Anyone ever see this tire/lift combo
Discussion in 'Wheels & Tires' started by ramitdammit, Jun 6, 2008.
  1. Jun 6, 2008 at 3:21 PM
    ramitdammit
    ramitdammit [OP] Member
    Apple Valley CA
    06 4x4 dbl cab snugtop super sport
    I just had the rear leaf TSB done. With the weight of my shell I only only need an 1 1/2" coil spacer up front to level it out. I found an alumunium spacer that claims to do just that. I know I can run 265/70/17's stock. My Question is has any one tried a 275/70/17. I'm thinking they will work with an 1 1/2" lift. A 265/70/17 measures 10.7 wide and 31.9 tall. A 275/70/17 measures 11.2 wide and 32.4 tall.
  2. Jun 6, 2008 at 3:24 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i'd be worried about those rubbing the UCA when width and height are being gained...that is if ur talking about stock wheels
  3. Jun 6, 2008 at 3:42 PM
    ramitdammit
    Apple Valley CA
    Yes, stock wheels will be used. What about a wheel spacer. What size and type has any one tried. I've seen the narrow ones that slip over the studds before the wheel goes on and the bolt on type.
  4. Jun 6, 2008 at 5:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    My neighbor is running that size on his FJ and he seems to have plenty of room. He isnt running a lift, either. Have the tire shop do a test fit.
  5. Jun 7, 2008 at 12:01 AM
    Route66Taco
    Route66Taco Well-Known Member
    Rolla, MO
    Silver Tacoma
    Hey ramitdammit hurry and get that spacer kit. ;)
    Your neighborhood SA
  6. Jun 8, 2008 at 7:22 AM
    Jumpmaster
    Jumpmaster Proudly Serving
    USAG Humphreys, Korea
    Route66,
    Love the look/stance of your access cab. What size lift do you have and what are the specs on your tires? How do you like the 16" TRD wheels? I saved a couple pics of your ride for future referance.:thumbsup:
  7. Jun 8, 2008 at 11:50 AM
    Route66Taco
    Rolla, MO
    Silver Tacoma
    Thanks a lot. The wheels fit the truck great 265/75/16 IMO. Silver/Silver. The "Lift" is just a 2.5" spacer kit I found on ebay for $60. later
  8. Jun 8, 2008 at 1:00 PM
    Jumpmaster
    Good deal man, I am planning on going w/ the Bilstien 5100 (all around) to get the 2.5" up front. I had them on my FX4 and they really helped out with handling (nose dive, firmness, and leaning w/turns). Good wheel/tire package you have. Thanks for the info.
