Anyone Retrofit Wireless Charging into their 2nd gen?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jinseiganai, Apr 16, 2016.
  1. Apr 30, 2016 at 1:26 PM
    GTOJim
    GTOJim Well-Known Member
    Jim
    SF Bay Area
    2013 PreRunner TRD OffRoad V6
    Just took this picture to give a better idea of how I made a wireless charger for my Tacoma. The forstner bit pictured is to small for this size hole but with this type of bit the holes can overlap each other to remove more material. I cut a grove using a table saw for the charging cable. I also used a small forstner bit to remove material for the plug on the cable end and as a notch for the electronics to fit into on the opposite side of the hole . Then used a chisel to square up rounded areas created by the drill bit.
    This picture was for an extra wireless charging stand for inside the house but process is very similar. I inlaid some ebony in maple then sliced a thin piece off as the top. Then glued it back in place after the electronics was inside.
    I only mention the inlay because some ebony is missing on the inside piece and might seem strange. Also the grove on the end is so the charging cable gets embedded inside a second piece of wood which gets glued to the piece pictured creating a base so it can stand upright. Again the process was very similar to the wireless charger for my Tacoma.
    As I mentioned in my previous post this can be done by drilling though the bottom of a piece of wood being careful not to drill all the way though and remove enough material for the electronics to fit into.
  2. Apr 30, 2016 at 1:28 PM
    GTOJim
    Jim
    SF Bay Area
    I've got to run, let me think about it.
  3. Apr 30, 2016 at 3:37 PM
    jamiec
    jamiec Man who keep hands in pockets feel cocky all day
    Jamie
    Chillicothe, Ohio
    2017 Prius three touring. Sold the Taco
    That is an incredible idea. I wonder where he got the tray and charger from? Too bad the post didn't list where he got everything. I'd be willing to attempt this if I could get all the parts together
  4. Apr 30, 2016 at 3:46 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    He's got a page on Facebook, I think it's called the same thing, you can ask him there.
    jamiec[QUOTED] likes this.
  5. Apr 30, 2016 at 5:29 PM
    jamiec
    Jamie
    Chillicothe, Ohio
    Cool thanks
  6. Apr 30, 2016 at 11:46 PM
    gbell210
    gbell210 Active Member
    Gary
    Poulsbo, WA
    '13 TRD Offroad DCSB
    The site said he got the tray:
    "the tray used is actually the dash cubby from a VW Polo"
  7. May 1, 2016 at 4:35 AM
    jamiec
    Jamie
    Chillicothe, Ohio
    I overlooked that, thanks
  8. May 17, 2016 at 6:10 PM
    gbell210
    Gary
    Poulsbo, WA
    Decided to cut the ribs off and smooth it out for a nice flush mounting area along with epoxy. A very thin layer was applied on top, with most of the holding around the edges.
    Still haven't had time to wire it up, but its looking like I may have to run a line to an add-a-fuse (or tap into the cigarette lighter), so power is automatically on when the truck is.
  9. May 17, 2016 at 11:29 PM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    I am doing this as well. I'm am epoxying it under as well but I don't know the best/cleanest/ most efficient way to wire this up?!? Please help!
  10. May 18, 2016 at 10:20 AM
    Berniebikes
    Berniebikes Well-Known Member
    Bernie
    Williamsburg, VA
    2015 White TRD OR Double Cab
    if you have a trd with the inverter under there you can tap the wire in for a constant 12v to the charger.
  11. May 18, 2016 at 10:26 AM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    I gave it a lot of thought and came to the conclusion that wireless is too slow and I'm usually in my car 20-30 mins at a time... Max. A "quick charge 3.0" car charger has worked out great for my needs. You gotta have a compatible phone though. Chances are if your phone has wireless charging, it also has Quick Charge capabilities
  12. May 28, 2016 at 2:48 PM
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    Waiting for the epoxy to dry, should have this done this weekend :goingcrazy:
    Thesandaddict and gbell210 like this.
  13. May 29, 2016 at 11:59 AM
    Thesandaddict
    Thesandaddict The dude
    Harley
    West Covina, CA
    2010 tundra bro-dozer
    Are you guys using covers on your phones? samsung has a quick charging wireless unit (pricey) that I was wanting to use, but between the Otterbox and the console, I'm wondering if it would even register?
  14. May 29, 2016 at 12:34 PM
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    I have a cover on mine and it works like a charm. Just finished it up today... Its awesome!
    Thesandaddict likes this.
  15. Jul 10, 2016 at 1:04 AM
    #35
    gbell210
    Gary
    Poulsbo, WA
    Just to provide an update, I eventually ended up tapping into an add-a-circuit I put in the fuse box to provide a trigger to my driving light relay. It may be slower than plugging in, but I like the ease of access. With a antislip pad on the console, and a silicone case I haven't had it slide at all. The other benefit is the wife can use the USB to charge her phone now.
    As for tapping into the inverter, it looks like on my 2013, the violet wire going into the inverter box might have a constant 12v source from the 7.5A fuse labeled STA, if I'm reading the wiring diagram correctly.
  16. Jul 10, 2016 at 9:27 AM
    #36
    GTOJim
    Jim
    SF Bay Area
    I think there is a very good chance it will not work with an Otterbox case. I made a wood charging stand for a friend that has a Galaxy S6 and it did not work with his Otterbox. The fix was putting an aftermarket charging receiver between the layers of his Otterbox case.
    If you often connect your device to a computer a thinner case might be a better solution as it's a bit of a hassle plugging and unplugging a wireless receiver, assuming your device supports wireless changing. My friend never needs to unplug the receiver so he's very happy with this work around as he loves the wooden charging stand.
    Good luck
  17. Jul 10, 2016 at 10:04 AM
    #37
    Thesandaddict
    Harley
    West Covina, CA
    I'll look into that. It never leaves it's case and it connects to everything in the house wirelessly anyways. Is that receiver just a small spool of wire like the qi charging pad pretty much? Seems like that would fit between the phone and case if it's as thin as it looks
  18. Jul 10, 2016 at 10:53 AM
    #38
    GTOJim
    Jim
    SF Bay Area
    Your description is very accurate, wireless receivers are very thin and should fit in just about any case. With an Otterbox I suggest placing the receiver between the layers of the case rather than between the device and the case. This is what I did with my friends Galaxy S6 and it working great. His S6 supports wireless charging but it wasn't charging with his Otterbox as it's pretty thick. You shouldn't have any problem using WiFi.
    Thesandaddict[QUOTED] likes this.
  19. Aug 26, 2020 at 11:26 AM
    #39
    JStiner
    JStiner Well-Known Member
    11 MGM 4x4 4.0 double cab
    KO2s (32s) with 2inch level
  20. Aug 26, 2020 at 11:45 AM
    #40
    zaitsev77
    zaitsev77 Member
    Frack
    Ohio
    2006 PreRunner
    Had to get creative since the instagram post wouldn't show embedded in my browser, but old post or not, that's a nice clean install. Good work.
    JStiner[QUOTED] likes this.
