anyone know pa inspection laws?
Discussion in 'Lighting' started by kjf216, Jan 14, 2010.
  1. Jan 14, 2010 at 9:13 PM
    kjf216
    kjf216 [OP] Fitz
    Kyle
    Ridley Park, PA
    2016 Jeep Wrangler Sahara
    Head unit, speakers, LEDs
    ok so i mounted a cheap set of fog lights under my bumper as aux/ back up lights. so i went to add a switch so i could turn them on when ever and in the process i screwed something up the shifter locked, lost the heater and turn signals so i went to the dealer and they helped me figure out i shorted out on something and poped a fuse.
    but anyway back on topic while there the guys that was helping me said he thinks under pa law the lights r illegal he said he thought one would be ok but not two, anyone know the truth about this?
    also i have been planning to do a HID retro anyone know if a retro would pass inspection in pa?
  2. Jan 14, 2010 at 10:38 PM
    BWro
    BWro Well-Known Member
    Any aux lighting on the front of a vehicle must be atleast, if i remember correcrly, 26 inches apart from center, tied into the high beams and covered.
    As for the HID retro... no idea. I only check to see if all the lighting works, not how bright the are.
  3. Jan 14, 2010 at 10:47 PM
    kjf216
    kjf216 [OP] Fitz
    Kyle
    Ridley Park, PA
    my lights are in the rear of the truck and only trigger in reverse
  4. Jan 15, 2010 at 9:55 AM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    08 Tacoma Black,Sport package,
    Sport pedals, Extang full-tilt cover, Magnaflow exhaust system, XPEL invisible paint protection, TRD short Shifter, Hood struts, Homelink mirror, Dbl power outlets,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Muth heated signal mirrors TSB. Lo-Tek Pilllar pod with Glow-Shift gauges, 4x4 illuminated switch, Pioneer Z110BT (upgraded to Z130BT) w/2011 toyota tailgate backup camera,traffic tuner, parking brake bypass. Leather interior w/heated seats. LED's installed in glove box, center console, front and rear cupholders, rear console vent, AFE CAI, LED taillights, under hood lights, LED bed lights, oil catch can, extra D-rings installed in bed, frame replaced, Bilstein 5100, fronts set at.85, FOCAL Auditor 6.5" componet speakers. Replaced lower center dash panel with 2011 dash panel, installed USB charger and relocated seat heater switches to lower panel, FLYZEYE lights, APEX stealth LED light bar brackets and Cali Raised LED light bar, Illuminated Ignition Ring,Diff. Breather mod, AC mod.
    I know from past history they must be tied into the high beams and kept covered.
  5. Jan 15, 2010 at 9:59 AM
    Brunes
    Brunes abides.
    Rotorhead
    Try searching your state statues- There is the only place you'll find a definitive answer.
  6. Jan 15, 2010 at 12:56 PM
    BWro
    i have my state and emissions. there is nothing stated in our guidelines that state anything about HID's. (i checked into this today) As long as your low/high beams, turn, stop lights and 3rd brake are working properly. it will pass that part of the inspection. As for fog or after market lighting, i could care less when i inspect within reason....with the exception of lights on a roll bar, thats to obvious and a State Trooper will nail you...and me.
  7. Jan 15, 2010 at 1:06 PM
    kjf216
    kjf216 [OP] Fitz
    Kyle
    Ridley Park, PA
    so basicly i should come see you next year lol thanks for looking for me is there anything in the book about bumper mounted rear facing lights?
  8. Jan 15, 2010 at 1:11 PM
    BWro
    as long as they are wired into the reverse circuit, no. as for a aux switch to activate them with out being in reverese.....i know nothing;)
  9. Jan 15, 2010 at 1:30 PM
    kjf216
    kjf216 [OP] Fitz
    Kyle
    Ridley Park, PA
    so what part of philly you in i used to go to school at drexel and i live just outside philly by the air port
  10. Jan 15, 2010 at 1:38 PM
    BWro
    Im in ne philly, near the ne airport
  11. Jan 15, 2010 at 4:19 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I don't have any clue about rear lights....
    Front lights have to be apart 20" center to center. If they are close together, they need to be covered. I've personally never had to worry about this. The only covers I've ever had were the plastic cages that come with the PIAA's.
    Fog lights on with low beams
    Driving lights on with hi beams
    If you plan on wiring any lighting (front) indepedantly of the hi/lo beams (illegally in PA) - I'd put a fuse or plug somewhere that you can reach it. Because...for inspection, you can disconnect the power to those aftermarket lights and they can't fail you.
