Anyone ever remove the interior from the back???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Minnetacoma, Apr 29, 2014.
  1. Apr 29, 2014 at 11:04 AM
    Minnetacoma
    Minnetacoma [OP] Well-Known Member
    Elliott
    Minnesota
    96 tacoma sr5 with oe sunroof
    3.5 fabtech suspension lift with dirt logic shocks, Wheelers Alcon 8 pack rear leafs with extended brake line All pro rock sliders Cbi DIY front bumper with m8000 winch Cbi bushmaster 1.0 non swing arm 33x10.5 BFG mud terrains Skid row front skid plate Trs headlight retro fit fxr 2.5in projectors with rbg halos Audio/electrical upgrades K2 73ah lithium battery Big 4 upgrade 300a Ohio generator alt Alpine type r 6.5 coaxials in front Alpine type s 6.5 coaxials in back Alpine double din touchscreen Digital designs z3 15” subwoofer Digital designs m4 amp Alpine ktp 445u behind the dash amp for speakers 152db
    Getting ready to tear down for murdermat install.... And wiring... But it's really looking like a headache compared to everything else I've done!?!?
  2. Apr 29, 2014 at 11:10 AM
    Madjik_Man
    Colorado Front Range
    Do you have an extra cab or regular cab?
    I did it on the regular cab and it takes about ten minutes to take it all off. Just get a panel/trim removal tool if you want to eliminate breaking many (if at all) clips.
    I'll dig up the pdf that shows how to remove it all. You have to start with the plastic trim piece over the padding on the rear wall. Then remove the padding, and work your way down...
    • remo.pdf
      File size:
      12.8 KB
      166
  3. Apr 29, 2014 at 11:13 AM
    Madjik_Man
    Once you remove all the stuff off the rear wall, you can remove the rear quarter panels.
    Pretty self explanatory when you're looking at it. Window hinges, coat hanger/hook, pop the seat belt brackets out and feed them through the hole...
    Then it's a matter of a bunch of clips holding it on.
  4. Apr 29, 2014 at 11:27 AM
    Minnetacoma
    Elliott
    Minnesota
    Xtra cab sr5
  5. Apr 29, 2014 at 11:29 AM
    Minnetacoma
    Elliott
    Minnesota
    Got any more of those that's quitehelpfull
  6. Apr 29, 2014 at 12:27 PM
    exminnesotaboy
    exminnesotaboy Well-Known Member
    Maple Grove, MN
    01 Tacoma 4x4 V6 SR5 TRD Xtra Cab
    Bilstein 5100's / OME 881's / Wheelers 5 leaf pack / Level8 MK6/ 265/75-16 Bridgestone Dueler tires
    the panel removal tool is a must. I would also get a good small mat roller tool - not required, but helps a lot.
    Once in there, this is a good time to replace your window latches if they are broken. You can also replace speakers easily.
    One thing I remember when installling my dynamat: it was difficult to get some of the side panel studs to 'click' into the holes unless you trimmed the mat around the holes about a 1/2".
    Links to tools mentioned above:
    http://www.amazon.com/Lisle-35260-P...id=1398799403&sr=8-5&keywords=trim+panel+tool
    http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias=aps&field-keywords=dynamat roller
  7. Apr 29, 2014 at 12:47 PM
    Madjik_Man
    Here, this should be very helpful
    • remo.pdf
      File size:
      22.4 KB
      117
  8. Apr 30, 2014 at 6:30 AM
    Minnetacoma
    Elliott
    Minnesota
    Thanks for the help
  9. Apr 30, 2014 at 7:26 AM
    Madjik_Man
    Any time.
    Just come back to this thread if you're in the middle of the job and need help.
    Like I said though, it's pretty self-explanatory once you start the project.
  10. Apr 30, 2014 at 1:46 PM
    Minnetacoma
    Elliott
    Minnesota
    I already tore it all apart and wired all through for my amp I completely removed the passager side rear seat for the box amp will be mounted either on the box or under the back cushion behind the drivers seat....
  11. Apr 30, 2014 at 6:28 PM
    jdkilroy
    jdkilroy Well-Known Member
    Jon
    Southern NH
    '02 4x4 SR5 Access Cab
    Systematic disassembly. Take notes and pics to keep it in order for reassembly...
