Anyone knowledgeable on “balance shafts”?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Greenbean10, Aug 23, 2024.
  1. Aug 23, 2024 at 6:00 AM
    Greenbean10
    Greenbean10 [OP] Well-Known Member
    2010 Timber Mic 4x4
    Hello TW.
    The ongoing vibrations from acceleration in my 2010 SR5 DC is an ongoing issue that I just can’t seem to figure out and currently just dealing with since I haven’t had any leads on the issue. But I did hear some information from a friend of mine about checking balance shafts? that are supposedly located in the oil pan. Has anyone heard or have experience with this? If so, please share. Thank you in advance.
  2. Aug 23, 2024 at 6:58 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    What engine do you have?
    2.7L or 4.0L
    Auto or manual?
    The 4.0L doesn't have a balance shaft.
    Have you checked the U-Joints and carier bearing?
    SethM and Greenbean10[OP] like this.
  3. Aug 23, 2024 at 7:05 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    Greenbean10[OP] likes this.
  4. Aug 23, 2024 at 8:19 AM
    Greenbean10
    2010 Timber Mic 4x4
    It’s a 4.0L automatic. I had the driveshaft balanced and spun and there was a pinched area coming off of the transmission that was fixed but that didn’t even touch the vibration. The carrier was sitting fine according to the driveshaft shop and no comments on the u joints. The u joint coming off the transmission wore a lot faster than the other two on the driveshaft
    I was also told that when the carrier bearing goes out that it can do something to the balance shafts which is when all of this started is when the carrier bearing when out and after it was replaced, the vibration was constant and has no gone away. Even changed all of the fluids not too long after CB change ( transmission, diff, transfer, oil) no differences.
  5. Aug 23, 2024 at 8:44 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The carrier bearing will not affect the actual balance of the driveshaft. It either balanced, or it’s not. A bad carrier can be out of round, have a bad bearing, or be installed incorrectly.
    It the problem started AFTER you replaced the carrier. I’d suspect a carrier issue.
    FWIW, the carrier needs to sit at the same height as the old one. And the big nut needs to be torqued correctly. Blasting it in with an impact will get it too tight. Leading to premature failure.
    I recommend going with a OEM carrier. That way, everything is “the same”.
  6. Aug 23, 2024 at 9:05 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    300 years ago a balanced shaft would have convicted you as a witch.
  7. Aug 23, 2024 at 9:15 AM
    SethM
    SethM Well-Known Member
    Seth
    Los Angeles ca
    2011 mgm tacoma trd sport 4x4
    3" toytec lift 285/75/17" tires
    If you fell the imbalance while acceleration, or deceleration I would suggest u joints are bad pr seized. I even felt when slow speeds driveshaft felt as if was kinking up.
  8. Aug 23, 2024 at 2:02 PM
    Greenbean10
    2010 Timber Mic 4x4
    I was looking for an OEM one not too long ago but I could not seem to find one that was actually OEM and in store unless it’s only on Toyota parts. If you had a link handy, I would greatly appreciate it, other than that I’ll start the search again.
  9. Aug 23, 2024 at 3:52 PM
    SethM
    Seth
    Los Angeles ca
    Toyota uses Spicer driveshaft/u joints from factory
  10. Aug 23, 2024 at 4:28 PM
    TnShooter
    Deogee
    STOCK
  11. Aug 23, 2024 at 5:00 PM
    TacoTuesday1
    FL
    I doubt a 1GRFE has a balance shaft.
  12. Aug 23, 2024 at 6:56 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I presume you installed an aftermarket center/carrier bearing? I had bad experience with them. One was a Dorman and did not last a year. Spicer makes the oem center bearings for Toyota. Their non-Toyota part #s are 5002334 and 5002007 - either will fit. The -334 is listed for prerunners and the -007 for 4x4. I installed the -334 in my 4x4 because the -007 was hard to find when I was shopping for one, and when I did find one, it cost twice as much. The difference is the -007 adds a dust shield, I read somewhere. I’ve had the -334 for four years and is holding up as expected.
    TnShooter and Greenbean10[OP] like this.
  13. Aug 23, 2024 at 7:14 PM
    Greenbean10
    2010 Timber Mic 4x4
    Yeah I soon as I drove my truck out from the shop, there was an immediate vibration from acceleration and it’s been there ever since.
  14. Aug 23, 2024 at 7:15 PM
    Greenbean10
    2010 Timber Mic 4x4
    Thank you all for your help
    TnShooter likes this.
  15. Aug 24, 2024 at 10:32 AM
    Chuy
    Lakeside, CA
    Silver Taco
    On the two shitty ones I got, it was the rubber part around the bearing that deteriorated quickly. There was excessive play on the shaft at the center bearing. I felt more of a thumping than a vibration.
  16. Aug 24, 2024 at 10:51 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    It's possible that the shop didn't put the driveshaft back together like it came and has it out-of-phase, which would affect the balance and cause a vibration.
  17. Aug 24, 2024 at 12:31 PM
    SethM
    Seth
    Los Angeles ca
    I have heard carrier bearing is unidirectional. May have been put in backwards.
  18. Aug 24, 2024 at 1:58 PM
    Bosco369
    Bosco369 Active Member
    Russ
    Temescal Valley
    2006 Tacoma 4x4 TRD
    Yes, bad vibration at 60 mph+ after I hit 90k miles. I have an '06 DCSB 4x4 4.0L. Replaced U-joints & carrier bearing, vibration actually got worse (no longer worn out and loose). Replaced drive shaft (OEM) slip joint worn out. Tacoma is now smooth as silk.
