Anyone figure it out yet?
Discussion in '4 Cylinder' started by xA101x, Jan 10, 2012.
  1. Jan 10, 2012 at 6:51 PM
    xA101x
    xA101x [OP] Well-Known Member
    AJ
    Florida
    Has anyone figured out the bench seat to bucket swap in the 10-12 yet? I saw online you can get the 2012 reg. cab with buckets but when I went to go buy one I found out thats only with the auto and im looking to get the manual.
  2. Jan 13, 2012 at 12:17 PM
    motoretro
    motoretro Well-Known Member
    Michigan
    09 Reg, Cab, 2.7 Four Cyl. manual trans
    Did you try building in another sales region using different zip code? Lot's of differences depending on where you live.
    Good luck,
    Motoretro
  3. Jan 13, 2012 at 12:28 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    xA101x, See if you can build online or find a dealer with a regular cab with a "SR5" package.
    If that fails, then it should not be a major task to swap out bench seats for buckets. Find a set of buckets seats at a salvage yard. I expect your truck will have all 4 holes drilled for the buckets seat mouints on each side already there, if not, drill 2 holes and use large washers underneath.
  4. Jan 13, 2012 at 1:58 PM
    motoretro
    Michigan
    If I'm not mistaken, you need to search for 09-12 buckets as I believe they have the side airbags built into them.....Check on this to make sure.
    Motoretro
  5. Jan 13, 2012 at 2:11 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    That's what I always heard. I really considered a regular cab stick, but my wife is really short, and had she driven us (as she sometimes does) I would have been jammed into the dash. Wish Toyota would make the buckets an upgrade option.
  6. Jan 14, 2012 at 10:20 AM
    xA101x
    AJ
    Florida
    I tried that and I also tried to find one with an SR5 package. The SR5 isn't offered in the RC models anymore.
  7. Jan 14, 2012 at 10:23 AM
    xA101x
    AJ
    Florida
    I read on here that the harness is different and wont work. I was thinking of trying to just take all the electrical from the bench and transfer it to some after market buckets. I think the bench only has an airbag sensor in it not an actual airbag.
  8. Jan 14, 2012 at 10:54 AM
    wolftree
    Rick
    Ohio
    xA101x,
    I did an online build at Toyota.com yesterday for my zip code(Ohio). It showed a 2012 regular cab, manual transmission, 4X4, 4 Cylinder with bucket seats. Are you actually talking with a dealer / salesman?
  9. Jan 14, 2012 at 9:19 PM
    xA101x
    AJ
    Florida
    Yeah iv been dealing with a dealer. Iv looked all over FL and nobody can get one
  10. Jan 18, 2012 at 8:50 AM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    not too hard to do a swap , check out my signature for the write-up.
  11. Jan 18, 2012 at 11:04 AM
    xA101x
    AJ
    Florida
    Awesome, thanks man! What did it cost you to do the center console?
  12. Jan 18, 2012 at 10:13 PM
    TacomaBuzz
    CT
    I think I paid $120 for the whole center console assy
  13. Jan 19, 2012 at 4:41 PM
    xA101x
    AJ
    Florida
    Thats not to bad, thanks for all the info
