Anyone have experience with installing tweeters?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dlakerguy13, Jan 23, 2020.
  1. Jan 23, 2020 at 9:30 AM
    Dlakerguy13
    Dlakerguy13 [OP] Well-Known Member
    I am looking to do new speakers in my 09 Taco. I have seen several videos for the installation and it seems pretty straight forward. However, when it comes to the tweeter install, I can only find one video for the 2nd gen Tacoma and it is pretty lengthy with a lot of cutting of wires and other modifications to make it work. Does anyone know of a pretty simple plug and play kit or easy way to swap out the tweeters?
  2. Jan 23, 2020 at 9:32 AM
    countryttcuzzin
    countryttcuzzin Member
    Darrell
    Exlax City, centeral Kansas
    2007 Tacoma TRO Sport crew cab V6 auto
    Westtin Running boards+ bull bar and Lights,Bilstein Shocks front raised 1 1/2 inchs,Kelly Safari TSR tl 265/70R17 tires, Spyderauto compression headlights and LED tail lights.K+N CAI,Flowmaster CAT/B exhaust, Wood Grain Dash and doors trim,ATC Tonneau cover
    Try *********. I got them for my 07 worked great.
  3. Jan 23, 2020 at 9:33 AM
    countryttcuzzin
    Darrell
    taco tunes. some when wrong with the last post!!!
    Skyway and ALI3N_123 like this.
  4. Jan 23, 2020 at 9:33 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Have you looked at crutchfield?
  5. Jan 23, 2020 at 9:35 AM
    Larzzzz
    Larry
    MA
    There was nothing wrong with that post. They do not have good rep here. The site does that to their name automatically.
    The miracles of modern technology.
    deadpocketss and Muddinfun like this.
  6. Jan 23, 2020 at 9:38 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    What exactly do you need help with? I installed some Image Dynamics tweeters in my '14 (along with everything else besides a new head unit). From what I remember, and i'll have to double check, besides custom making a bezel so the new tweeter would fit in the OEM location I think it was pretty plug n' play. Like I may have had to buy a wiring connector to mate the Toyota connection to the Image Dynamics tweeter connection.
  7. Jan 23, 2020 at 9:41 AM
    Dlakerguy13
    Basically in the 2 videos I can find for the 2nd gen Tacoma tweeter install, they are having to splice wires or damage/modify the wire connectors to fit the one for the tweeter, etc. I just want something that comes with the right size mount and the right size connecting harness so I can just plug in and mount without having to modify anything.
  8. Jan 23, 2020 at 9:43 AM
    jbaker1976
    jbaker1976 It's always Taco Tuesday
    East TN
    2015 DCSB OR
    Camper shell with side windoors and bed slider, JL Audio Component Door Speakers, JL Audio Stealth box, Grill Craft Grill, Husky floor liners, Hondo Radio knobs, Predator steps, Remote Start, Pop N Lock, etc...
  9. Jan 23, 2020 at 9:43 AM
    gkomo
    San Diego, CA
    2014 MGM AC SR5 4x4
    I think I bought Metra connecting harnesses. Let me look (and you search too), but either I made a thread or I posted a ton of pictures to an existing thread here for the stereo install. Sorry I did it like 4 years ago so my memory is slipping.
    Dlakerguy13[OP] likes this.
  10. Jan 23, 2020 at 9:48 AM
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    OP if you are looking to just swap out the tweeters it super easy....
    Buy the adapters above and OEM tweeter adaptors, pull the door card, unplug harness, remove tweeters, install adapters, mount new tweeters, use wire adapters to connect tweeters, install door card, done.
  11. Jan 23, 2020 at 9:49 AM
    gkomo
    San Diego, CA
    2014 MGM AC SR5 4x4
    Ya, check out "My Audio Build" in the Audio sub-section.
  12. Jan 23, 2020 at 9:49 AM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    They are banned for being a shitty vendor
  13. Jan 23, 2020 at 9:50 AM
    Dlakerguy13
    Good to know... I wont buy from them then.
  14. Jan 23, 2020 at 9:51 AM
    81shark
    No need to splice if you get an install kit. You may need a mount although you can reuse your current tweeter mount by removing the speaker parts from it
  15. Jan 23, 2020 at 9:51 AM
    Dlakerguy13
    Looking around now for a different kit than the one on *********.
  16. Jan 23, 2020 at 9:53 AM
    gkomo
    San Diego, CA
    2014 MGM AC SR5 4x4
    I TTT'd my thread so you can easily find it. It's 8 pages so you'll have to sift through it to find pertinent tweeter information/pictures.
  17. Jan 23, 2020 at 9:54 AM
    jbaker1976
    East TN
    2015 DCSB OR
    Search for the Subaru tweeter swap if you dont want to cut 2 wires....
    I think it's a plug and play swap. I just cant justify buying stock Suby speakers vs. crimping a couple of wire for the audio components I prefer.
    jungleman and Zac of all trades like this.
  18. Jan 23, 2020 at 9:54 AM
    Zac of all trades
    Zac
    fwpfab.com
    I picked up some Polk Audio silk dome tweeters. They have a high sensitivity so they work well with an OEM head unit
    Polk Audio DB1001 1-Inch Silk/Polymer Composite Dome Tweeters
    https://amzn.to/2TR6tkz
    Sensitivity (1W at 1 meter) 92
    Sensitivity at 2.83 volts N/A
    Frequency Response 4000 - 23k Hz
    Minimum RMS Wattage 6
    Maximum RMS Wattage 60
    Peak Power Handling (Watts) 180
    Top-mount Depth (Inches) 1
    Bottom-mount Depth (Inches) N/A
    Cutout Diameter or Length (inches) 2
    Skyway and CaptainBart45 like this.
  19. Jan 23, 2020 at 10:00 AM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road
    When I installed my aftermarket tweeters, I just cut and soldered the new in. I know it's not what you're asking, but the process was pretty straightforward. I have no need to go back to stock tweeters, but I could solder them back in if need be. To me, this was faster and easier than the Subaru tweeter install.
    Crutchfield didn't seem to have a plug and play harness for the tweeters last I checked.
  20. Jan 23, 2020 at 10:03 AM
    Dlakerguy13
    Were these a plug n play kit? Or what did you do for installation/connection?
