Anyone running 17x9 Moto Metals
Discussion in 'Wheels & Tires' started by travbz24, Aug 27, 2011.
  1. Aug 27, 2011 at 5:40 PM
    travbz24
    travbz24 [OP] Active Member
    Des Moines, Iowa
    2011 BLK DC TRD SPT
    Is anyone running the Moto Metal 951 17x9? What tire size are you running on them? Think i want to go with this wheel setup but not sure if I'll need spacers and i don't think the stock 265/65r17s are wide enough.
  2. Aug 27, 2011 at 5:40 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Anything is wide enough....some people fit 11.5's on 10" rims, dont ask why but they do
    Should be fine with that size, makes sure you get the right offset and backspacing in case you decide to do a 3" lift later on with larger tires :D
  3. Aug 27, 2011 at 5:46 PM
    travbz24
    Des Moines, Iowa
    2011 BLK DC TRD SPT
    So running the stock 265/65r17s on that wheel won't change the overall height of the tire? i don't want to get outta sync with the spare and don't care to get the speedo inaccurate.
  4. Aug 27, 2011 at 5:49 PM
    08pretaco
    az
    sorry to say most speedo's are inaccurate from the factory. most vehicles that role out of the plant are 2-5% IIRC.
    all you are doing is changing the width of the rim, that would not affect the height at all. it will not even affect the tread width, the only thing it will do is "balloon" the sidewall out a little more.
    tires are read as follows:
    265 is the width in mm
    65 is the sidewall height, 65% of 265 is 172mm or 6 3/4"
    17 rim diameter
    So in order to increase the tire height, either the width needs to change and the aspect ratio remains the same or the aspect ratio goes up. I would say going with a 265/70/16 would actually get your speedo closer to "on".
  5. Aug 27, 2011 at 5:50 PM
    2kool4school
    2kool4school Well-Known Member
    Beau
    Honolulu, HI
    '12 JKU Sport
    as long as your tire is wider than the rim you will be find, which the 265/65/17 are about 10.4 inches wide so a 17x9 will be fine. but you wouldnt want to put to wide of a tire on it like a 33x16.5
  6. Aug 27, 2011 at 5:54 PM
    travbz24
    Des Moines, Iowa
    2011 BLK DC TRD SPT
    Awesome thanks guys!!
  7. Aug 27, 2011 at 6:01 PM
    travbz24
    Des Moines, Iowa
    2011 BLK DC TRD SPT
  8. Aug 27, 2011 at 6:07 PM
    08pretaco
    az
    looks right to me! :thumbsup:
    looks like you did your research on the wheel specs! good job
