Anyone Put a 2012 Rear Mirror in a 2005-2011 Yet?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tunngavik, Jan 16, 2012.
  1. Feb 16, 2012 at 4:27 PM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    Does the connector on the 2012 mirror look like it will be easy to get a +12v wire on it for the homelink once the other connector for the compass and backup mirror is in place? I have a 2009 Sport AC I might like to do this mod to.
    BTW, I was stranded in Houston last friday night thanks to Continental Airline mechanical. Got to spend the night in the Hilton Houston North... First time in Houston actually outside of the airport.
  2. Feb 16, 2012 at 4:33 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    I added constant power to the 2012 mirror connector in order to get my homelink working... Tapped into the power at the Map lights and ran it to the mirror... I had an extra mirror plug (pinned) so I pulled a wire and pin from the connector and used it to plum power into the mirror's connector....
    If you had to splice power into the mirror you could do it without the connector, but there isn't a lot of room for t taps...
  3. Feb 16, 2012 at 4:44 PM
    Raylo
    MD, USA
    I guess I really need to see it.... but it's good to know that it is doable.
  4. Feb 16, 2012 at 4:45 PM
    Delmarva
    Tucson, AZ
    I'll eventually get a write up done... Pics are complete just need to sit down and do it...
  5. Feb 16, 2012 at 4:48 PM
    Raylo
    MD, USA
    Thanks, mayor.
  6. Aug 31, 2012 at 7:47 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Blackseven and skygear get ready for some pms coming your way. I just bought a 2012 mirror.
  7. Oct 8, 2012 at 9:19 PM
    skeeet
    skeeet Well-Known Member
    Pete
    San Jose, CA
    05 DCSB TRD Sport
    So if I install an auto-dimming mirror with homelink, all I'll need to do is hook up a power source to the homelink? everything else will plug in?
  8. Oct 9, 2012 at 4:09 AM
    dexterdog
    Oly WA
    2012 F150
    No. No one has been able to get the temp display to work afaik. I still don't have mine working.
  9. Oct 9, 2012 at 8:43 AM
    BlackSeven
    BlackSeven Well-Known Member
    Maryland
    2017 4cyl 5 spd 4x4 extended cab
    Toytec Ultimate Lift kit, Toytec Rear AAL, 4.88 Gears, ARB Rear locker, Doug Thorley header, Volant Cold Air Intake, Demello Offroad front high clearance bumper, ARB On board Air compressor, BLHM, Wet Okoles, 2011 Color matched grill, Weathertech mats, 4x Innovations Sliders, ATO Engine Skid plate, ATO High lift bed mounts.
    The Temp won't work (if you have that in your mirror), but your autodimming will work and homelink will work after you add a power source.
  10. Oct 9, 2012 at 10:39 AM
    skeeet
    Pete
    San Jose, CA
    05 DCSB TRD Sport
    Thanks, I don't really mind the temp not working in the mirror since I already have it.
  11. Jan 9, 2013 at 5:44 PM
    FgReed
    FgReed Active Member
    Ontario
    09 Tacoma TRD Sport
    Hey guys,
    I know this thread is a bit old, but I figured why start another thread on the same topic. I've got a 09 with backup camera in mirror and it has the overhead compass and temp, but the microprocessor burnt out in it. It wasn't the 510 resistor issue that many have experienced. I figured instead of spending 200+ bucks to replace that, why not get a 2012 mirror with all the same stuff plus homelink. Problem is, i've read over 20 different threads now and can't find the part# for the OEM mirror anywhere. Does someone know what the OEM part# is for the 2012 mirror with camera, homelink, temp, compass and auto dim? If so could you post it by chance? Thanks in advance.
  12. Jan 10, 2013 at 9:34 AM
    skygear
    skygear                    
    FYI - Still haven't got my temp working.
  13. Jan 11, 2013 at 5:25 AM
    FgReed
    Ontario
    09 Tacoma TRD Sport
    Found out what the part# is for this. I figured I would post it in case anyone else is interested.
    Part# 87810-04090
    $1000.00+ from Toyota, but I found it online for $552.00 Still pricey.
  14. Feb 15, 2015 at 10:30 AM
    bradforj
    bradforj Well-Known Member
    TN
    07 4x4 v6 TRD Sport
    2012+ Front End Swap 2014 steering wheel swap w/audio and BT controls 2014 power window controls 2014 lower center dash and radio bezel 2014 a/c controls Auto-dimming mirror Heated side mirrors Turn signal side mirrors Backup camera DNX890HD head unit Kenwood speaker system Kobalt slim toolbox In-channel Ventvisors N-Fab running boards
    I am hoping to put a 2012+ mirror with Homelink and temp/compass on the LCD screen into my 2007 DC. HAs anyone else done this and gotten everything working? I know my old temp probe won't work since it is a two-wire probe and the new mirrors use one wire. Is there a one-wire probe that will work?
