Anyone open up their TRD hood scoop?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheRiddleOfSteel, Jul 4, 2011.
  1. Jul 4, 2011 at 1:23 PM
    TheRiddleOfSteel
    TheRiddleOfSteel [OP] Well-Known Member
    Phx
    08 TRD sport
    it looks cool, but Ive never been a fan of non-functional scoops
    tempted to open it up and maybe put some foam in there or something else to keep major debris out
  2. Jul 4, 2011 at 1:26 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You want to open it up and then plug it up with foam :confused: You lost me there.....
  3. Jul 4, 2011 at 1:27 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    There are threads on here about this and basically all say it would be useless. :notsure: You probably just opened a can with this btw. :facepalm:
  4. Jul 4, 2011 at 1:27 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    the scoop was not designed to be functional...it'll do nothing positive if you remove its innards...
  5. Jul 4, 2011 at 1:28 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    beat me to it lol ;)
  6. Jul 4, 2011 at 1:29 PM
    TheRiddleOfSteel
    Phx
    08 TRD sport
    cool the engine off
  7. Jul 4, 2011 at 1:29 PM
    TheRiddleOfSteel
    Phx
    08 TRD sport
    air would go through foam much better than solid plastic/metal
    (air filters often use only a piece of foam)
  8. Jul 4, 2011 at 1:30 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    what cools the engine is your air intake....all your gonna do is make your engine bay dirty as fuck...this has been covered 1,665,678,432 times....try searching ;)
  9. Jul 4, 2011 at 1:31 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    and air filters use either a paper or synthetic media for filtering
  10. Jul 4, 2011 at 1:31 PM
    TacomoMoto
    TacomoMoto Well-Known Member
    Miami
    09 SR5 Sport 6speed 4.0L
    Have you opened it up ? If so any diff in temp ?
  11. Jul 4, 2011 at 1:32 PM
    KPT
    09 Prerunner
    It would cool the plastic cover on the motor and that's about it....as was already noted, the intake and the radiator are what cools the internals of the engine.
  12. Jul 4, 2011 at 1:34 PM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    why not just put fine mesh with a layer of cloth infront of the mesh to keep most water/debris out
    you can even put a later of spot paper behind the mesh so you know if water gets in
  13. Jul 4, 2011 at 1:36 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    or just leave it alone because like mentioned before...this has been tried and tested 1,456,789,443 times and NOTHING IS BENEFITED FROM IT!!! :goingcrazy:
  14. Jul 4, 2011 at 1:40 PM
    TheRiddleOfSteel
    Phx
    08 TRD sport
    no, a scoop would make the engine compartment cooler (the silly people that put an inside the engine compartment CAI would most benefit from this) otherwise it isnt going in the engine but just cooling the exterior
    *edit- to ad that the foam would keep out debris
  15. Jul 4, 2011 at 1:41 PM
    Deserted1
    Deserted1 Hellion
    Corey
    Murrieta
    4wd Super White
    Icons
    They are right you wont see any benefit in a Tacoma, first off where is the air gonna go, it isnt going to cool anything. However there is no need to "filter it" if you decide to open it up, I had a STi before this and it did have a functioning air scoop on the hood, you have all seen em, but the air was also directed straight into the Intercooler so it had a purpose. I never did have anything bigger than the occasional bug in there, so no reason to close it off.
  16. Jul 4, 2011 at 1:42 PM
    TeamSarcasm
    The better coast
    just a suggestion :stirthepot:
  17. Jul 4, 2011 at 1:42 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    but it won't cool the "exterior" enough to change the temp on its "interior"...so again...why bother!!!! :confused:
  18. Jul 4, 2011 at 1:43 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
  19. Jul 4, 2011 at 1:45 PM
    TheRiddleOfSteel
    Phx
    08 TRD sport
    but we can all agree that people with aftermarket CAI's would benefit?
  20. Jul 4, 2011 at 1:45 PM
    TheRiddleOfSteel
    Phx
    08 TRD sport
    why bother? principle, non functioning scoops are inherently cheesy
