Anyone know if these spacers will fit?
Discussion in '5 Lug' started by Minnis12, Feb 22, 2013.
  1. Feb 22, 2013 at 7:00 PM
    Minnis12
    Minnis12 [OP] Well-Known Member
    Blanchard, La
    '09 Tacoma BASE 2.7L i4
    de-flapped, Pro-Flow Super V muffler, Pilot offroad lights with 7 color changing LED's, fog lights
  2. Feb 22, 2013 at 7:03 PM
    MIAtaco
    MIAtaco Well-Known Member
    Brian
    Miami FL
    2010 tacoma base lifted
    2.75" front lift 2.5" rear, pro comp es3000 rear shocks w/ orange shock boots, custom exhaust, k&n cold air intake, 20" led light bar behind grill, aftermarket grill, T-rex3 eyelids, pioneer HD radio
    Get the ones from ccm off road they garantee fitment and have the ones for the 5 lug model, i have the 2.75" spacers on mine
  3. Feb 22, 2013 at 7:10 PM
    Minnis12
    Blanchard, La
    I really only want an inch or two to level it out cause I don't wanna do the AAL. did you add a leaf if not, how's it look?
  4. Feb 22, 2013 at 7:20 PM
    MIAtaco
    Brian
    Miami FL
    They have smaller spacers i just wanted it lifted, i had a custom exhaust made but the pipes were hitting the drive shaft when the bed was loaded so i added a heavy duty leaf in the rear for lift and help with hauling
  5. Feb 22, 2013 at 7:24 PM
    Minnis12
    Blanchard, La
    i cant find them on their website i can only find them for 6 lugs
  6. Feb 22, 2013 at 7:26 PM
    MIAtaco
    Brian
    Miami FL
    I bought mine through them via ebay, or you can call them to make sure you get the right ones
  7. Feb 22, 2013 at 9:46 PM
    Minnis12
    Blanchard, La
    Would a 2.75" block in the front look funny without anything in the rear?
  8. Feb 23, 2013 at 7:55 AM
    MIAtaco
    Brian
    Miami FL
    yeah you will have a bro lean i suggest a 1.5" spacer
  9. Feb 23, 2013 at 2:55 PM
    MIAtaco
    Brian
    Miami FL
  10. Feb 23, 2013 at 4:00 PM
    poteran
    poteran Active Member
    david
    LOS ANGELES
    SR5
    question guys. i tow a side by side UTV with my 5lug. would i still be able to tow with just a 2inch front spacer lift?
  11. Feb 23, 2013 at 5:36 PM
    MIAtaco
    Brian
    Miami FL
    i would add an extra leaf in the rear too if you're gonna tow
  12. Feb 24, 2013 at 7:04 PM
    poteran
    david
    LOS ANGELES
    SR5
    ok thanks!
  13. Feb 25, 2013 at 10:36 AM
    poteran
    david
    LOS ANGELES
    SR5
    was going to order fat bob kit, but whats the difference in long and short leaf packs?
  14. Feb 25, 2013 at 10:41 AM
    MIAtaco
    Brian
    Miami FL
    long leafs usually add a little more lift , i jaust added a single long leaf and longer u bolts to mine and got about 2.25" of lift and roughly 400-500 pounds added to my hauling capacity. or you could just add some helper springs like they sell at pepboys
  15. Feb 27, 2013 at 5:15 PM
    poteran
    david
    LOS ANGELES
    SR5
    can someone please tell me which shocks would be good upgrade to replace the 2 front shocks. since im installing the fat bob kit i would like to upgrade the 2 in front . make and model are appreciated.
  16. Feb 28, 2013 at 11:02 AM
    MIAtaco
    Brian
    Miami FL
    theres not too many aftermarket ones for the 5 lugs but kyb seems to be the best of whats available, little pricey though
  17. Mar 23, 2013 at 8:26 PM
    poteran
    david
    LOS ANGELES
    SR5
    dammit! replaced my front struts up front today and i didnt install the stock shock boots. is this ok??
  18. Mar 24, 2013 at 5:59 AM
    MIAtaco
    Brian
    Miami FL
    yeah its fine just make sure if you go off road you wash them off when you're done
  19. Mar 25, 2013 at 9:35 AM
    poteran
    david
    LOS ANGELES
    SR5
    ok thanks!
