Anyone install Detroit Truetrac
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dilley, Oct 30, 2009.
  1. Oct 30, 2009 at 4:13 PM
    Dilley
    Dilley [OP] Well-Known Member
    WA
    06 2.7L
    KN Cold air intake, Dynomax exaust, Husky liners
    I was just wondering if anyone has personaly installed the Detroit Truetrac. How do you like it and how did the installation go?
  2. Oct 30, 2009 at 4:27 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    well i do no detroit has been around a longggggggg time.and in the jeepen world they r used alot.we've even had a couple of plow trucks with detroits in them and they worked well.no problems.
  3. Oct 30, 2009 at 4:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2. Installed one in a Dodge, and it worked REALLY well.....Put a couple in First gen Tacos, and they worked well too.
  4. Oct 30, 2009 at 4:41 PM
    Dilley
    WA
    06 2.7L
    Thanks thats great. I am going to attempt the installation myself. I have no differential experience but I have fixed alot of mechanical stuff. I am going to get a rebuild kit and give it a shot and hope everthing goes well. any advice.
  5. Oct 30, 2009 at 4:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Just take your time. Give yourself the whole day if you have never done it before. Have some pizza handy....
  6. Oct 30, 2009 at 5:03 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    yeah just pizza,no beer.i think you"ll b happy with it when its done.
  7. Oct 30, 2009 at 5:22 PM
    Dilley
    WA
    06 2.7L
    Yeah I think I will too. Beer is never a good idea with something like that. Everything I have read about the Truetrac is great. nearly locks like a locker and drives on the street almost like a open diff. I cant wait to test it out after the install.
    Camel51 likes this.
  8. Oct 30, 2009 at 5:26 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
  9. Oct 30, 2009 at 5:42 PM
    petersharp
    petersharp Well-Known Member
    Do you need to ask?! It's up there ^
    Louisville, CO
    Ex DC LB Sport owner.
    Isn't there some really technical part where you need to set up the backlash in the differential to a certain level?
    I hope they've come along way since the one I had in my Land Rover (or mine was set up wrong). Every so often going around a corner it would unlock with a big bang, enough to make the car shake. And as for driving on ice/in teh snow...don't bother. Take the bus.
  10. Oct 30, 2009 at 5:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your just replaceing the carrier....You shouldnt have to reset the back lash on a tru track install.
  11. Oct 30, 2009 at 5:57 PM
    Dilley
    WA
    06 2.7L
    Did you have the the detroit Truetrac LSD with helical gears or the Detroit lockers? because I am not getting the locker. I have heard LSD is good on snow also.
  12. Oct 30, 2009 at 5:58 PM
    petersharp
    Louisville, CO
    I had the locker - sorry if I misled you (I thought you were talking about the locker also).
  13. Oct 30, 2009 at 6:59 PM
    JJK
    JJK Active Member
    08 SR5 DC
    TrueTrac Limited Slip
    The Truetrac was the first thing I did on my 08 dc sr5 4x4 – (along with tires)
    I had a transmission shop install it. I had a torsen type LSD in my Ranger and that little truck was great off road so I wanted something similar. The Detroit is perfect. I live in Maine and it is great in the snow. I also hunt a lot and it’s great on the logging roads etc.
    You never know its back there until you are supposed to be stuck but you’re not.
    JJK
  14. Oct 30, 2009 at 7:06 PM
    Dilley
    WA
    06 2.7L
    Great thanks. the only way your post would have been better is if you installed it yourself. did you buy a rebuild kit also for the differential and bring it to the shop with the truetrac? or did they just reuse the bearings and use silicone for the seals? how much did it cost you? thanks JJK
  15. Oct 30, 2009 at 7:10 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    All he should need is a carrier shim kit. I got two sets (one for each side, in the event that you need two of the same shim) for around 25 bucks shipped from randy's ring and pinon. Also, dont forget a oem gasket that goes between the third and the axle housing. Might as well use instead of sealant since it only cost 7 bucks.
  16. Oct 30, 2009 at 7:19 PM
    JJK
    JJK Active Member
    08 SR5 DC
    I beleive I paid around 750.00 installed and I beleive they replaced carrier bearing. (2 years ago) It's not somthing I could have done myself. I don't have the tools (Physical, mental, or actual tools that is:) )
    JJK
  17. Oct 30, 2009 at 9:24 PM
    SC4333
    Grant
    FL
    Yep, its not exactly easy unless you are fairly mechanically inclined. As far as the carrier bearing goes, you WILL need a set of carrier bearings (2) if you do not have the correct puller to remove the old bearings from the open carrier. I just went ahead and bough two new ones for peace of mind. Toyota quoted me almost 100 bucks for two new bearings, so I bough a set of Timken bearings which are every bit as good, for less than half the cost. You will also need a press to install the new bearing.
  18. Oct 30, 2009 at 11:57 PM
    RWS_350MAG
    RWS_350MAG Well-Known Member
    Don
    Wisconsin
    2010 TRD Off Road 4x4 AC
    Toytec Ultimate lift, Tailgate anti-theft mod, 265/75-16 Goodyear Duratrac tires on stock rims, Lakeland Predator Cap, Rear seat headrests removed, Husky Floorliners
    If you are just replacing the differential, there is really no reason to buy a whole rebuild kit. You will need to get bearings, and cups, for sure. It wouldn't be a bad idea to get new ring gear bolts, and a third member gasket. The only tricky part about changing out the differential carrier is getting the bearing preload, and ring and pinion backlash set up right. I installed a Tru-Trac in the front, and a Detroit Locker in the rear on my Jeep. I must have got it right, because both axles are still alive and happy after 4 years now.
  19. Oct 31, 2009 at 2:17 AM
    TacomaHarry
    TacomaHarry Well-Known Member
    I had a TruTrac installed in the rear axle when I had my lift put in. I don't have the tools or time or garage.
    I've had mine for about 3 years now. I do mostly city stop and go driving. Can't tell it's even there, until I get on it going around a corner too fast and swauk a tire. Off road it's great until you lift a tire then it goes away. But if you pull a few clicks of the parking brake the LSD thinks both tires are still on the ground. It takes some pratice on how many clicks and how much gas to apply to get it to hook up.
    IF you haven't set gears before (ring and pinion) I wouldn't touch it.
    Good Luck.
  20. Jan 12, 2011 at 9:50 AM
    Tony H
    Tony H Active Member
    Tony
    Bandon, Oregon
    03 4WD 4cyl single cab SR5
    Tundra 17" wheels
    How did your install go and are you satisfied with the Truetrac? i just purchased one and am gearing up for the installation. I have a shop where the truck can sit for as long as it takes me so there's no pressure to get it done quick-even if I need to order more parts during the job. I am definitly going to buy new carrier bearings
