Anyone running a Resonator:
Discussion in 'Performance and Tuning' started by roxspin72, Jan 7, 2009.
  1. Jan 7, 2009 at 7:10 PM
    roxspin72
    roxspin72 [OP] Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Prefferably w/DTLT.
    Been hearing lots of issues with the infamous Rasp. plus I am running the URD Y-pipe, so Im sure it will come to play.
    Been researching the issue and seems some fixed with Magnaflow. But that fix was going from Flowmaster to Mag.
    Mag. is a straight threw just like my Borla. Both reputable companies. So instead of switching mufflers, thinking of adding a Resonator between the Y-pipe and my borla.
    Big question is which brand, and is longer better at ruducing noise???
    The only conclusion I made is I want stainless, local shop told me they will weld on, plus weld all exhaust links at the band clamps, and add the O2 bung to my DT's for $60.
    Just need advice before I buy...
    Here are to ideas I have, not sure yet if second one will fit underneath:
    http://vibrantperformance.com/catal...id=46&osCsid=4ffe7690b2fe3f595f54b2f540e44f81
    http://vibrantperformance.com/catal...d=291&osCsid=4ffe7690b2fe3f595f54b2f540e44f81
    Thanks...
  2. Jan 8, 2009 at 5:35 AM
    roxspin72
    NC
    Oh Yeah!!!
    Or better yet has any of the TW DTLT owners configure their exhaust to eliminate the raspy sound???
  3. Jan 8, 2009 at 9:37 AM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    ur best bet is to go to stock y-pipe or invest in the pipe bomb. or add an extra muffler like gadget did
    EDIT: sorry just read u wanted stainless and the pipe bomb is not
  4. Jan 8, 2009 at 11:59 AM
    sonjay
    sonjay Well-Known Member
    You could get a muffler shop to build you a cross-over pipe for much cheaper then they charge for the pipe bomb.
  5. Jan 8, 2009 at 1:13 PM
    roxspin72
    NC
    Oh Yeah!!!
    I got the Y pipe, rather live with rasp then give that up. Why would you say a muffler rather than a Resonator. I believe a 2nd muffler is a little to much and too heavy. Thats why I want a resonator, just want to know what brand is quality.
  6. Jan 8, 2009 at 1:52 PM
    tacoskim
    Los Angeles, CA
    Stock
    2nd muffler will tone down the sound alot! check gadgets ride, such a sleeper is scary :eek:
  7. Jan 8, 2009 at 5:18 PM
    roxspin72
    NC
    Oh Yeah!!!
    Well, went under the truck this evening with a measuring tape, and cant even begin to thinks of where I would put a 2nd muffler, barely any room for a resonator. Probably why the Pipe Bomb came out,; best place to put resonators. Guess Gadget has more room on his 2WD XR.
    So sorry to start a thread with out propper specs, but it looks like I will just have to run straight through with the Borla... Maybe I will be lucky, and no rasp will be present.
    Anyways, thanks for the help...
