinsu Cab rack Dometic CFX40 fridge/freezer Decked drawers SOS Concepts sliders SOS Concepts rear bumper/swingout Body Armor front bumper Superwinch 10k winch Lots of MESO and other smaller stuff
    My 2014 had the same squeak, i just sprayed it with silicone spray every couple of months.
