Anyone Have Experience Installing URD SPEC-U Headers?
Discussion in 'Ontario, Canada' started by TegoTaco, Feb 21, 2020.
  1. Feb 21, 2020 at 3:26 PM
    TegoTaco
    TegoTaco [OP] Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Any of you local guys have experience installing the URD SPEC-U headers? I’ve done the Doug Thorley Long Tube Headers many many years ago on my XRunner, that didn’t require removing the studs. Any input would be greatly appreciated. :)
  2. Feb 23, 2020 at 2:00 PM
    TegoTaco
    Ontario, Canada
    No luck then lol
  3. Feb 26, 2020 at 5:56 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    sorry man, haven't heard of anyone doing header work.
    Mostly just stuff from the cat rearwards to the exhaust tip but that'ss about it.
    Bumped into a guy with MBRP (based in huntsville) pipes but never asked more than what he ran with, not sure if they make headers
  4. May 1, 2020 at 12:10 AM
    Smokehouse
    Smokehouse Procharged
    Zach
    Republic, Missouri
    2007 Super White Tacoma Sport
    You ever end up doing anything with this man?
  5. May 1, 2020 at 12:20 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Best advise I can give for removing the studs: PB blast them the night before. Then PB blast in the morning. Once you are ready to remove the studs, grab 2 of the nuts that fit on them and screw them down the stud as far as you can. Put the box end of an open end wrench on the lower nut. Then tighten the nuts against each other. Using the box end on ONLY the bottom nut, turn counterclockwise. This will remove the stud without putting too much twist and torque on the it, like you would if trying to remove it by it's self.
  6. May 1, 2020 at 2:02 AM
    TegoTaco
    Ontario, Canada
    Might be going with the URD SPEC-U exhaust this year, mods add up quick lol!
    Smokehouse[QUOTED] likes this.
