Anyone running 285/70/17 w/ 17x9 0 offset and 5" backspacing?
Discussion in 'Wheels & Tires' started by bowhunterRN, Jul 25, 2015.
  1. Jul 25, 2015 at 3:19 AM
    bowhunterRN
    bowhunterRN [OP] Well-Known Member
    Eric
    Greenville, NC
    14 MGM TRD sport DCLB 4x4
    I have searched and searched and everyone seems to be running 4.5" backspacing with 17x9" wheels. Here is my setup: I have this lift http://www.ebay.com/itm/Full-Leveli...yota|Model:Tacoma&hash=item3a680ac3cc&vxp=mtr on a 14 DCLB TRD sport. Stock UCAs and 17x9 fuel krank 0 offset and 5" backspacing. I have found only one thread saying that they will work without rubbing the stock UCAs, but that was an 09 model truck. I know I will have to do some trimming and possibly a CMC but my question is will it rub the stock UCAs? Can anyone help here? I am currently running 265/70/17 and want to upgrade. thanks
  2. Jul 25, 2015 at 5:59 PM
    bowhunterRN
    Eric
    Greenville, NC
    Anyone? I guess I'll just order 0.5" wheel spacers to be safe since nobody is running a similar setup.
  3. Jul 25, 2015 at 7:15 PM
    bowhunterRN
    Eric
    Greenville, NC
  4. Jul 25, 2015 at 7:22 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    It's not the UCA that you should be worried about. It's the cab mount area. I have 17x9 with 0 offset and that's my only problem area.
  5. Jul 25, 2015 at 7:28 PM
    bowhunterRN
    Eric
    Greenville, NC
    thanks. So you are running 285/70/17 tires and no issues with the UCA clearance? which model truck do u have?
  6. Jul 25, 2015 at 7:58 PM
    Justinlhc
    265/70 but there is tons of clearance between the control arm and tire. I have an 05 TRD sport.
  7. Jul 25, 2015 at 9:17 PM
    bowhunterRN
    Eric
    Greenville, NC
    I am currently running 265/70/17 and need insight from people who have 285/70/17
  8. Jul 25, 2015 at 9:25 PM
    Justinlhc
    That's 20mm wider. If you have 10mm clearance on either side than you're good to go. It's not a big jump in tire size.
  9. Jul 25, 2015 at 9:27 PM
    bowhunterRN
    Eric
    Greenville, NC
    Thanks for simplifying that for me. Will measure when I get off work
  10. Jul 28, 2015 at 9:38 AM
    bowhunterRN
    Eric
    Greenville, NC
    285/70/17 KM2s work for me if anyone has a similar setup and was wondering if they fit. No scrubbing right now
  11. Jul 28, 2015 at 2:45 PM
    Justinlhc
    Awesome. Do you happen to have your alignment printout? Seems like that's going to wander on the highway
  12. Jul 28, 2015 at 4:42 PM
    bowhunterRN
    Eric
    Greenville, NC
    I haven't had an alignment done on these new tires. I had an alignment done after the lift and 265/70/17 with rims mounted. I went one inch bigger in tire height and a lil bit more width. Do I need another alignment done?
  13. Jul 28, 2015 at 5:54 PM
    Justinlhc
    Some people like to get alignments with a new set of tires for piece of mind. If I were you I'd get the SPC upper arms and THEN get it aligned PROPERLY. It will be a major improvement with the massive spacer lift you're using. :goingcrazy:
    You'll be amazed how much better it rides/drives afterwards.
  14. Jul 28, 2015 at 9:07 PM
    bowhunterRN
    Eric
    Greenville, NC
    I see no need for new UCAs at this point. I'm not a heavy wheeler and I have plenty of clearance and it drives fine right now. I'm still wondering if I need another alignment done when I went up 1" in tire? It holds true on the highway. Guess I'll have to do more research to find my answer
  15. Jul 28, 2015 at 9:23 PM
    Justinlhc
    Your alignment is definitely off. That would be the "need for new UCA's". It's not a clearance or an off-road issue. A new alignment is still going to net you a bad alignment on stock arms.
    If you're ok with the way it drives than leave it. :notsure:
  16. Jul 28, 2015 at 10:14 PM
    bowhunterRN
    Eric
    Greenville, NC
    im just concerned about treadware at the point. It drives fine for me. I will ask the shop to check the alignment and see where im at. I guess 0* Camber and 2.4* caster is where i want to be?
  17. Jul 29, 2015 at 5:44 AM
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    Leave it alone! Just rotate frequently.
    bowhunterRN [OP] likes this.
  18. Jul 29, 2015 at 9:20 AM
    Justinlhc
    Yeah, fuck alignment! :headbang:
