Anyone else here gut the engine bay of most sheet metal?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 5efvz, Sep 20, 2022.
  1. Sep 20, 2022 at 7:09 AM
    5efvz
    5efvz [OP] Well-Known Member
    Came across this video here of a PreRunner cage build: https://youtu.be/F2-pbRgFVpo?t=1502
    Any tips? I'm not going to be putting in tubes, but I guess as long as anything that currently sits on fender sheet metal, as long as it's secured to another stable point, should be okay.
    How would I go about getting rid of the very front end sheet metal? The radiator is attached to it. At what point will it start loosing strength?
  2. Sep 22, 2022 at 5:49 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Sheet metal is one of the most efficient ways to build a metal structure, start cutting it up and you lose integrity fast and probably in ways you didn’t expect.
    TACOTU3, SwampYota, 5efvz[OP] and 4 others like this.
  3. Sep 22, 2022 at 6:01 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    If you need to ask you shouldn't do it.
    5efvz[OP] and Wulf like this.
  4. Sep 22, 2022 at 6:03 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    40s n tons
    You're finally headed in the right direction
    Jakuku Pahwheenis and 5efvz[OP] like this.
  5. Sep 22, 2022 at 6:09 PM
    0xDEADBEEF
    5efvz[OP] likes this.
  6. Sep 22, 2022 at 6:10 PM
    02hilux
    Planet: EARTH
    Why and for what reason?
  7. Sep 22, 2022 at 6:10 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :evil:
  8. Sep 22, 2022 at 6:13 PM
    02hilux
    Planet: EARTH
    I have hole(s) everywhere. Tire well to engine bay, the cab, and my bed.... maybe I can patch em up. :lalala:
  9. Sep 22, 2022 at 6:16 PM
    Clearwater Bill
    Billy
    Largo Florida
    Then you shouldn't hack out sheet metal.
    The tubes are used for increasing strength and that allows sheet metal removal.
    If you just remove sheet metal, what's left will eventually flop like a limp dishrag.
    Dm93 and 5efvz[QUOTED][OP] like this.
  10. Sep 22, 2022 at 7:36 PM
    5efvz
    weight reduction
  11. Sep 22, 2022 at 7:52 PM
    02hilux
    Planet: EARTH
    10 seconds truck?
    Dm93 and zero4 like this.
  12. Sep 22, 2022 at 7:55 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Sorry but... :rofl:
    Weight reduction for what? Building a drag truck or for auto cross?
    I hope you don't say for mpg. :laugh:
    CrustyTaco, Dm93 and 02hilux like this.
  13. Sep 22, 2022 at 8:07 PM
    0xDEADBEEF
    The whole bed weighs 200 lbs. I doubt you'd save more than 50 cutting up the front end, and probably create headaches in the process.
    Dm93 likes this.
  14. Sep 22, 2022 at 8:28 PM
    5efvz
    fuel is getting expensive.
  15. Sep 22, 2022 at 8:43 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Front is sort of a hybrid unibody construction..
    The inner fenders - out fenders - and front end all bolt together to form a sort of box construction...
    You can get rid of all that.....if you build steel tube frame around all that in its place....
    should be able to do it for $2k or $3k ........wont save no gas.....but if threaten by a deer....your ready....
    You'll find a lot of these with front end crashes rebuilt.....
    the trucks with moderate rear end hits.....usally get totaled....
    Sterling_vH111 likes this.
  16. Sep 22, 2022 at 8:47 PM
    02hilux
    Planet: EARTH
    Lol. Move. That's cheaper
  17. Sep 22, 2022 at 8:47 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Gutting & cutting off a bunch of stuff ain't gonna make your fuel expense much cheaper. Fuel is just gonna keep getting more expensive. Gotta pay to play.
    Don't wanna pay for fuel, buy a hybrid, Tesla, or some other electric car.
    TACOTU3 likes this.
  18. Sep 22, 2022 at 8:47 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If you want MPG's get a Prius or other hybrid vehicle, there's very little MPG to be gained by shedding a few pounds of sheet metal at the expense of the loss structural integrity not to mention hacking up a perfectly good truck.
    KdF likes this.
  19. Sep 22, 2022 at 8:50 PM
    O'Silver_Taco
    MD
    My bro's prius is getting 67 mpg between work/home.....
  20. Sep 22, 2022 at 9:05 PM
    5efvz
    time to look up a prius engine to tacoma body swap
